September 17, 2026, 04:12:15 pm
Hoffman Amps Forum image Author Topic: LA2A compressor  (Read 27239 times)
Offline Bub
LA2A compressor
« on: June 10, 2010, 08:11:33 pm »
Hi Gent's,
I don't understand how to hook up an LA2A. Everything I've read seems to indicate hooking it up between the pre-amp and power amp in a series configuration. Am I able to hook it up between my guitar and my pre-amp?. The amp I built does not have a line out or in.
Rob
Re: LA2A compressor
« Reply #1 on: June 11, 2010, 01:28:01 am »
That depends on how you want to use it.
It's made for higher-level signals either coming from a tape machine output or mic preamp output before being fed back to either tape or a console mixing buss. However, I have seen bass plugged into its input either through a DI box or a preamp.
What are you trying to accomplish with it?
Offline Bub
Re: LA2A compressor
« Reply #2 on: June 11, 2010, 11:54:20 am »
Thanks for the reply HBP,
I'm trying to do a couple of things.
1st, even out my volume from aggressive to soft playing and thought a compressor may be the way to go but I don't really know alot about them.
2nd, I have read alot of bass players use an LA2A and just love them but how they are wired I can't seem to find.
3rd, looking for something fun to build with tubes that I can use with my setup, a basic amp and 4x10 cab. I was hoping it would be as simple as wiring in a couple of 1/4 jacks for a series connection between my guitar and amp but something tells me not. If I were to wire a send and return between my pre-amp and power amp would this accomplish what I'm looking for?. I am not trying to alter my sound in any way, re clean up, filter etc. What I have is Ampeg B15 on steroids.
Thanks for any help
Rob
« Last Edit: June 11, 2010, 12:43:13 pm by Bub »
Re: LA2A compressor
« Reply #3 on: June 12, 2010, 12:14:38 pm »
Well, it is an expensive compressor to use just for playing. If you were able to also use it in recording, it would probably be a better option.
Anyhow, the DIY LA-2A page mentions it costs about $800 to build yourself. That's still a bargain over buying a new or used LA-2A. Only you can decide if the cost is justified for your use.
It normally comes with terminal strips (old LA-2A) for input and output, or terminal strips and XLR connectors (modern LA-2a and modified units). You could probably modify it to use 1/4" jacks. The stock circuit is usually push-pull in and out and at a low 600 ohm line impedance. I'm not sure what modification is needed to use with an instrument directly into the compressor.
Also, the circuit is suited for line-level. There is a gain knob, but what that does is boost the incoming signal to a point where the limiting action can kick in.
Hopefully PRR will see this and chime in, as I think he knows more about how easy it will be to adapt this compressor to your use.
Offline Bub
Re: LA2A compressor
« Reply #4 on: June 12, 2010, 12:55:38 pm »
Thanks HBP,
I don't mind the cost, it's something I could piece together over time and looks like a neat toy to play with. I'm starting to get a better understanding of FX loops. From what I've read I don't think I can install between my guitar and amp, but I could be wrong. I think I would have to install an effects loop in my amp. I don't really understand too much about recording but thats for the future. The schematic is my pre-amp and I'm wondering the best place to install a loop. Would it be better before or after my volume control?. V1 is 6SL7 but I'm using a 12AX7 for my PI. Maybe I'm chasing the wrong thing to build but I'm looking for a project that I can use with my guitar and amp. Any suggestions?
Thanks again
Rob
« Last Edit: June 12, 2010, 01:11:14 pm by Bub »
Re: LA2A compressor
« Reply #5 on: June 13, 2010, 06:08:26 am »
Well,there are a number of compressor pedals that you might try, or even build, prior to going after the LA-2A.
Regardless, that looked like an O'Connor schematic, which means you have at least one of his books on hand. I do not have a lot of practical experience with effects loops, but there are a couple of reportedly good loop circuits in O'Connor's books. If your book doesn't specifically discuss them, look at some of the other projects to find one with a loop (maybe the Standard, or similar).
Geenrally, the best place for an effects loop is between the preamp and phase inverter. The preamp has boosted the instrument signal up to a sort of line-level, which would be helpful if you tried to use an LA-2A. O'Connor has some good circuits for splitting off a send signal for the loop, and for mixing it back with the dry signal.
Offline Bub
Re: LA2A compressor
« Reply #6 on: June 13, 2010, 04:55:39 pm »
Thanks again HBP,
Yes you are correct, that is a KOC schematic. After about eight hours on the net looking for info I had a (Da moment) and looked in TUT1 and lo and behold there was most the info I was looking for but it pertained to buffer circuits with pedals and why you need them. It was stupid of me to think that I could hook an LA2A between my guitar and amp. KOC has some excellent buffer circuits using send control, release control utilizing a 12AT7. Now here is where I'm at.
Do I need a buffer circuit? I don't think so as this is part of the LA2A, re gain control, please correct me if I'm wrong. Can I use a simple series passive effects loop and plug in the LA2A? and question #3, if I can plug it in to a series passive loop should it be before or after my volume control as I have seen schematics with a passive loop either way. I'm not really a pedal guy, I just don't want to go out and buy something that works, that's no fun. I'm not a prolific builder (as I'm sure you can tell) I'm just looking for something really nice to build that I can use.
Again, Thanks for all the help
« Last Edit: June 13, 2010, 05:08:35 pm by Bub »
Re: LA2A compressor
« Reply #7 on: June 14, 2010, 04:28:56 am »
I think LooseChange might have better info from experience with loops.
Application determines the best approach.
I personally only have a couple of pedals, and don't use them frequenctly. For me, it's enough just to plug them between the guitar and amp input.
The location of the loop depends on the intended outcome. The guys who use an either a standalone preamp, or an amp with a master volume to generate preamp distortion, generally want their distorted signal to go from the preamp out to effects and back into the amp at the input to the phase inverter. That's because they want the sound that is generated and shaped by the preamp to be altered by the effects, rather than the raw guitar signal.
When you read a lot of bass players like the LA-2A, what you really were seeing (and it might not have been pointed out) is that they were playing through their normal setup (bass, amp, speakers), then having the sound of the speaker picked up by a microphone and sent to a mic preamp and on to tape (or hard disk). If compression is used when tracking, it is purposely light, as it can't be readily undone later. Then during mixing, the bass signal is sent to the LA-2A and squashed down as much as the producer and engineer feel necessary, then sent to the console mixing buss and eventually to 2-track tape (or hard disk).
So the sound altered is the sound of the entire rig, not usually prior to feed into the amp. That's not always true, and some bass amps actually incorporate some kind of compression circuit.
The current production LA-2A can accept +4dBm or -10dBv inputs. In layman's terms, the +4 input is the old professional recording/broadcasting standard, and the -10 input is the "commercial/consumer" level. -10dBv corresponds to about 0.25v RMS, which is likely more than double what your bass will output on its own. +4dBm is about 4 times bigger than that, almost 1v RMS.
1v RMS is actually bigger than the input signal to most phase inverters, so it looks like we want to at least tap off just prior to the phase inverter. We also have to assume that the original circuit shown in the DIY LA-2A page is copying the original circuit. That means you'll likely need some boosting.
Do I need a buffer circuit? I don't think so as this is part of the LA2A, re gain control...
The LA-2A doesn't work quite like that.
The idea is to keep the signal fed into it from exceeding a level set by the Peak Reduction knob. You might feed a signal into the LA-2A too weak to really cause the limiting circuit from acting on it. To force it to compress and get a resulting sonic change, the Gain control is provided to boost the signal until there's enough to activate the compression circuitry.
But! You really need to make sure you feed the LA-2A a signal of sufficient size. You don't know for certain that there's enough gain available from the Gain control to make up for a very weak signal. Even if it does, you don't want to limit the range of options available.
Active or passive? If you tap off after the preamp, you may have enough signal output from the LA-2A to drive your phase inverter, but maybe you won't. That is possibly the case for severe gain reduction. But stock, the input impedance to the LA-2A is 600 ohms, and is way too low for your preamp (or bass) to drive. You need a buffer of some kind with an output impedance equal to or less than 600 ohms (preferably less). You might need a transformer to reduce the output impedance.
An active loop also gives you the opportunity to boost the signal back up after it returns from the effects. That is probably not necessary with the LA-2A, but if you use any kind of pedal originally designed to go between the instrument and amp input, you will almost certainly need to boost the signal back up to the size needed to drive the phase inverter.
I don't remember if TUT 1 has the effects loop I'm thinking of, but one of the other project books does. It can be series or parallel, has an active and adjustable low-impedance output and a return that reboosts the signal (also adjustable).
We really need some other bass players to chime in, especially those with effects loop experience. For guitar work, I know my choice would be a parallel active loop. But it's not a one-size-fits-all situation.
Offline Bub
Re: LA2A compressor
« Reply #8 on: June 14, 2010, 12:25:05 pm »
Thanks for the explanation HBP, That really helps out alot.
I need to learn more about line signals, recording and what components go where. I don't know if anybody has done what I'm trying to do. KOC has an excellent buffer circuit he calls (The best all tube effects loop) but I would have to build it in with the LA2A as my amp has no more room inside. I just might stop by the music store and see what pedals are available but I still have to try and pursue this. Maybe somebody can tell me if I'm completely out to lunch on this one or not.
Thanks for looking back at my post and helping me out.
Rob
« Last Edit: June 14, 2010, 01:15:08 pm by Bub »
Re: LA2A compressor
« Reply #9 on: June 14, 2010, 01:16:26 pm »
Before buying anything, I'd just try a simple passive loop. Kinda like this...
http://home.comcast.net/~seluckey/november/november.pdf
I'd first insert it before the volume control. then I'd try it after the volume control (you'll likely need a dedicated 1M grid return resistor for that next triode). You may get lucky and find this is all you need to do.
Offline Bub
Re: LA2A compressor
« Reply #10 on: June 14, 2010, 01:49:35 pm »
Thanks Sluckey,
I will install that type of effects loop, but before I build an LA2A I need to find out if it will work.
Rob
« Last Edit: June 14, 2010, 01:56:30 pm by Bub »
Re: LA2A compressor
« Reply #11 on: June 14, 2010, 02:15:59 pm »
Somehow I missed that point. I thought you had one already.
Offline simonallaway
    • Hot Bottles - Tube Amp Blog
Re: LA2A compressor
« Reply #12 on: June 14, 2010, 02:51:06 pm »
I think it depends on whether you want to use a compressor for artistic reasons, or simply in an engineering/technical capacity to help get the signal on the tape. Some bass players like to us different compression setups on different frequency bands. I know that technique is used a lot by Steely Dan's engineer Roger Nichols.
Offline Bub
Re: LA2A compressor
« Reply #13 on: June 16, 2010, 10:04:25 am »
Hi Gentlemen,
No I don't have one yet but I want to build one, but before I take on this project I'm trying to find out if it will work with my setup.
Here is where I'm at. My tone quest is 90% complete. I built an amp with a Ampeg B15 pre-amp and output section of a Traynor YBA3 with 4 x 6550s. I built the bass I've always wanted with Hofner 511b pickups. The tone is incredible but volume is very sensitive with playing style especially above the 12th fret, this thing howls, just like a Hofner does. So this leads me to a compressor, yes I could go buy a pedal and be done with it but from reviews I read (this one hisses a little or the hum one that one isn't too bad or it gives you that nice tube warmth). I have no hiss, no hum and tones of tube warmth. I'm looking for a quality tube compressor to build that is transparent as possible. I know the LA2A is made for broadcast or studio use which is where my problem comes in, can I tie it in to a stand alone amp head and cabinet. Something tells me I am out to lunch on this but it sure would be nice if it could be done. On the other hand, any peddle recommendations?, there seems to be about 10,000 to chose from.
Thanks for the help, past and present.
Rob
PS simonallaway, that hammered paint looks incredible
« Last Edit: June 16, 2010, 10:36:14 am by Bub »
Re: LA2A compressor
« Reply #14 on: June 17, 2010, 01:03:07 pm »
Thank you, but that was pure luck. I achieved that finish by spraying way too much in one pass, but the piece was level so it pooled nicely. I just let it dry cos it looked cool  :grin:
Offline RicharD
    • Toxic Water
Re: LA2A compressor
« Reply #15 on: June 20, 2010, 03:01:47 pm »
The LA2a is a studio compressor with balanced input & output.  Not something you can simply plug your guitar into.  Kent Stevenson has a nice web page about home brewing one.
http://www.conditionedresponse.com/DIY/LA2/index.html
What "makes" the LA2a is the T4B opto-coupler.  It is to the LA2a what the "roach" is to the classic Fender tremelo.  These compressors are only as good as the T4B.  Here comes the rub.  The T4B went out of production a few years ago.  They used to sell for $50.00 and somebody bought up the remaining stock and is selling them for $250.00 ea.  You can DIY one but with varying results.  I have to agree with HBP that this is not a guitar compressor.
Now I will assume you are like me and simply have to build your own compressor.  How about a variant of the PRR Vari-mu compressor?  Oh look.... another Kent Stevenson web page:
http://www.conditionedresponse.com/DIY/C5/index.html
A Vari-mu compressor experiment is about one or 2 projects out for me.  A guitar version might be a nice side excursion.
Offline Bub
Re: LA2A compressor
« Reply #16 on: June 21, 2010, 07:57:34 am »
Thanks for the links and info Butterylicious,
Yes, I just have to build something and that looks like a great project.
Rob
Offline TubeGeek
    • Glacier Amps
Re: LA2A compressor
« Reply #17 on: June 26, 2010, 10:51:43 am »
An LA-2A has been on my to do list for a couple years now.  I have collected and hoarded info I come across.  This layout looks very nice.  I have not checked for errors.  I have a bunch of other schematics and layouts also, let me know if you'd like a copy.
Offline Bub
Re: LA2A compressor
« Reply #18 on: June 27, 2010, 02:18:20 pm »
Hi TubeGeek,
Thanks for the offer of the info but I think I'm going to change gears on this one. As Butterylicious said above the T4B opto-coupler is now $250.00 bucks! I was going under the asumption they were $100.00 and being the heart of the LA2A I would want a spare on hand just in case, now I would be up to $500.00 even before the build starts. Just a tad too pricey for what I want to do. In searching compressor's I came across the (PRR compressor) so I think I'm going to persue that one, 2 x 12au7s and some Solid state things which I'm going to have to learn about. I' ve never made a circuit board before either so I have to do that or go point to point if possible.
Thanks again
Rob
« Last Edit: June 27, 2010, 02:57:41 pm by Bub »
Offline Bub
Re: LA2A compressor
« Reply #19 on: June 27, 2010, 03:19:37 pm »
I tried to post the schematics and link but my confuser doesn't seem to be cooperating today.
Rob
Offline Rev D
Re: LA2A compressor
« Reply #20 on: June 27, 2010, 04:49:01 pm »
 On building a circuit board, just start on a small pedal project to get a feel for it. I know theres all sorts of products to stick and develope and then etch. I've had good luck on a few boards I made where I just used a laser printer and had it print as dark as I could (putting down more toner) then just cleaning the copper real good, ironing the toner side of the circuit to the copper and then etching, it was surprising to me how well the toner transfered. From there I just used echant from Radioshack and it worked fine.
 Of course there's ton's of techniques out there documented so do whatever works for you, just thought I'd put forth how easy it is to make simplistic circuit boards (and one of mine wasn't that simple, it was for a univibe which I've yet to put together), its not a scary deal at all.
Regards,
RD
Offline Bub
Re: LA2A compressor
« Reply #21 on: June 27, 2010, 09:44:40 pm »
Thanks Rev D,
The pattern for the circuit board is on the DIY Factory site so the hard work is already done. I haven't done any research yet on how to make boards but what you have just described, it doesn't seem that hard. I'll post a picture when I'm done.
Rob
Re: LA2A compressor
« Reply #22 on: June 28, 2010, 10:56:33 am »
I'd recommend the"DR Comp" board from this site http://diyeffects.com/products.htm
I built a pedal based on their TS Overdrive and it was really cool. I plan to build one of these compressors myself (once I finish all my other unfinished projects).
Offline Bub
Re: LA2A compressor
« Reply #23 on: June 28, 2010, 04:37:40 pm »
Thanks for the info and link simonallaway,
That looks like a great project and relatively inexpensive, but it has no tubes, I need tubes. There's just something about electrons traveling through a vacuum that excitates me. Which now brings me to the (Retrospec Squeeze Box) I think I have finally narrowed it down. It's tough when your new to this field and don't know what is out there. Only 10,000 pedals to choose from. But I don't care if it is in pedal form.
The Retrospec Squeeze Box operates at instrument or line level, no transformers, and has tubes. Does anyone have a schematic of this? I've been looking with no luck. This looks like it would be a really cool project. I think I might have to start a new thread on this one.
Thanks for everyones help
Rob
« Last Edit: June 28, 2010, 05:00:01 pm by Bub »
Offline nateflanigan
Re: LA2A compressor
« Reply #24 on: September 20, 2010, 07:14:23 am »
I've built the drip La2a, it sounds fantastic, i think it cost between $600-$700 dollars and could definitely be done cheaper.  He doesn't sell that PCB anymore, but with the available layouts you probably don't need one, he does still sell the T4b though which as mentioned is a big deal.  As far as getting line level into the La2a I don't think it's necessary, the thing as tons of gain.  When I use mine for mixing I barely turn up the input gain.
You might want to consider building a Gates STA level, or Federal am 64 limiter.  They would probably be cheaper and easier and get you to the same place.
