September 16, 2026, 12:04:34 am
Hoffman Amps Forum image Author Topic: Are this small transformers usable for a shifting vibrato unit ?  (Read 4999 times)
« on: November 28, 2012, 07:43:57 am »
I recovered 5 pulse transformers like this from a tube military telephone equipment
Firstly I've think they are of no use for our purposes
Than I remembered the shifting vibrato unit build by Sluckey
There is a way to test if they are suitable ?
EDIT: does someone knows what mean the labeled data
on primary 132 T. - secondary 79 T. - tertiary 58 T. ? Mean Turns ?
« Last Edit: November 28, 2012, 09:08:48 am by kagliostro »
Re: Are this small transformers usable for a shifting vibrato unit ?
« Reply #1 on: November 28, 2012, 04:44:12 pm »
No, I don't think they can be used that way :sad2:
All started because I was remembering badly the name of the kind of transformer
I remembered pulse transformer instead of saturating transformer
http://www.el34world.com/Forum/index.php?topic=10681.0
However if someone knows if there is an use that can be done of those transformers he is welcome .........
« Reply #2 on: November 29, 2012, 07:01:45 pm »
Yes, the "T" means Turns.
Impedances are not given directly, but you can figure the turns ratio between any two windings and calculate the impedance ratio.
Unfortunately, I don't really know whether they can be used in place of a saturable reactor, but my guess is no. Saturable reactors are very specialized devices.
« Reply #3 on: November 30, 2012, 07:10:50 pm »
Thanks HBP
This small transformers is to be added to the pile of non usable I recovered from other military equipment :smiley:
« Last Edit: November 05, 2017, 05:11:46 pm by kagliostro »
« Reply #4 on: November 30, 2012, 07:24:52 pm »
Here's an example of the type circuit that pulse transformer might be used in. Your transformer would be used in a smaller blocking oscillator circuit than this, but the operation would be similar. I really can't think of any audio applications.
« Reply #5 on: November 30, 2012, 07:41:06 pm »
... Your transformer would be used in a smaller blocking oscillator circuit than this, but the operation would be similar. I really can't think of any audio applications.
Translation: the oscillator works at frequencies way above the audio range, so you won't be building a trem oscillator with it.
« Reply #6 on: December 01, 2012, 01:55:44 am »
Many Thanks Sluckey & HotBluePlates
Now, at least, I know what it is, which is no small thing !
