September 15, 2026, 11:04:40 am
Hoffman Amps Forum image Author Topic: DeArmond R15T schem ?  (Read 7266 times)
Offline worth
« on: July 13, 2011, 11:24:51 am »
I'm seeing the volume pots as being 350K , and the treble pot 650K.... correct, or not ?
Offline Tone Junkie
Re: DeArmond R15T schem ?
« Reply #1 on: July 13, 2011, 02:13:05 pm »
yea Ive never seen a schematic that read .35M before but that would be 350k so correct as far as I can tell.
Thanks Bill
« Reply #2 on: July 13, 2011, 02:51:27 pm »
yes, pots are 650K and 350K.
make a 650K use a 1M pot paralleled with a 1M8 resistor.
make a 350K use a 500K pot paralleled with a 1M2 resistor.
--DL
Offline moonbird
« Reply #3 on: July 13, 2011, 03:43:39 pm »
Hi all --
Appears that Mercury Mag DOES supply PT & OTs for the push pull Dearmonds - I am attaching files. No SE OT though  :sad2:. Oh well there are MUCH cheaper options for that  :icon_biggrin:.
Offline worth
« Reply #4 on: July 14, 2011, 07:10:49 am »
The HV secondary is too high on the Toneclone to match the voltages on the schematic, ( if Martins' voltages are correct )... I'm thinking more like 260-275 V.
« Last Edit: July 14, 2011, 07:25:57 am by worth »
« Reply #5 on: July 14, 2011, 07:24:12 am »
It also has the 6.3 @ 5A?   2 - 6V6's = .9A, 3 - 12_ _7's =.9A, so .9A + .9A = 1.8A.
Might be they have their spec sheet's mixed up?
           Brad       :dontknow:
Offline worth
« Reply #6 on: July 14, 2011, 07:28:39 am »
I read that the transformers were beefed up to allow for the use of 6L6s' or 6V6s'.
« Reply #7 on: July 14, 2011, 07:36:58 am »
Yeah but, 2 x 6L6's = 1.8A, so 1.8A + .9A = 2.7A. Still 2.3A extra, almost double in reserve.
            Brad         :dontknow:
