August 29, 2026, 12:17:52 pm
Hoffman Amps Forum image Author Topic: EZ81 in classic Fender amps  (Read 5446 times)
Offline Leevi
    • Rikstone
« on: March 29, 2012, 11:58:04 am »
Has someone tried EZ81 tube rectifiers in the famous  Fender amps
like Champ, Princeton, Tweed deluxe etc.
Do you think that would change the sound?
/Leevi
Re: EZ81 in classic Fender amps
« Reply #1 on: March 29, 2012, 05:35:07 pm »
One question on my mind, what is the effect of using 5 v on the filaments rather than 6.3 volts.
It won't heat it properly and won't work right, if at all or maybe even kill the tube.
Offline Leevi
    • Rikstone
« Reply #2 on: March 29, 2012, 11:43:51 pm »
Code: [Select]
A quick check of specs for the EZ81, indicates filament voltage is 6.3 v not 5v.That's why I'm was asking it. I have a PT where is not 5V secondary.
/Leevi
« Reply #3 on: March 30, 2012, 01:04:05 am »
I think that if the EZ81 has the voltage and current rating that can be compared with the tube you use it to substitute, the principal difference to consider is the resistance of the tube and so the drop of voltage it will induce on B+
As far as I can know, the different sag effect that a different rectifier can induce in SE amp will not be of great concern
in an SE amp you can also try to use SS rectify and that will give not very much difference IMHO
Kagliostro
Offline Leevi
    • Rikstone
« Reply #4 on: March 30, 2012, 10:54:23 am »
Yes, SS rectifier is of course an option especially if you are aiming to a clean sound.
/Leevi
