August 02, 2026, 09:55:17 am
Hoffman Amps Forum image Author Topic: Speaker ohms switch  (Read 4524 times)
Offline supro66
Speaker ohms switch
« on: December 23, 2014, 09:04:06 am »
I am building my second Supro 6420 thunderbolt amp
I have an output transformer witch has 5 choices
3.5--  8--  16 -- 250-- 500 ohm taps
8 ohms is what I use should I put a switch or another jack in for a 16 ohm speaker
Re: Speaker ohms switch
« Reply #1 on: December 23, 2014, 09:24:42 am »
It's a buckdancer's choice.
« Reply #2 on: December 23, 2014, 10:21:43 am »
Won't hurt, might need it someday, who knows. If you have room use another jack.
                  Brad    :icon_biggrin:
Offline supro66
« Reply #3 on: December 23, 2014, 10:34:52 am »
                  Brad    :icon_biggrin:
does it make a difference in sound 8 or 16
« Reply #4 on: December 23, 2014, 10:37:59 am »
No, not if you go 8 ohm tap to an 8 ohm speaker and 16 ohm tap to a 16 ohm speaker.
               Brad    :icon_biggrin:
« Reply #5 on: December 23, 2014, 11:40:28 am »
At the risk of tearing asunder this seemingly simple thread: there are those that believe, swear in fact, that at least in some cases, different ohm taps sound different even when used with the matching speaker load impedance.  See, e.g.:  http://www.thegearpage.net/board/showthread.php?t=984649
