April 29, 2026, 03:20:15 pm
Hoffman Amps Forum image Author Topic: 12AU6 as V1  (Read 15648 times)
Offline oldhippy
12AU6 as V1
« on: June 05, 2010, 11:22:17 am »
hey guys,
I scored a Soundtronics B-35 cathode biased 6BQ5 PP bass head, maybe mid-to late 60's???(in original leopard skin tolex!) I can't find a thing on it as to history or schematic. I started drawing it out adn it has a 12AU6 in 1st position. I'm not sure what to make of that...anybody care to instill alittle knowledge on a motivated student? I only thing I can find on that tube is that it is a sharp cutoff pentode...what's it doing in my new cathode biased push-pull? :-) many thanks! Steve
Offline Tiny_Daddy
  • Get your Amp N Gear!
Re: 12AU6 as V1
« Reply #1 on: June 05, 2010, 11:55:38 am »
7-pin 12AU6, not 9-pin 12AU7? What other tubes are in there?
Offline Geezer
Re: 12AU6 as V1
« Reply #2 on: June 05, 2010, 12:08:43 pm »
Possibly really good things!
A pentode in the V1 spot can be a real tone generator.....a TD said, what else is in there?
Offline oldhippy
Re: 12AU6 as V1
« Reply #3 on: June 05, 2010, 12:11:23 pm »
thanks
I've looked at it several times, 7 pin 12AU6. It's a single triode( I think) thre's also12AT7 (PI) and a pair of 6BQ5's. The tubes are at AES, adn they're real cheap, like $4 ea., but mainly I'd like to know can I treat it like a regular triode because the grid resistor taking the signal to ground is only 100K. Not sure what to do with it...if it's regular triode, I would up that to at least half meg, but I've never seen an input to ground resistor that low in value before, and I'm pretty green as far as tubes and audio go. It would be nice to know what kind of gain it has, as well.
Offline Geezer
Re: 12AU6 as V1
« Reply #4 on: June 05, 2010, 12:18:40 pm »
No, it's definately a pentode.......
http://tdsl.duncanamps.com/show.php?des=12AU6
Same specs as a 6AU6......Mu is 36 when triode connected.
http://www.nj7p.org/Tube4.php?tube=6AU6
Offline oldhippy
Re: 12AU6 as V1
« Reply #5 on: June 05, 2010, 12:28:37 pm »
PENTODE!!! last night was friday night...
Offline oldhippy
Re: 12AU6 as V1
« Reply #6 on: June 05, 2010, 12:40:23 pm »
6AU6... I have that pinout. Thank you. Now I can get that drawn out this wkend. I'll post it if anyone is interested...
Offline Shrapnel
Re: 12AU6 as V1
« Reply #7 on: June 05, 2010, 02:04:01 pm »
When are we not interested?  :thumbsup: We relish the "new" circuit and what it might teach us.  :toothy9:
-Later!
Re: 12AU6 as V1
« Reply #8 on: June 05, 2010, 02:22:05 pm »
thanks
http://www.mif.pg.gda.pl/homepages/frank/sheets/093/6/6AU6A.pdf
page 2 has a typical circuit with various component values.
Re: 12AU6 as V1
« Reply #9 on: June 06, 2010, 05:36:03 am »
And are you sure it's not a 6AU6? Do you actually have 12.6vac between pins 3 and 4?
Unlike the 12A_7 series, you cannot run a 12AU6 with 12.6v or 6.3v. The 6AU6 is the 6.3vac version.
Offline oldhippy
Re: 12AU6 as V1
« Reply #10 on: June 07, 2010, 05:09:37 pm »
Thanks for the interest! Much to learn. I've attached ( I think) a sketch of the Soundtronics B-35. I've only cked it a few times, I think it's right. Yes, it's a 12AU6 and it is heating up on the same 6.2VAC as the rest of them. I looked and there is a faint orange glow in there...
I haven't had a chance to really dime it but what I hear I like. Lots of harmonics on the upper strings, nice sensitivity. I did change out the 100K input R to 1M before I even gave it a listen. Thoughts? ideas? I'm wide open. Thank in advance, Steve in Tucson
Re: 12AU6 as V1
« Reply #11 on: June 07, 2010, 08:41:19 pm »
That's not logical.
Offline oldhippy
Re: 12AU6 as V1
« Reply #12 on: June 07, 2010, 09:29:21 pm »
could it be that the amp has the wrong tube in it? Please give me more than that. I'm hopeing to learn something here...
OK, I just ck'd it again, up and screamin' the 12AU6 is getting 6.3VAC...just barely glowing, and sounding good...Just how hot does a cathode have to be to properly emit??
« Last Edit: June 07, 2010, 09:44:38 pm by oldhippy »
Re: 12AU6 as V1
« Reply #13 on: June 07, 2010, 10:54:59 pm »
Put simply, the heater's job is to get the tube ready & hot enough to "boil off" or excite the electrons to the point that they are ready to do their job and hit the plates from the cathode.
Yes you may have the wrong tube, if the filament voltage is 6.3 Vac then you should be using a 6au6 not a 12au6. The first number on a tube designates it's filament voltage it should be ran with. The only other situation would be if you ran two 6au6s in series to make the 12 Vac but this isn't your case.
The values on the pentode are kind of odd. You may try a 220k inplace of the 1M load resisitor and use the 1M in place of the 3.9M on the screen. Then sub a 2.2k for the 6.8k cathode R and put a capacitor across that. But, first you need to get the correct tube in there before you do anything further.
Re: 12AU6 as V1
« Reply #14 on: June 08, 2010, 12:08:18 am »
Yes, change the inpiut grid resistor to 1Meg.
You may discover that the amp is "too darn bright", and loading-down the guitar with a 100K resistor was the lowest-cost way to "fix" it.
The cathode should be near 1,000 degrees C. The "orangeness" should be similar to your 12AX7. Emission falls off quickly with lower temperature. However the *AU6 is a 10mA tube, here used at ~~0.1mA or 1% of what we could suck through it. It is remotely possible it can "work" even when severely under-heated.
Re: 12AU6 as V1
« Reply #15 on: June 08, 2010, 12:29:39 am »
EDIT: Removed a comment meant humorously, but which could have been misinterpreted.
How much "hot" is hot enough?
The data sheet was linked earlier in the thread; take a look at it. Right up at the top, it says a 6AU6 wants 6.3v @ 0.3A, and the 12AU6 wants 12.6v @ 0.15A. If you multiply either of those, you get about 1.9 watts. That's how hot the cathode wants to be to properly emit, 1.9w worth. The cathode and the rest of the tube don't care how you make that happen.
Unfortunately, the heater dictates what you can do. The 12.6v heater looks like 12.6v/0.15A = 84 ohms when it's hot. The 6.3v heater looks like 6.3v/0.3A = 21 ohms when hot. That's a big difference. If you apply 6.3v to the 12.6v heater, you get 6.3v/84 ohms = 0.075A, and 6.3v * 0.075A = 0.4725w. That's 1/2 the current, and 1/4 the heat!
Yep, the tube may light (dimly) but won't do it's job right.
But we're *ass*uming here... Did you measure with a meter lead on pin 3 and the other lead on pin 4? Or did you measure from one of these pins to ground? The "right way" to see the full heater voltage is from pin-to-pin. When you measure from pin to ground, you see half of the total heater voltage present.
And we're also assuming heater wiring like the usual guitar amps. It is possible, if the winding puts out 12.6v, to use a 12AU6, a 12AT7 with pin 4 to one side and pin 5 to the other, and the 6BQ5 heaters in series, with the whole shebang in parallel. That might be goofy, but I've seen weirder.
... could it be that the amp has the wrong tube in it? Please give me more than that.
Or it could just be the wrong tube. 6AU6 is still near dirt-cheap, but not as dirt-cheap as a 12AU6 might be (the 6v version was used in more stuff).
Well, you could do that...
The road forks here; you'll have to decide which trip sounds more appealing to you.
This whole thing looks like a power amp to me. Yeah, I see a tone control, but it looks a lot like input gain stage -> phase inverter -> output tubes. And that's the basic plan for 97.6% of all stand-alone power amps, whether they're PA, instrument or Hi-Fi. So, the question is what are ya gonna use this for? If for bass, you might leave it be. If for guitar, the right pentode may or may not be raucous enough as-is.
Without calculating, the 1M plate load does look high. But the way to get the most gain out of a pentode is to raise the plate load. The screen resistor should be a value related to the plate load. Normally, the total cathode current goes mostly to the plate, with some portion splitting off and going to the screen. The ratio of plate current to screen current is pretty consistent within a given tube type. It would appear that a 6AU6 would be a 4-to-1 ratio of plate current to screen current, judging by the resistor values and assuming the designer wanted similar voltage on each element.
The data sheet typical conditions shows 5mA plate 2.1mA screen, 7.6mA plate 3mA screen, and 10.6mA plate 4.6mA screen. Thpse all land pretty near 2.5:1 for the ratio of plate to screen current. So we can see without measuring that the designer wnated the screen voltage lower than the plate voltage, and useda screen resistor 4x the plate load instead of 2.5x the plate load.
So that would mean a lot of gain, maybe. Big screen resistor means less screen voltage which means less plate current. When plate current in a tube drops, Gm drops too, so that could drop our gain some. The unusually big 6.8k cathode resistor seems wrong, maybe too big. Is it Blue-Gray-Red (6.8k) or Blue-Gray-Brown (680)? It might be the bigger value to still arrive at a healthy bias voltage with low plate current.
We'll save ways to butcher the pentode for later...
So the 2 roads I was thinking about: You could try to make this an all-in-one chassis like every other guitar amp. Or... you could accept is as just a power amplifier, and make seperate preamps to mate up with it. You could possibly play with a number of different designs and not have to re-work the main amplifier chassis, just the couple-tubes for your preamp chassis.
What do you think?
« Last Edit: June 08, 2010, 09:56:47 am by HotBluePlates »
Re: 12AU6 as V1
« Reply #16 on: June 08, 2010, 05:30:16 am »
I'd be tempted to build DaGeezers HoSo56 with a 6AU6 pentode in V1. You will need to add ONE tube. Should be an easy mod.  DaGeezer built a dual pentode HoSo56 with 6AU6 & 5879.  I did the same thing and the 6AU6 was a close second tone wise to the 5879.
Re: 12AU6 as V1
« Reply #17 on: June 08, 2010, 08:31:53 pm »
Many ways to butcher the cat.
But we usually slice-off the "Power Amp" after the user volume control. Also the NFB loop encloses the power amp section. And the power amp input sensitivity is very roughly 1V.
6BQ5 needs say 12V at grid. 12AT7 paraphase has gain near 20. So this plan needs about 0.6V at 12AT7 grid.
Add the *AU6. Gain may be 60. Its sensitivity is like 0.6V/60= 10mV. Much lower than power-amp input convention.
The 6K cathode resistor suits the low *AU6 current. Assume 100V across 1Meg, plate current is near 0.1mA. This 0.1mA in 6K gives 0.6V cathode bias, and also in this case roughly 0.6V maximum clean input, in line with a hot guitar.
It's unsophisticated low-cost design. For super-clean (ala Dyna) we'd wrap the pentode and triode together, then slam it with massive NFB. Then you need something more for preamp and tone-control.
Yes. But the load is mostly the 750K pot. While with modest triodes we tend to pick plate resistor smaller  than load, with a fat pentode the gain and output are good with plate resistor a bit higher than load. It's odd, not wrong.
The very high impedance suggests a top end of "only" 9KHz, but that's ample for guitar.
Offline oldhippy
Re: 12AU6 as V1
« Reply #18 on: June 09, 2010, 09:37:24 am »
Thanks for all the interest!
I ck'd voltage on pin 3 to 4 and measured 6.3 volts on this 12AU6 miniature pentode. Just barely see it glowing. compared to the rest of the tubes, it is very dull. I had a friend plug into it, it made him smile...???
PRR, I changed out the input R to 1M before I even tried it, after I thought about it for a minute. I wish I had tried it before, just to see, and to adhere to proper convention. It works and to my cymbal-deaf former semi-pro ears, it sounds tasty! Further evaluation is dictated. From my virgin newby- hobbyist point of understanding, I too suspect it wouldn't be working if it was actually being asked to do something. Thanks for the explanation, a fraction of a milliamp? I would imagine if the filament was hot enough to be emitting visable light, and the cathode is mounted very closely to it the temperature of the two elements would be roughly the same and that there would be some flow...potential...would it work as well in a cold room? :-) anyway, a 6AU6 is on the way. Should be interesting.
HotBlue, humorous remark taken as such. I laughed. Printed communication is far from ideal and being "in the moment"
can cause all kinds of mis-perceptions. Thank you for the consideration, though! So... 1.9 Watts worth...OK :-)  I doubleck'd the resistor values and they are correct.
I'll probably put it in a combo cab as a guitar amp, easier to get rid of, after I get tired of it. I noticed I forgot to insert signal cap values...most were .003uf and bass response is alittle much. Where to start...would you cut the value of the pentode C? And to what? .001?
JOJOKEO, thanks for the suggested R values, the proper tube is on it's way.
Tubenit, I have read about the Soho adn it sounds like a real possible. I would have to take the iron and the tubes and basicly start over. This thing is a PCB screwed to a piece of 3/8ths particle board, mounted in a 5/8ths particle board cab and covered with leopard skin plastic. I don't think it's worth much as is. Any Soundtronics collectors out there? This thing may be a jewel and I don't know it! :-) Maybe start with an 18watt marshall chassis? I'll do alittle research...good idea. Thanks all, for your interest, I'll be back when I get a 6V tube. ...peace...
UPDATE"The values on the pentode are kind of odd. You may try a 220k inplace of the 1M load resisitor and use the 1M in place of the 3.9M on the screen. Then sub a 2.2k for the 6.8k cathode R and put a capacitor across that."
After some thought, I decided to change out the resistors to the values suggested and it doesn't work now! I get a little spiting noise when I slam it.lol! Hmmm...Do you suppose it was designed that way? Maybe the owners brother bought  10,000 tubes with the wrong filament voltage and they wouldn't take them back??lol ...discuss... Thanks guys, if wasn't for this website, I wouldn't be doing any of this, I am just a lowly tech... But I am learning!...peace...
Re: 12AU6 as V1
« Reply #19 on: June 10, 2010, 01:35:12 am »
My mistake was seeing what I wanted to see.
After all the split-load fun, I forgot to notice that the paraphase has higher sensitivity on it's own. And the old power amps I was thinking of typically have a stage (maybe pentode) ahead of the phase inverter, but the feedback loop usually runs to that input stage. All that means is less sensitivity, more total feedback, and more likelihood of oscillation unless much care is spent tweaking phase shift at every stage.
Now that PRR has readjusted my focus, this looks a lot more like a 5C3 Deluxe, but with EL84's and maybe too much input sensitivity.
I ck'd voltage on pin 3 to 4 and measured 6.3 volts on this 12AU6 miniature pentode. Just barely see it glowing. compared to the rest of the tubes, it is very dull. ... I would imagine if the filament was hot enough to be emitting visable light, and the cathode is mounted very closely to it the temperature of the two elements would be roughly the same and that there would be some flow...
Think about it this way:
You've used a dimmer for room lights, right? In the end, you reduced the power fed to the lightbulb filament, and while the bulb was dimmer, there was still light.
To meet ratings, the full filament power specified for the tube has to be heating the cathode. That allows the cathode to emit sufficient electrons at all times to meet ratings. Less heating power = fewer electrons, but how much fewer?
Some better tube testers had a "Life Test". You perform an initial test on the tube; in most Hickok testers, that test measured how much plate current flows when an input signal is applied to the grid. Then to make the life test, you throw a switch, and test the tube again. The measured plate current is expected to drop somewhat, but if it stays within a certain range of the first reading, the tube is deemed to have a lot of life remaining.
The life test switch reduces the filament voltage on the tube. for a 6.3v tube, it normally reduces filament voltage to 5v, about 20% low. The filament power will reduce by about 40%. That means the cathode should release fewer electrons. If the tube still gives a decent measurement (in some cases, I have had tubes that didn't change the reading at all) then the cathode has a large reserve capacity to supply electrons and the assumption is that it will last a long time.
Still with the 12AU6? I'd put the original parts back and wait for the 6AU6. Who knows what might be out of whack, and there's no point making changes until you know what the amp should sound like when properly working.
Offline oldhippy
Re: 12AU6 as V1
« Reply #20 on: June 10, 2010, 10:02:08 am »
HotBlue, thank you, you are a wellspring of information. I got the 12AU6, installed with the revised R values and it works great...sure cleaned it up some :-) At low levels it's blues clean, with even more bass. Very nice! I re-installed the original values and didn't notice a definate difference. But like I said earlier, I'm somewhat cymbal deaf so I'm no reference. I think I like the tone better than my 59bassman, although that's entirely subjective, because I've always liked the sound of the EL84's. I think I'll just play it for a couple of days as is and get a feel for it...the sensitivity is nice, is that the pentode? I'll ck the bank account and see if I can afford to do a re-build on this thing. It would be nice to add an extra stage so I could stick a tone stack in it, but it really needs a chassis... but for now,how about lowering the value of the first signal cap to get rid of some of that bass? watcha think? thanks
Re: 12AU6 as V1
« Reply #21 on: June 10, 2010, 10:26:52 pm »
> like a 5C3 Deluxe
Like a million paraphase amps. But the pentode input is odd.
Ponder the earliest Fender Pro:
 http://www.schematicheaven.com/fenderamps/1946_pro.pdf
Yes, the paraphase is drawn wrong. The 10K should dangle from the other 250K grid resistor.
Also the sensitivity is the same for Mic or Inst, and the input overload is awful low by modern guitar standards. It's for older tamer pickups and gentle Hawaiian playing.
