September 14, 2026, 12:52:47 pm
Hoffman Amps Forum image Author Topic: Here's something a bit different: A Sock Turlet Board  (Read 15173 times)
Offline LooseChange
    • Fix Your Darn Amps
« on: March 11, 2012, 11:38:27 am »
Working on something new. It will be a rack mount preamp.
I call it a Sock Turlet Board.
Stay tuned. ;-)
Call me Dan
www.fydamps.com
Re: Here's something a bit different: A Sock Turlet Board
« Reply #1 on: March 11, 2012, 12:53:18 pm »
This is Doug's version  :icon_biggrin:
No, your's is a mixed eyelet/turret board
I'm curious to see results
Ciao
Kagliostro
« Last Edit: March 11, 2012, 01:00:41 pm by kagliostro »
Offline daveyajd
« Reply #2 on: March 11, 2012, 01:01:38 pm »
What is the wire used to connect the turrets? I am looking to start a build of some sort and I have seen turrets connected like this on some of the Hoffman project info pages. What type of wire is used and how do you twist it to make it look so nice?
Offline LooseChange
« Reply #3 on: March 11, 2012, 04:14:35 pm »
My board has the sockets facing up.
The wire between the turrets is buss wire. Strip 22ga. solid core is what Doug uses.
Call me Dan
www.fydamps.com
Re: Here's something a bit different: A Sock Turtle Board
« Reply #4 on: March 11, 2012, 07:50:25 pm »
You can't quite see it in the pics posted, but all Doug does is twist them from turret to turret.
I think there are clearer pics of this in Doug's library of tube amps. It's at the top of the main page.
                   Brad     :icon_biggrin:
Offline daveyajd
« Reply #5 on: March 11, 2012, 09:24:20 pm »
Alright thanks. I have some on the way.
« Reply #6 on: March 11, 2012, 10:40:22 pm »
Thats a very neat and clean job*
« Reply #7 on: March 11, 2012, 10:55:16 pm »
I'm sorry but I don't understand you. "I have some on the way"?    :dontknow:
            Brad       :icon_biggrin:
Offline daveyajd
« Reply #8 on: March 11, 2012, 11:00:26 pm »
I just placed an order for some parts, including wire, and they are on the way.
Offline LooseChange
« Reply #9 on: March 12, 2012, 07:09:08 pm »
Wiring this board top and bottom is more of a challenge than I thought.
Call me Dan
www.fydamps.com
« Reply #10 on: March 13, 2012, 04:00:17 am »
Top and bottom ?
are you trying a double face components Turlet Board ? or not ?
I was thinking you want to put the components in the top side and only socket connections on the bottom side  :think1:
My curiosity about this your's new job increases and I/we are waiting for further news about
thanks for sharing this new idea
Kagliostro
Offline LooseChange
« Reply #11 on: March 13, 2012, 05:28:32 am »
Yes, exactly. Components on top and socket wiring under. I'm never a fan of bottom wirin g. I like to see where everything goes. But it looks pretty cool.
Call me Dan
www.fydamps.com
« Reply #12 on: March 13, 2012, 12:27:11 pm »
Looks good LC, the only concern I see is if you need to change or alter a component after installing. That would be a bitch to say the least. Maybe solder the bottom of the turret and if your stand-offs are tall enough the resistor or cap would fall away/off. Then you'd have to feed the new one down and up back into the turrets w/ some long nose needle nose pliers maybe? Then re-solder, cut & trim.
Is this a brand new build or something you've already worked out before?
Offline Fresh_Start
  • noob de Lux
« Reply #13 on: March 13, 2012, 01:47:34 pm »
Rack mount explains it... I was really confused there.  Looks nice and a great idea for that application.
I've combined a few eyelets on a turret board before.  It worked out OK but was a little confusing for me until I made the printed mask with different colors for turrets vs. eyelets.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #14 on: March 13, 2012, 02:10:05 pm »
Are you thinking about adding an insulator board underneath the main board?
I dunno exactly how you'd do it, but it would seem handy to prevent underboard wiring from falling away if you have to unsolder/swap parts.
Or... You do a little less-neat wiring, a la Fender, and have a significant length of the wire in inserted through the eyelet, then bent over. After sldering, and when trying to remove a component lead, the extra little hook in the wire end helps prevent it from falling out.
« Reply #15 on: March 13, 2012, 02:17:16 pm »
Looks Very Nice and practical :thumbsup:
Kagliostro
« Reply #16 on: March 13, 2012, 02:25:22 pm »
Hi LC, I have had little to do with rack mount stuff but the ones i have used have a removable top and bottom panel and the kit comes with metal rails, so could your board, transformers etc. be suspended rather than fixed to the bottom panel? Looks Good  :thumbsup:
« Reply #17 on: March 13, 2012, 02:46:23 pm »
I think he's using a standard Hammond steel chassis and will add rack ears to it?
Looks real good to me LC!
                        Brad      :icon_biggrin:
« Last Edit: March 13, 2012, 02:51:05 pm by Willabe »
« Reply #18 on: March 13, 2012, 02:55:27 pm »
I like it too but it's different from what I was thinking. Not sure why the turretts were mounted the way they are but it doesn't matter.
« Reply #19 on: March 13, 2012, 03:01:40 pm »
I think it's to lift the 1 end of the R's above the ground buss?
                       Brad
Offline LooseChange
« Reply #20 on: March 13, 2012, 03:08:24 pm »
Yes, rack ears. BUT... Can't find anything that fits. They need to be no more than 1" wide.
Yup.
Call me Dan
www.fydamps.com
« Reply #21 on: March 13, 2012, 03:15:19 pm »
Why only 1"? The chassis deeper than that.
                      Brad     :icon_biggrin:
Offline LooseChange
« Reply #22 on: March 13, 2012, 03:19:13 pm »
The chassis is 17" wide. That leaves only 1" each side for the rack ears.
Call me Dan
www.fydamps.com
« Reply #23 on: March 13, 2012, 03:38:47 pm »
Ohh, it's the width. I was thinking the hight of the face.
« Reply #24 on: March 13, 2012, 10:05:45 pm »
I have a good friend who has a 24 track 2" tape full studio with all the old out board gear and the old mics.
He buys old studio out board rack gear and often has to re rack them. He does not like Hammonds rack chassis, from working with them, but loves Par-Metal rack chassis.
Here's the link to them;
http://www.par-metal.com/index.php
                              Brad       :icon_biggrin:
« Reply #25 on: March 13, 2012, 10:22:47 pm »
Sure they can. I have a pair of mic preamps built exactly the way you describe, with a similar, but different, handwired board.
Do you have a link for the kits you're talking about?
« Reply #26 on: March 14, 2012, 02:40:40 am »
Hi HBP, This is my local Electronics store here australia http://www.jaycar.com.au/index.asp the 2 and 3u have i think four of these metal rails
« Reply #27 on: March 15, 2012, 07:01:44 am »
I did a bunch of my early amps with sockets on the board.
Starting somewhere around 1993
Here's a few really old pics
Plus several of my rack projects including a power amp
It's a good way to go and fun to build
Offline LooseChange
« Reply #28 on: March 15, 2012, 07:05:19 am »
That's awesome Doug!  Wish I saw this before I built mine. :-)
Call me Dan
www.fydamps.com
« Reply #29 on: March 15, 2012, 07:12:19 am »
LooseChange job is one of the possible variations on the TCB (Turret Circuit Board) planned byDoug in the late '93
Two different but similar way to obtain a nice and practical Circuit Board
there is always something to learn from others
again thanks for sharing
Kagliostro
« Reply #30 on: March 15, 2012, 11:41:27 am »
All that and more awaits on the library pages.  :icon_biggrin:
All that stuff is in the Hoffmanamps section showing stuff I built way back when
« Last Edit: March 15, 2012, 11:53:33 am by EL34 »
