September 18, 2026, 06:29:23 pm
Hoffman Amps Forum image Author Topic: Adding a 2nd Master volume to a Peavey VTM  (Read 9306 times)
Offline JustMike
« on: August 29, 2013, 09:52:11 am »
 I think it's pretty simple :dontknow: Can I just put it pre phase inverter?
http://dl.dropbox.com/u/20590817/peavey_vtm_60_120.pdf
 It looks like v3 is an fx loop buffer?
 What I'm trying to accomplish is have a post fx loop MV so I can plug in an external preamp.
I'm learning...
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
Re: Adding a 2nd Master volume to a Peavey VTM
« Reply #1 on: August 29, 2013, 10:02:37 am »
are you wanting a level control for the FX loop or are you wanting another Master Volume ? for the FX Loop level control use a 1meg pot attached to pin 5(fx return) and pin 8(gnd) of J3
Offline JustMike
« Reply #2 on: August 29, 2013, 10:14:00 am »
 I want a master volume after the FX loop.
I'm learning...
Offline jerrydyer
  • Make it one of a kind
« Reply #3 on: August 29, 2013, 01:13:37 pm »
I like those amps, interesting story behind those. Mike are you here in orange county CA and do you rent rehearsal space from Shaul at Backline?
Offline jerrydyer
« Reply #4 on: August 29, 2013, 01:17:49 pm »
do you just need to attenuate there in general? what effects units? good ones have adjustable parameters inside there.  I see a spot another 1 meg pot could work (in theory)  lol   ..
Offline JustMike
« Reply #5 on: August 29, 2013, 01:45:59 pm »
 No, I'm in Orange county FL! But I was in Hollywood Ca. back in '91 or so and I can't remember the name of the rehearsal space I was in, but lots of bands were there.
 So...about the Master volume..?.. It looks like this thing has a tube buffered fx loop after the master. Am I right?
I'm learning...
Offline rzenc
  • TUBES RULE
« Reply #6 on: August 29, 2013, 04:51:56 pm »
I think you might be able to install a post PI master volume to it. Is this your idea?
Best Regards
R.
« Reply #7 on: August 29, 2013, 05:20:22 pm »
              Brad     :icon_biggrin:
Offline rzenc
  • TUBES RULE
« Reply #8 on: August 29, 2013, 07:12:01 pm »
              Brad     :icon_biggrin:
It's after  :laugh:
Best Regards
R.
« Reply #9 on: August 29, 2013, 07:15:50 pm »
It's after  :laugh:
True.    :laugh:
                  Brad      :icon_biggrin:
Offline JustMike
« Reply #10 on: August 30, 2013, 06:48:00 am »
 Can it work between J3 & C13, after the presence control and before the PI?
I'm learning...
Offline rzenc
  • TUBES RULE
« Reply #11 on: August 30, 2013, 10:28:03 am »
I think not...but that's my opinion.
I think not. See signal flow drawing below, so that you will understand how your amp preamp signal goes to your FX loop and returns from it. Also, FX loop is passive, not active buffered. A buffered FX loop would need a tube to drive (generally a CF design) the sending jack and receive the returning jack also into tube stage, which is not the case here...
IMHO, I'd do it by replacing R11 with 500KA pot so that your master volume would prior to a gain stage. It will also work for the amp pre as well (turn it full on and your amp will be back to stock specs).
Another option would be a post PI master volume, which would allow you to use V3 as a gain stage to drive the P.I. harder and generate more distortion. Your stand alone preamp should have a output level control, this way you can blend it's output and P.I. driving signal. Just replace R24 & R25 with a dual ganged 250KA pot. Turn it full on and your amp will be back to stock specs). Also search for LARMAR PPIMV for more instructions on how to do it right.
See drawings below...
Hope this helps,
Best Regards
R.
Offline JustMike
« Reply #12 on: August 30, 2013, 01:14:46 pm »
Hmmm...it's obvious when you point it out that there is no buffering whatsoever for the fx loop. It's about as primitive as it gets, eh?
 I'm going with your first suggestion at R11 as my preamp has no master volume on ch. 2 and I love the way it sounds when it's cranked.
 Many Thanks.
I'm learning...
Offline JustMike
« Reply #13 on: August 31, 2013, 09:33:14 am »
 I wired in a 500kA pot at R11 as suggested and I've got 2 issues. The sound is thin now and the pot is noisy when I rotate it.
 I wired it >input from J7 to pin 3 of pot, Output (wiper) to pin 2 of V3a and pin 1 of pot to gnd.
 Might it work better if I place it before C14 ( the coupling cap immediately after the fx return)?
I'm learning...
Offline rzenc
  • TUBES RULE
« Reply #14 on: August 31, 2013, 10:03:55 am »
The sound is thin
Does it behaves like this even when you rotate to max?
Might be rusty. Spray potentiometer lubricant and give it some full turns back and forth.
Hope this helps.
Best Regards
R.
Offline JustMike
« Reply #15 on: August 31, 2013, 10:17:57 am »
 I moved it to the spot I mentioned above and it appears to be working the way it should. I think having it before the coupling cap is what made the noise disappear. Also sounds normal now ( no thin-ness).
I'm learning...
Offline rzenc
  • TUBES RULE
« Reply #16 on: September 01, 2013, 10:50:10 am »
sounds normal now
Nice!
Best Regards
R.
