September 08, 2026, 07:13:31 pm
Hoffman Amps Forum image Author Topic: vintage soldering iron and gun museum  (Read 10027 times)
Offline terminalgs
« on: August 09, 2014, 09:52:52 am »
some cool pics of old soldering equipment.   Check out the "Handmade Soldering Gun"
http://www.stevenjohnson.com/soldering/index.html
(I'm not sure which forum is the best place to  post this...)
« Last Edit: August 09, 2014, 12:37:04 pm by terminalgs »
Re: vintage soldering iron and gun museum
« Reply #1 on: August 09, 2014, 10:42:15 am »
vintage soldering iron:  Just the ticket for a vintage cap can soldered to the chassis.  :icon_biggrin:
« Reply #2 on: August 09, 2014, 04:33:15 pm »
I like very much  :thumbsup:
« Reply #3 on: August 09, 2014, 11:02:48 pm »
I just used a larger, 300 Watt, version of the American Beauty to solder a tractor fuse-panel.
« Reply #4 on: August 09, 2014, 11:26:40 pm »
Now that's a soldering iron!
            Brad      :laugh:
« Reply #5 on: August 10, 2014, 12:22:45 am »
How I make soldered ground connections to a Fender steel chassis:
Find a 3-4" long (or longer) 1/4-20 bolt, preferably not galvanized. If galvanized, grind off the zinc plating on the head.
Grab the bolt in a pair of vice-grips and heat up the upper 1" in a propane torch, stop below red heat.
The head of the bolt does an excellent job soldering to a Fender steel chassis.
« Reply #6 on: August 10, 2014, 09:07:50 pm »
> If galvanized....
You should do the initial burn-off outside in a slight breeze. Zinc fumes are not good.
Sorry, the picture is a mere 200W, my 300W is even bigger. Here's a you-toobe of a 300W in action.
https://www.youtube.com/watch?v=ytgoT87nK_g
I was working in the sun on a very warm day. Brutal radiation off that huge lump of heat.
Offline terminalgs
« Reply #7 on: August 10, 2014, 09:42:32 pm »
that's a serious iron!!
you 've mentioned tractors..  what are we talking about?  I imagined farm and utility tractors, but maybe you are talking about large combine harvesters??? or are you old school referring to trucks as a tractor as in a tractor/trailer? semi's?
« Reply #8 on: August 11, 2014, 01:15:30 am »
Enough thread drift. Go to:
http://el34world.com/Forum/index.php?topic=17421.msg174503#msg174503
Offline vibrolax
« Reply #9 on: August 16, 2014, 10:44:22 am »
Here is the majority of my soldering arsenal, from left to right:
1) American Beauty 100W
2) Hexacon 10W
3) Hexacon 60W
4) Hexacon Stedi-Heat 4422 22W
5) Hexacon TC 871 300W controller
6) Sal Ammoniac tip cleaning block
The American Beauty was a $10 hamfest find, in wonderful condition except for a badly oxidized tip.  A 10 minute session with the Sal Ammoniac block brought it back to prime condition.   The others came from that auction site, each for less than $20.  A co-worker turned me into a Hexacon fan.  The XtraDur tips last a long time.
Jon
« Reply #10 on: August 17, 2014, 02:24:35 pm »
I just got a Weller WTCPL, green box with holder and 48W mag-stat iron and nice-size tip.
It heats. There's a hole on the box where something is missing. I feared it was a temp adjustment so I only ran the iron 20 seconds. Turns out it is just the on/off switch, the unit is fine as long as I unplug it.
Really needs a cleaning.
The same yardsale had a 100W utility iron in the wall-mount holder, but how many irons can I need?
Offline Jim Coash
« Reply #11 on: January 02, 2015, 06:21:37 am »
I still have the Heath soldering station I built from a kit in 1965.  It works but tips are NLA.  Jim
James Coash
