July 25, 2026, 10:48:15 pm
Hoffman Amps Forum image Author Topic: 3D Printer build  (Read 24203 times)
3D Printer build
« on: March 10, 2013, 04:32:49 pm »
I built a plastic extruder and bolted it to my CNC machine as a test.
The test came out great and so I decided to go ahead and build a dedicated 3D printer
Here's a video of the extruder test creating a small cup object
First print from my extruder - Part 2
And that test object looked like this when it was done
And here's my extruder post on CNC zone
http://www.cnczone.com/forums/general_3d_printer_discussion/174081-extruder_build_my_cnc_machine.html
I am posting the info on my printer build here
http://www.cnczone.com/forums/general_3d_printer_discussion/175337-new_printer_build.html#post1247112
It easier just to post in one place
Go to the link above to see pics and info
Here's a youtube movie of the X axis moving for the first time
http://youtu.be/INTkTemk-4k
My youtube channel has video of my progress
http://www.youtube.com/playlist?list=PL0CC8AA3BFAF51042
« Last Edit: March 10, 2013, 04:37:44 pm by EL34 »
Re: 3D Printer build
« Reply #1 on: March 10, 2013, 07:59:29 pm »
Doug,
THe latest issue of Make magazine has a big feature on 3d printing.  I have not read it yet, but if it is like their normal fare, it should be excellent.  You may want to pick it up for reference?(Plus all the other COOL stuff!)  Those things are so neat!
« Reply #2 on: March 12, 2013, 06:05:28 pm »
I installed the UHMW-PE bearing material in the bearing blocks and got the X and Z axis up and running
The X axis has a spring under the bed that keeps the belt tensioned
The Z axis has two shafts with two GT2 pulleys and belts
The bottom shaft is the drive shaft and the top shaft just free wheels
I can slide the top shaft up or down to put tension on the belts
Here's a video of both axis running some G code
3D Printer build - Testing X an Z axis
Offline pullshocks
« Reply #3 on: March 14, 2013, 12:52:13 am »
I read an article recently about the capabilities of 3d printers that really opened my eyes.  Prior, I had only seen a few 3d printed items, and the quality did not impress me.  This article showed some very impressive firearm parts made on a $1300 unit.  f you can make all the parts for a functional gun with one, it seems like the only limit is your imagination and CAD skills....
« Reply #4 on: March 14, 2013, 05:45:01 am »
« Reply #5 on: March 14, 2013, 06:12:30 am »
As far as the quality goes, there's a couple different methods
The plastic extruder can get very good results, but the expensive machine use lasers
The powders/resins and laser methods will trickle down to diy builds eventually
yeah,  I had seen a couple youtube vids a while ago
This guy on the Alex Jones show created a downloadable 30 round mag
Breaking Gamechanger: Printable Gun Magazines
And here is the receiver in action
3D Printed Assault Rifle Makes It 6 Shots Before Breaking
« Last Edit: March 14, 2013, 06:15:37 am by EL34 »
« Reply #6 on: March 14, 2013, 05:23:26 pm »
Offline SILVERGUN
« Reply #7 on: March 14, 2013, 08:41:44 pm »
« Last Edit: March 14, 2013, 08:45:07 pm by SILVERGUN »
« Reply #8 on: March 15, 2013, 05:03:23 am »
The video was useless but I get the big picture
3D printing is in it's infancy
Sort of like DIY CNC machines were several years ago
Offline SILVERGUN
« Reply #9 on: March 15, 2013, 09:16:15 am »
Wasn't sure if you'd seen the 3D printed guitar application,,,,,,and just threw the video on there as a reference
The back page of my last Guitar magazine was all about a 3D printed guitar and that was the first I had seen of it......
I wanted the guitar pic to be the focus of my post,,,but because it was an attachment, it came after the pasted video url
I'm thinking about the possible use for custom faceplates.....or head cabinet fronts to add to your store....?....maybe
« Reply #10 on: March 15, 2013, 09:36:06 am »
The DIY printer technology is not able to do anything like a smooth faceplate
This little plastic cup 30mm in diameter took 1.5 hours and has a weaved texture
That guitar probably took 30 hours, just guessing, and that guy is using a much better technology that a DIY home printer
« Reply #11 on: March 16, 2013, 02:57:17 am »
« Reply #12 on: March 16, 2013, 08:39:13 am »
I just ran the little black cup code on the new printer
The same cup shown at the top of this thread
The printer does not have an extruder on it yet but I wanted to see how fast it could complete that same little black cup that I made on my CNC machine
The CNC machine took over 1.5 hours to complete the cup
The new printer finished the cup code in 32 minutes
That's a huge speed increase because I built the 3D printer moving parts very light
I think I can crank up the motors even faster and maybe get the print time on the cup down to 25 minutes
« Reply #13 on: March 20, 2013, 03:38:17 pm »
I spent a couple days getting everything square, bolting down the electronics and got the A axis extruder almost done.
Here's a video of the 3D printer running the same cup code I did on my CNC machine extruder test.
The 3D printer is finishing the same code in 25 minutes that my CNC machine did in 1 hour 40 minutes
It hard to see just how fast the X and Y axis are in this video but if you lay your hand on the X axis bed, it feels like an intense vibration as it rips the code off in Mach3
I should have the extruder finished in the next couple days and be ready to print the cup code to compare it to what my CNC machine printed
http://youtu.be/vaPC09YgCWA
« Reply #14 on: March 22, 2013, 03:08:34 pm »
Yay, first run on my new printer just finished
Got to dial in some settings in slic3r, but no major problems on the first run.
From what I have read, the spider web strings and small blobs may just be a matter of more retraction on extruder moves
Any suggestions are welcome for figuring out how to dial that in
Here's a youtube video of the first run on my new printer
www.youtube.com/watch?v=_FhFPXJW3WE
« Last Edit: March 22, 2013, 03:10:43 pm by EL34 »
« Reply #15 on: March 22, 2013, 03:46:10 pm »
What are you planning on making with it?
Bike light parts?
            Brad     :think1:
« Reply #16 on: March 22, 2013, 04:29:12 pm »
I could make thousands of things
prototype parts to see how they look, etc
It's like a computer or a power tool
What you do with it is up to you and your imagination?
If you want to see thousands of things that other people make, check out thingiverse
and you can download all the code to make the things
http://www.thingiverse.com/
« Last Edit: March 22, 2013, 04:36:47 pm by EL34 »
« Reply #17 on: March 22, 2013, 05:20:34 pm »
OK, looks like the skies the limit.
              Brad     :icon_biggrin:
« Reply #18 on: March 28, 2013, 07:56:16 pm »
I finally had some time today to take a bunch of detailed pictures of the 3D printer
I have added several things to the printer since I last posted here
This page on my web site has lots of pics and info
http://www.el34world.com/Misc/Cnc/CNC21.htm
I printed this cool twisted shape the other day and it came out great.
I thought I would extrude some plastic on some copper clad board and then etch it to see how it does making a PC board
Of course it would then have to be drilled, but it sounds like a fun experiment
My machine can extrude at .1 mm so it should be able to make some fine traces
Here's an small image of the printer
Go to the link above to see large detailed images
« Last Edit: March 28, 2013, 08:12:06 pm by EL34 »
« Reply #19 on: April 29, 2013, 02:12:44 pm »
I changed out the nozzle on my printer
The brass acorn nut was dragging material around and there was not enough brass on the end to be able to machine it down to a finer point
I purchased a makerbot style .4 mm nozzle and the prints are much cleaner now
I printed this skull in 4 parts and glued them together
I added some LED's behind the eye sockets just for fun
The lid comes off just above the eyebrows for access to the electronics
I added a few pics of some of the prints here
3D prints page
« Reply #20 on: May 11, 2013, 04:47:51 am »
That's remarkable!!
Just think ............... with that machine (at least in theory) one could reproduce copies of small famous statues like the one Degas did.
« Reply #21 on: May 11, 2013, 05:07:33 am »
yeah and this is the home version that extrudes plastic
The really nice ones use lasers and different liquids or powders
You should se what those can do, it's amazing
here's a sample of some of the amazing things 3D printers can do
3D Printed Snake, Gears, Art, Wrench and more..
Offline Geezer
« Reply #22 on: May 11, 2013, 07:39:27 am »
The Feds are getting interested and want to regulate 3D printers, telling you what you can (or more importantly CANNOT) print or file share online.
http://www.guardian.co.uk/technology/2013/may/09/3d-printed-guns-plans-state-department
« Reply #23 on: May 11, 2013, 07:46:14 am »
Yeah, I have been following that
It's because people have been printing guns
It's just another thing the government will fail at
