September 16, 2026, 02:56:17 am
Hoffman Amps Forum image Author Topic: Grounding ? for a AB763 Reverb and Output jacks  (Read 4193 times)
Offline x44d80
« on: January 06, 2014, 11:28:33 am »
Newbie here.  On the AB763 layout, would it cause a ground loop by tying a buss wire from the reverb and output jacks all the way back to the power transformer? I see on the layout that the reverb transformer's black wire ties to the reverb jack. Then I have the rest of the RCA jacks and the output jacks tied together with a buss wire, but then I continued it all the way to the Power Transformer.  Is this wrong? Thanks, Brent.
Re: Grounding ? for a AB763 Reverb and Output jacks
« Reply #1 on: January 06, 2014, 11:44:38 am »
Welcome x44d80!
I would say yes if the jacks are not insolated/isolated. You only need to wire them to a ground buss wire if the jacks are not grounded to the chassis.
Read this it might help you.
             Brad
« Last Edit: January 06, 2014, 11:47:51 am by Willabe »
Offline x44d80
« Reply #2 on: January 06, 2014, 12:52:59 pm »
Thanks Brad and thank you for the link. Brent
