August 29, 2026, 01:14:20 pm
Hoffman Amps Forum image Author Topic: Grounding Layout - Is this correct ?  (Read 4087 times)
« on: November 30, 2014, 04:08:59 am »
Is this Grounding Layout correct (according with Doug's indications http://el34world.com/charts/images/ChassisGrounds_small.png) ?
Layout
Schematic
Many Thanks
« Last Edit: November 30, 2014, 07:04:39 am by kagliostro »
Re: Grounding Layout - Is this correct ?
« Reply #1 on: November 30, 2014, 10:53:58 am »
Whell this tread was continued here http://el34world.com/Forum/index.php?topic=17904.0
I hope this won't generate problems, the other tread was relative to the general disposition of the components respect each other
here I ask if the grounding scheme is conform to what Doug's indicate as a good grounding
as to avoid confusion I add also here the new Layout
« Reply #2 on: December 01, 2014, 05:35:00 am »
Franco,
It looks to me like you have a ground loop
You have two paths to ground from your pre amp bus
I would run it like this
A wire from your pre bus to the input jack ground
« Reply #3 on: December 01, 2014, 05:49:11 am »
Ciao Doug
On my draw I was thinking to use an isolated jack intake
Do you mean it will be better I use a not isolated jack intake at the input ?
Is my trouble on the buss soldered to pot chassis that are connected to ground ?
So, if I understand well, 6ak5 and 6j6 (preamp and PI) go to ground at the input jack, the other part of the amp to the bolt near PT, correct ?
Grazie per la risposta
« Last Edit: December 01, 2014, 05:56:06 am by kagliostro »
« Reply #4 on: December 01, 2014, 06:37:04 am »
Hi Franco,
I don't know
I have never used an isolated jack and pot assembly
You could easily move ground wires around once the amp was built to find the quietest grounding points
« Reply #5 on: December 01, 2014, 07:08:52 am »
Grazie ancora
