September 15, 2026, 05:52:54 am
Hoffman Amps Forum image Author Topic: Standard spacing on eyelets/turrets?  (Read 6317 times)
« on: July 16, 2011, 08:50:13 am »
Is 3/8" on center enough for 1/8" eyelets?
         Thanks,     Brad     :think1:
Offline Frankenamp
  • What does this button do?
Re: Standard spacing on eyelets/turrets?
« Reply #1 on: July 16, 2011, 10:03:23 am »
I think it should be. If memory serves, Doug uses 9mm (long story) which is a skosh more than 5/8". Should work for most components except the largest PS caps. Check spacing by laying 'em out on a strip of cardboard and measuring. If it is a popular amp Doug may nave a board already drilled. Have Fun!
OOPS! I meant 5/16"  :embarrassed:
« Last Edit: July 16, 2011, 02:20:26 pm by Frankenamp »
This problem calls for a bigger hammer!
« Reply #2 on: July 16, 2011, 12:05:19 pm »
Yes, 3/8"will be fine.  I thonk dougs are on 5/16" centers.
« Reply #3 on: July 16, 2011, 05:52:07 pm »
Thanks guys.
         Brad        :icon_biggrin:
Offline stingray_65
« Reply #4 on: July 17, 2011, 12:51:14 am »
A little off topic,
I wished Doug sold a universal board, something that looks like his drilling template. add lugs where you want em!
Offline andrew_k
« Reply #5 on: July 17, 2011, 11:02:20 pm »
Yes please
« Reply #6 on: July 22, 2011, 01:52:49 pm »
Eyelets would be completely different than lugs because they have a very wide flange.
My board spacings for lugs are
.296875" inch horizontal column spacing (11/64ths)
.19685" vertical spacing between rows.
Really long story somewhere on this forum why I use those spacings
You talking about a generic board with tons of holes everywhere like the drilling template?
If so, would be really expensive because I charge by how long the CNC machine takes to drill all the holes on the pre drilled boards.
I charge $1.00 a minute for CNC time + how many inches long the boards are (raw board material pricing = .62 per linear inch).
I can only stack and drill two boards at a time because the 3/32 carbide CNC drill bits have a very short business end.
They are not really long like a regular drill bit.
If I could stack up 5 boards at a time, it would be much cheaper, but the CNC machine will smoke regular jobber drill bits.
Have to use very high quality carbide bits.
« Last Edit: July 22, 2011, 01:57:51 pm by EL34 »
