July 28, 2026, 06:50:50 pm
Hoffman Amps Forum image Author Topic: Marshall Popular 1930  (Read 26933 times)
Offline SleepLess
« on: March 18, 2014, 04:12:27 pm »
Hi guys.
A pretty darn interesting amp arrived on my bench, I thought you'd like to see it, it's quite unusual... Pics:
So it had several issues: bad V3 connection, that's solved. Bad hiss that was coming from the wiring placement, that's solved (I remember that the 1974 18w is DARN tricky with wire placement so same thing here...). The tremolo wasn't working and still isn't. I tried to take measures but pointing the red probe on V1 pins 1 and 2 makes SUCH a crackling noise it's crazy!
If you guys have any tips...
Re: Marshall Popular 1930
« Reply #1 on: March 18, 2014, 05:47:38 pm »
... The tremolo wasn't working and still isn't. ...
The schematic shows the foot switch must be plugged in the jack and shorting the hot to ground to enable the trem oscillator. I'd try bridging those contacts with a jumper wire first.
If that doesn't work, you have 2 trimpots from the 12AX7 cathodes to ground. I bet one of them (maybe the 5kΩ?) is the panel Trem Depth control. The other is probably that preset trimpot shown in your pictues with what looks like a black wire to the + side of the 25uF cap. I might try bridging a new 25uF cap across the existing one (to rule out a dried up bypass cap), then tweaking that trimpot a bit to see if it brings back trem strength.
But I'm guessing lack of a footswitch is gonna be your culprit.
Offline SleepLess
« Reply #2 on: March 18, 2014, 05:51:28 pm »
Hi and thanks! I have a footswitch! It's not the original, it's the footswitch I use for my Tremolux 5E9A. Even with the footswitch, still no trem... I'll do what you say!
« Last Edit: March 19, 2014, 09:06:30 am by SleepLess »
Offline SleepLess
« Reply #3 on: March 19, 2014, 10:06:00 am »
Hi there!
I have checked the 25uF cap and it's good. The trem jack was wired badly: it was grounded on the - side of the 25uF cap but also on the jack ground tab.
It's still not working though and turning the trimpot doesn't change a thing... I guess the next step is to check the three .01uF ceramic disks, right?
« Reply #4 on: March 19, 2014, 12:47:15 pm »
The schematic shows that the trem oscillator shares cathode resistance with the 12AX7 gain stage. So that tells you if the oscillator is running, you should get some amount of trem.
Before suspecting a malfunctioning part, I recommend seeing if the existing parts are hooked up/functioning correctly. In order to oscillate the trem oscillator needs 3 series caps from plate to grid, and 3 resistors to ground (1 after each cap).
I mentioned the footswitch before; I would follow the wiring from the footswitch jack back to see if it connects to a resistor (it should, according to the schematic). If you don't have continuity from that resistor to ground (through the footswitch), the oscillator can't oscillate.
The trem Speed pot is in series with one of the resistors in order to vary trem speed. You might check that it has good connection to ground at one end.
To ensure oscillation, the 12AX7 needs to have good gain. The 25uF cap is partly to help with this, which is why I suggested checking it. You can also try swapping with a known-strong tube.
There is a 0.68uF cap from the trem oscillator plate to ground. I'm thinking the purpose of that is to shunt all signal higher than trem-frequency to ground, mainly to minimize the effect of distortion in the oscillator tube. If that cap were leaky, it would also shunt your trem signal to ground. You could try unsoldering one end to see if trem is restored.
You can try swapping the caps from plate to grid, but you might want to try one at a time, as you probably will not have a good way to determine which is the leaky cap.
You'll want to be monitoring a.c. volts on the oscillator plate to see the trem signal, in case there's something preventing you from hearing it. Depending on your meter's capabilities, you will probably have to do this by measuring d.c. volts at the plate and watching for slow fluctuation (set your amp's Speed control to minimum to help with this).
Offline SleepLess
« Reply #5 on: March 19, 2014, 01:21:20 pm »
I have continuity there.
Done, it's there.
Done, doesn't change a thing...
This cap still tests at 0.66uF with my Capacity tester.
Need to do that now... The wiring seems to be good so that's the only solution left for now.
Thanks HotBlue!
« Reply #6 on: March 19, 2014, 01:25:58 pm »
Sounds like a plan!
Offline TubeGeek
    • Glacier Amps
« Reply #7 on: March 19, 2014, 01:31:38 pm »
Nice amp! :m11  Don't see these too often.
Offline SleepLess
« Reply #8 on: March 20, 2014, 03:46:06 pm »
Hi.
So, I have changed all the ceramic disks, one by one, from the plate to the grid and still no tremolo coming out, I replaced them anyway because they were out of specs, they were supposed to be .01uF and were about 40% lower than that, in the .0065uF ballpark...
I'd like to make sure that the jack is wired properly now if you can help me. As you can see in the third picture I posted above, the jack had the shield wire going to its ground and the live wire to the sleeve, not the tip. So I rewired it, got rid of the ground shield connection on taht end and wired the signal to the tip. On the other side of the wire, teh shield goes to the - side of the 25uF cap and the signal goes to the 680K resistor (blue-grey-yellow). I think I was right to rewire the jack connections, wasn't I? I mean, if the ground shield is used on both ends of the wire, the signal doesn't come through, right?
Another thing I've noticed is that when I touch V1 pin 6 with my MM + probe, there's a loud noise and the tremolo effect seems to turn on for about a second or two and then vanishes. If that can lead you on a nice track for a hunch, please let me know. This Tremolo is giving me a hard time and I can't find any good schematic and most of all layout out there.
« Reply #9 on: March 20, 2014, 04:42:38 pm »
I dont know Teles from shinola about trem circuits, but I did want to throw this out.  In my Marshall book, the schematic shows a notation next to the 1K trim pot below the 5K trim pot.  It says 1K.  I don't know if this is the preferred trim setting or what.  These schematics are supposedly the most recent pulled from the factory.  Again, I don't know if this has any bearing, but wanted to let you know since you are still looking for a solution.
Good luck!
Offline SleepLess
« Reply #10 on: March 20, 2014, 04:45:00 pm »
Thanks Jim!
I did what HotBlue requested (I had forgotten about that!) and lifted one leg of the 0.068uF cap: the tremolo is back! So does it mean I need to replace it? I have 0.68uF in stock, I don't think I have any 0.068uF...  :BangHead:
Offline drew
« Reply #11 on: March 20, 2014, 05:44:50 pm »
Doesn't the schematic say it is a .68?
Also, what are the cabinet dimensions?  I'm curious if they used the same box for these as for the 18 watters.  Would also be interested in seeing a few more pix, if you took any beside the ones above.
« Reply #12 on: March 20, 2014, 06:17:27 pm »
Yes. It means the 3 caps already replaced may have been okay, and just the 0.68uF was leaking (which would shunt the trem signal to ground).
I also read the schematic as 0.68uF, the value you have on hand.
You looked at the schematic I linked, right? That shows 0.005uF caps, not 0.01uF, meaning your measured right where they should.
That said, you might replace them because you want slower trem, but that's a different matter.
Offline SleepLess
« Reply #13 on: March 21, 2014, 07:04:01 am »
HI.
Yes, I read the schematioc you gave HotBlue but it doesn't correspond to the reality of the amp I have here and to others I have found on the web. The cap is original and says 68000pF and 400V, just like on this other 1930:
So I guess the schematic has it wrong... But if I replace it with a .68uF what will happen?
As for the ceramic disks, same thing. The schematic you gave says .005uF but the originals I have and I have found say .01uF... So you mean that installing .005uF will make the tremolo faster than with .01uF?
« Reply #14 on: March 21, 2014, 07:40:09 am »
HI.
Yes, I read the schematioc you gave HotBlue but it doesn't correspond to the reality of the amp I have here and to others I have found on the web. The cap is original and says 68000pF and 400V, just like on this other 1930: So I guess the schematic has it wrong... But if I replace it with a .68uF what will happen?
I see...
Swap with the 0.68uF to see what happens. I'm guessing you won't hear any difference. Maybe it's a typo or maybe Marshall figured out they didn't need that-big a cap.
Gotcha. They say "10k" instead of "5k"? If so, yeah, they're 0.01uF.
The trem has 3 RC circuits running from plate to grid; each is a seires cap and a resistor to ground. Each section has a time constant proportional to R*C. If you make any (or all) of those RC sections with larger-value R or C, the RC product is bigger, the time constant is longer, and oscillation speed goes down. That equals slower trem.
The Speed control for all trem circuits changes one of the R's of the RC sections to control trem speed.
So if the caps aged upward to 0.005uF (from 0.01uF), then the trem would have sped up. If you want to slow the trem down beyond what it will do at its slowest setting, you should make the caps bigger (and maybe the R's bigger). Eventually, you will hit a point where the tube doesn't have enough gain at a low enough frequency to keep going; there are other tricks that can help deal with that if you run into it.
Offline SleepLess
« Reply #15 on: March 21, 2014, 08:14:03 am »
Thanks for your input HotBlue!
Damn it, it's still not working even with a new cap... I replaced the .068uF cap with a .1uF (I thought it'd be closer to the original .068uF than a .68uF cap) and it's still not working. The tremolo works as soon as I lift one of the caps' legs and remains on even when I want to turn it off with the pedal. As soon as I solder the cap in place, the tremolo goes away.
What can it be now...?
« Reply #16 on: March 21, 2014, 08:34:39 am »
Then just leave that cap out. I don't know why it won't work with a good new cap, but works when it's out of circuit. You could figure out that mystery, or enjoy it working now.  :laugh:
About the discrepancy between schematic & real values: I found out through an angry customer that this happens more than you'd think. I installed a Hoffman 5F6-A board into a reissue Bassman chassis for a vintage amp aficionado, who was seriously pissed when it arrived with the 0.022uF, 0.022uF, 250pF cap setup shown on the schematic. Apparently, Fender also shipped them with 0.1uF, 0.047uF, 250pF and 0.1uF, 0.022uF, 250pF setups, and the latter was the most common (according to the guy). He wanted it with the setup not shown on any Fender schematic which he claimed was the most likely circuit arrangement.
And of course, Marshall copied the 0.022uF, 0.022uF, 250pF setup from the schematic, which apparently was the least-common circuit arrangement...
Offline SleepLess
« Reply #17 on: March 21, 2014, 08:37:35 am »
LOL... Some customers think they know better, I've seen that too! Of course 99% don't...
I need to find a solution anyway because I can't leave it as is, I can't switch the tremolo OFF, it's always working! I can only turn it off by turning the intensity pot to 0 but the owner wants to be able to use it on stage so he'll need to turn it off with a pedal...
« Last Edit: March 21, 2014, 08:59:20 am by SleepLess »
« Reply #18 on: March 21, 2014, 09:01:37 am »
... I can't switch the tremolo OFF, it's always working!
Well, you did change the footswitch jack wiring... Maybe it was correct to begin with?
Offline SleepLess
« Reply #19 on: March 21, 2014, 09:02:33 am »
Nope, I wired it back to the original positions and it's not working either...  :BangHead:
Offline SleepLess
« Reply #20 on: March 21, 2014, 09:50:59 am »
I've seen on other Populars that there's a 470ohms resistor between V1 pin 7 and the first ceramic disk, like this, on this earlier 68 or 69 model (plexi faceplate), mine is 72 or 73:
https://plus.google.com/photos/116415517934384645566/albums/5527283465662015265/5527290791559723938?banner=pwa&pid=5527290791559723938&oid=116415517934384645566
Any idea what that does?
« Reply #21 on: March 21, 2014, 10:06:28 am »
Totally disconnect the shielded cable for the footswitch. Does that make it stop?
Offline SleepLess
« Reply #22 on: March 21, 2014, 10:20:46 am »
Hi Sluckey!
Now it's working... Shield is soldered on both ends and the footswitch works. The amp is now 80% functional. The only flaw left is that the tremolo is still too fast even with .01uF caps and it's also damn noisy... It's really unbearable when you're not playing... I'll try and find a 7025 V1 to check that. I have turned the trimpot back and forth and at minimum value the tremolo doesn't work anymore.
And of course when I solder the .068uF cap back in the tremolo still quits working, which isn't normal...
« Reply #23 on: March 21, 2014, 10:42:08 am »
That cap is used to smooth the LFO signal and also filter out higher frequency noise/hash that may be present. But it also reduces the amplitude of the LFO signal. It's a significant amplitude reduction, especially on the faster speeds. On the few trem circuits I've built lately I have always reduced the value of that cap. Why don't you try a .01µF. If that works, then increase to .022 and/or .047. Maybe one of those values will give you a good compromise for a strong trem with little noise.
That particular tremolo circuit is very similar to the circuit in the 1974 18 watt amp. It is very finicky and prone to noise, pops, and other undesirable effects. Gotta remember, these amps are Marshall's cheap bottom feeder line.    :icon_biggrin:
Offline SleepLess
« Reply #24 on: March 21, 2014, 10:46:03 am »
Yeah, I remember losing a lot of time solving tremolo issues on the 1974s... I have already tried a .1uF cap there Sluckey and it also cut off the tremolo effect. Something's wrong there, I currently need to have nothing there or the effect goes away..
« Reply #25 on: March 21, 2014, 10:49:01 am »
Well, that's even bigger. I was suggesting use a smaller cap. Start with .01µF. The 1974 uses a .05 for that cap.
« Last Edit: March 21, 2014, 10:51:05 am by sluckey »
Offline SleepLess
« Reply #26 on: March 21, 2014, 11:10:54 am »
Right, I have just soldered a .047uF cap. The tremolo isn't working anymore, I just get very loud pops past 5 on the intensity pot... Once one leg lift up, the tremolo comes back.
« Reply #27 on: March 21, 2014, 11:53:09 am »
Try a .01? maybe something even smaller, like a .002. This is where it's so nice to have a cap substitution box!
« Reply #28 on: March 21, 2014, 12:22:15 pm »
I haven't seen any mention of swapping the tube. Grab a handful of 12AX7s and try'em all. Hopefully you'll find one that works.
Offline SleepLess
« Reply #29 on: March 21, 2014, 12:33:07 pm »
I have Slucky, I have. That's always the first thing I check with tube amps... I have tried 5 different 12AX7s. The worst of them all are JJ. Jeez these tubes ARE noisy!!! I have settled down on an old Ei 12AX7 that is a lot quieter than all the others. The tremolo is a tad weaker with it but at least the amp hum is tolerable.
I have also tried a 0.022uF cap instead of the 0.068uF cap. Tremolo doesn't work with it either!
« Reply #30 on: March 21, 2014, 03:05:09 pm »
... The only flaw left is that the tremolo is ... damn noisy... It's really unbearable when you're not playing...
There's something you're not realizing regarding this trem circuit. As Sluckey mentioned, the cap to ground will help reduce noise somewhat, but the pumping when you're not playing is probably normal.
It has to do with taking a relatively small trem signal and injecting it at a preamp stage. Leo Fender got a patent on a trem circuit for the 1955 Tremolux, because it injected the trem at a shared cathode resistor of the paraphase inverter. That made the pumping noise common-mode to both sides of the push-pull output stage, which largely cancels the noise (it would perfectly cancel if the phase inverter had perfect balance.
Even that scheme didn't work 100%, and because Fender wanted to use something other than the paraphase on bigger amps, the trem was injected at the output tube grids on fixed-bias amps. And because this gets awkward with large bias voltages of high-power 6L6's, Fender took a step backward and used an optoisolator to inject trem without the benefit of noise cancellation.
All that is to tell you that injection of trem in a preamp stage is/was reserved for the cheapest amps in a company's line (for Fender, this would be the VibroChamp), because if you wanted noise-free perfect operation you should step up to the more expensive amps with the more complex circuits.
Now popping, banging, etc... that's not good. But backward pumping/woosh, that's par for this course.
Offline SleepLess
« Reply #31 on: March 21, 2014, 06:41:37 pm »
Thanks for making things clearer HotBlue!
The Tremolo works if I don't install a .068uF cap and I've tried bigger and smaller values too. I can switch it ON/OFF with the footswitch.
From 0 to 4 on the intensity knob the tremolo is weak. Between 5 and 6 it's ok. From 7 to 10 it just pops really loud and makes the amp unusable.
So I know the trem is very tricky on these amps, but there definitely is something wrong.
« Reply #32 on: March 21, 2014, 07:24:01 pm »
Now that it's working, did you go back and try to adjust that trimpot? I'm still not clear on its purpose, though it looks like it could be used to insure the trem signal doesn't overwhelm the other gain stage (which sounds like what's happening when you max the trem depth).
... From 0 to 4 on the intensity knob the tremolo is weak. ...
Methinks this is normal...  :l2:
Offline SleepLess
« Reply #33 on: March 22, 2014, 05:05:41 am »
Yes I did. The trimpot actually works like an intensity pot. At the minimum setting the tremolo quits working, at the extreme too. The difficulty is to set it right where the tremolo works well but remains acceptably silent.
I know I may sound like a noob at times but I'm not. Don't make fun of me. I am familiar with amps that have tremolos (and that don't): Fender blackface amps, tweed tremolux and Marshall 1974s. When I say it's weak, I know it should be subtle, but here, it's unusually weak. As a comparison, with the intensity on 6 it's the equivalent of the tremolo on 2 or 3 with the tremolux I have. So I could even have said that between 0 and 4, it's not working. And there's still those loud pops when the intensity is set beyond 7. So to sum it up, the tremolo works between 5 and 6, below that you can't really notice it and above that it pops. The setting range is usable on 2 figures instead of 10...
« Last Edit: March 22, 2014, 05:08:33 am by SleepLess »
« Reply #34 on: March 22, 2014, 06:30:23 am »
Not sure if you already did this, but those 3 cer. disc caps that are side by side in the picture... have you tried replacing those? I'm wondering if 1 (or more) might be leaky? And this might be totally off base, as I am not familiar with trems and how they work. My method is to keep replacing parts till I find the bad one. lol
« Reply #35 on: March 22, 2014, 07:30:33 am »
I'm sorry, that wasn't the intent. It just struck me funny when you mentioned the trem was weak when you turn it down. My silly side wanted to say, "Well, turn it up!"
Is the tube socket loose-fitting or something? Are the socket contacts corroded? What about wiring in a temporary replacement pot for the speed & depth?
I'm grasping at straws now, since from what you've said you have replaced everything else in the circuit and it's still not functioning properly.
« Last Edit: March 22, 2014, 07:45:46 am by HotBluePlates »
Offline SleepLess
« Reply #36 on: March 22, 2014, 08:33:46 am »
No worries!
Yes, it's a bit loose but the tube is held on fine. Do you mean I should maybe reflow all the solder joints on the socket? They still have the original red glyptol on them.
« Reply #37 on: March 22, 2014, 08:58:34 am »
I'm just thinking we're running out of items that aren't 100%.
If you have replaced all 3 series caps on the oscillator, replaced/removed the 0.068uF cap to ground, replaced the 25uF cathode bypass cap, re-wired the footswitch jack... Well, there's just not much left you can mess with.
So my thoughts turn to the noise/popping. Loose or dirty tube socket contacts could do that, so I wonder about those. I wonder about the pots and trimpot, and whether they could have a wrong taper (uneven trem strength per rotation) or dirty/intermittent resistive tracks (noise, popping). I wonder if the resistors (which we normally don't mess with) have some kind of noise/broken contact/absorbed humidity/etc issue...
Normally, trem is not this much trouble. I'd suggest replacing everything, one item at a time, until you fix the thing to figure out what is not right.
« Reply #38 on: March 22, 2014, 09:09:19 am »
Have you replaced the two plate resistors?
Offline SleepLess
« Reply #39 on: March 22, 2014, 09:10:33 am »
Nope but I measured them and they're within specs...
I'll reflow the solder joints on V1...
« Reply #40 on: March 22, 2014, 09:54:09 am »
A resistor can measure the right value and still be noisy.
Offline SleepLess
« Reply #41 on: March 24, 2014, 04:36:32 am »
I have changed the 470K resistor to no avail. I don't have any 680K at hand. I just shot a short video for you guys. I think these 40 seconds will be much more explicit that any text I can write... You'll see, something's definitely not normal.
http://youtu.be/BJ6zejtHAb0
Thanks for your help. At least the tremolo is working a bit, it wasn't at all before...
« Reply #42 on: March 24, 2014, 06:18:33 am »
I can't watch the video. It's "private".
1MΩ is fine for the 680kΩ. Don't forget the 100kΩ oscillator plate load and the 220kΩ gain stage plate load.
Offline SleepLess
« Reply #43 on: March 24, 2014, 06:20:29 am »
You should be able to watch it now. OK for the other resistors.
« Reply #44 on: March 24, 2014, 11:28:55 am »
Okay, that's a horse of a different color.
Turn the amp off. Measure resistance to ground from the 12AX7 cathode, with the trem intensity at 0. Record the value, then measure again with the intensity at full. Record the value. You know the approximate intensity setting whee the popping occurs; turn the intensity knob to this point and record the resistance value.
What were the 3 numbers you found?
« Last Edit: March 24, 2014, 04:05:33 pm by HotBluePlates »
Offline SleepLess
« Reply #45 on: March 24, 2014, 12:29:01 pm »
Okay, that's a hose of a different color.
Intensity on 0: 1.68K
Intensity on 10: 3.1K
Intenisty on 8 (about where the amp starts purring...): 2.7K
Thanks HotBlue!
« Reply #46 on: March 24, 2014, 12:48:28 pm »
What is the resistance end-to-end of the Intensity pot?
I was thinking this would be 5kΩ based on the schematic, but that doesn't seem possible with your numbers...
Offline SleepLess
« Reply #47 on: March 24, 2014, 12:53:24 pm »
I measured on the middle lug of the intensity pot to ground: 0K on 0 to 1.38K on 10... Far from 5K!
« Reply #48 on: March 24, 2014, 02:23:52 pm »
Looking at your pics and I can not quite see it - is that a solid wire connecting the plates on V1?  Where is the 100K resistor?
Offline SleepLess
« Reply #49 on: March 24, 2014, 02:30:55 pm »
You mean a 100K resistor connecting pins 1/6/7 like on other Marshalls? There's not any here...
