September 19, 2026, 10:28:52 am
Hoffman Amps Forum image Author Topic: Strange hum problem caused by reversed PT primaries?  (Read 5296 times)
Offline JayB
« on: July 26, 2010, 10:16:22 am »
 I couldn't figure out where the hum was coming from. Sounded like 60hz coming through. Looked at everything I could think of. It was pretty bad too. The louder you turned the master, the worse it got. I bypassed the preamp into another power amp, bypassed the preamp and played straight into the power amp. Nothing I did changed it. Finally I looked at the primaries and they we're reversed with the fuse on the return line. I switched them around it's gone? I never encountered that before.
You're going to hell faster than Britney Spears running to a Barber shop
Re: Strange hum problem caused by reversed PT primaries?
« Reply #1 on: July 26, 2010, 12:24:00 pm »
Is there a hum balance cap/ground switch still on the primary side?
Is there any chance that the act of reversing the primaries corrected some other fault? Something like a cold solder joint, poor mechanical connection, excess solder flux, etc?
I can't see how swapping primary leads could make a difference, except in light of a hum balance cap or a different fault.
Offline RicharD
    • Toxic Water
« Reply #2 on: July 26, 2010, 02:41:50 pm »
Seems very odd.  I'm inclined to agree with HBP that there might be another problem.  Grasping at straws, there might be a primary to shield short inside the PT, in which case you need to look at your wall receptacle grounding too because there shoulda been sparks, a tripped breaker, or earth shattering kaboom.  Is it a funky PT with a million leads?  Perhaps a hi resolution picture is in order?
-Richard
Offline JayB
« Reply #3 on: July 26, 2010, 05:45:33 pm »
I have no idea. I can't recreate the problem even after I switched the primaries and it doesn't do it. Checked the wall socket just in case and that's fine.
Just an ordinary fender PT.
