September 17, 2026, 08:27:17 pm
Hoffman Amps Forum image Author Topic: My Plexi 6V6 build  (Read 39007 times)
Re: My Plexi 6V6 build
« Reply #50 on: February 24, 2015, 11:57:23 am »
I think I am done with the front panel CAD work
It's down to panel 5 or panel 6
I like the oval panel 6 design but I also like the circle in panel 5
« Reply #51 on: February 24, 2015, 12:15:04 pm »
I like the oval better.
         Brad    :icon_biggrin:
« Reply #52 on: February 24, 2015, 12:17:01 pm »
Yeah, me too
« Reply #53 on: February 24, 2015, 12:24:57 pm »
It's softer looking and makes the slots look better by moving them into more of an ark on their ends.
                 Brad    :icon_biggrin:
« Reply #54 on: February 24, 2015, 12:48:16 pm »
Here's a straight on view
Offline SILVERGUN
« Reply #55 on: February 24, 2015, 01:11:17 pm »
That looks great!
Kinda reminds me of an antique radio look
« Reply #56 on: February 24, 2015, 01:19:07 pm »
yeah, that's back when things had real styling
« Reply #57 on: February 24, 2015, 01:58:04 pm »
Yeah, I like it.
       Brad     :icon_biggrin:
« Reply #58 on: February 24, 2015, 02:07:49 pm »
It's on the CNC machine right now being cut
I'll have pics in a while
« Reply #59 on: February 24, 2015, 02:55:52 pm »
Yeeehaaaa.
It's done and it came out great
« Reply #60 on: February 24, 2015, 02:57:22 pm »
Sure did!!!!!!     :blob8:
What size and type of bit did you use? Spiral cut?
Did you cut it before or after you stained it?
            Brad     :icon_biggrin:
« Last Edit: February 24, 2015, 02:59:35 pm by Willabe »
Offline MakerDP
« Reply #61 on: February 24, 2015, 04:34:52 pm »
Bravo! That looks fantastic!
Offline MakerDP
« Reply #62 on: February 24, 2015, 04:38:53 pm »
EL panels are flexible plastic panels that are coated with electroluminescent material that emit a soft glow when electrically charged.
Follow this link for examples of EL panels, tape, wire, etc...
http://www.adafruit.com/category/50
Oh wow... they even have EL piping! Didn't see that before...
« Last Edit: February 24, 2015, 04:43:15 pm by MakerDP »
« Reply #63 on: February 24, 2015, 04:41:57 pm »
            Brad     :icon_biggrin:
1/4 inch two flute end mill at 15,000 rpm
Straight down plunge at a very slow speed
Then a faster speed for the cuts
I under cut in two depth passes by .003" and then did a final pass at full depth for a super clean finish cut
It was already stained and clear coated when I did the cuts. All I did was take a small brush and brush some stain inside the cuts to get rid of the blond wood
« Last Edit: February 24, 2015, 04:45:45 pm by EL34 »
« Reply #64 on: February 24, 2015, 04:44:01 pm »
That's some cool stuff
« Reply #65 on: February 24, 2015, 04:47:57 pm »
Well your method and machine did a great job!
                        Brad     :icon_biggrin:
« Reply #66 on: February 24, 2015, 07:38:39 pm »
that's a cool site for open source hackers. it's owned by limor fried, she's an MIT grad who ventured off into her own biz. check the whole site out, she sells some cool stuff.
« Reply #67 on: February 24, 2015, 07:48:15 pm »
            Brad     :icon_biggrin:
i'm assuming your cut job was an inside contour: do you recall what the feed rate on your X & Y axis? how many passes and what cut depth did you use? it'd be nice to have a staring point since i've never cut wood on my CNC, just aluminum and Garolite...    :icon_biggrin:
thanks,
Offline MakerDP
« Reply #68 on: February 24, 2015, 09:53:11 pm »
Yep. I've ordered a fair amount of stuff from them. Us "makers" love that site. She's come up with some very innovative stuff.
Another very cool lighting product there are the Neopixels - Individually addressable RGB LED strips, arrays, rings, etc. controllable with any microcontroller (like Arduino.) I've seen people make these into large video displays (think stadium Jumbo Tron but on a smaller scale.)
I'd like to do a "neon retro jukebox" sort of design for a tubes-up combo. Done well I think it would look really neat on stage.
« Last Edit: February 24, 2015, 09:55:45 pm by MakerDP »
Offline TubeGeek
    • Glacier Amps
« Reply #69 on: February 25, 2015, 12:26:16 am »
I love that front panel!
I am working on using some light blue EL wire in my latest build.
« Reply #70 on: February 25, 2015, 05:38:05 am »
thanks, --pete
see my screen short for all the settings I used
Inside contour?
In CamBam the MOP is called profiling which is probably the same thing?
The tool is following a shape.
In this case I have it set for profiling the inside of all the shapes
I used real slow speeds because I did not want to splinter the wood.
3 for plunge and 10 for cutting, shown in screen shot
Two rough cut passes
-0.23 inches down, then -0.47 inches down
Cutting  -0.002 back from the lines as a roughing clearance
One final pass at -0.47 with the roughing clearance pass set to zero so it does one final clean pass following the lines
I set the tool width to 0.245 inches wide to fool CamBam because my parallel lines were exactly 0.25 inches apart
It has a problem doing that if the tool bit is set to 0.25 inches wide
« Reply #71 on: February 25, 2015, 11:57:38 am »
thanks, --pete
Inside contour?
thank you so much!   :icon_biggrin:
i was estimating about 13-14 IPM with my machine running @ 22K RMP on the spindle. my machine's spindle is a porter-cable router.
« Reply #72 on: February 25, 2015, 12:03:01 pm »
I run a Bosch router motor but I use a super PID motor control
You mount a sensor that reads the rpm of the motor shaft
The motor speed stays constant, even under heavy loads
See the wire coming out of the end of the Router motor?
Big pic here
http://el34world.com/Misc/Cnc/CNC19.htm
It's so much nicer with an electronic control unit
« Last Edit: February 27, 2015, 06:28:32 am by EL34 »
« Reply #73 on: February 26, 2015, 12:45:57 am »
Big pic here
thanks for sharing. i'm hoping that i can pickup rotation off of the main-shaft by the collett.
« Reply #74 on: February 27, 2015, 06:25:07 am »
Many Thanks for sharing
« Reply #75 on: March 02, 2015, 04:31:46 pm »
thinking about adding some blue LED's inside just for fun
« Reply #76 on: March 02, 2015, 05:06:40 pm »
Hoho, that's the ticket right there!
That would light up the letters on the face plate if it wasn't painted on the back?
             Brad    :icon_biggrin:
« Last Edit: March 02, 2015, 05:09:07 pm by Willabe »
« Reply #77 on: March 02, 2015, 05:40:52 pm »
I think the Blue looks pretty cool
I guess you mean edge lighting the plastic?
If you did that, then you would not be able to see the words in regular day light
« Reply #78 on: March 02, 2015, 06:36:54 pm »
I meant back lit.
               Brad    :dontknow:
« Reply #79 on: March 02, 2015, 07:06:07 pm »
You mean like cut all the metal away until there is nothing holding the front panel on the amp  :icon_biggrin:
« Reply #80 on: March 02, 2015, 07:19:52 pm »
Dho!  That's right the chassis.
             Brad    :laugh:
« Reply #81 on: March 03, 2015, 06:40:08 am »
I guess it could be done
Not sure how you would remove all that metal?
Then you would have to figure out a way to evenly light every bit of text plus all 11 pot detents
Plus, picture what is right behind all of those cutouts
Pots, wires, etc
It would look like this I guess
« Last Edit: March 03, 2015, 06:52:34 am by EL34 »
« Reply #82 on: March 03, 2015, 07:32:35 am »
To have light on labels
why don't to add a plastic faceplate with labels engraved on the back side as HotBluePlates has done on his Standel ?
« Reply #83 on: March 03, 2015, 07:46:32 am »
There ya go Brad
I like the black on white faceplates personally
Offline MakerDP
« Reply #84 on: March 03, 2015, 10:36:19 am »
This would be a great application of those EL panels I was showing you. Engrave the black faceplate as normal, cut an EL panel to fit the faceplate and affix it to the back of the faceplate or just sandwich the panel in between the faceplate and chassis front.
Hmm... I know you can cut these down to whatever size you want, but I don't know about holes for the pots and switches... Let me research that. If you can cut them to size, I'd think holes would be OK.
« Reply #85 on: March 03, 2015, 10:43:49 am »
They would have to be about zero thickness
The face plates are .0625 inches thick (1/16") and there are really no much more threads left on the pots when combined with the .09 inch thick aluminum chassis
Offline MakerDP
« Reply #86 on: March 03, 2015, 11:08:39 am »
That could be a problem... they are about 0.5mm thick.
« Reply #87 on: March 03, 2015, 11:15:24 am »
I have had that problem with my aluminum chassis' and face plates too.
I found that the Mojo brand pots have a little bit longer threaded bushing that works. Problem is they only stock so many values. So far they have been most of what of I needed but I have had to use a few PEC military pots which cost a lot more.
OTOH, with a steel chassis, because their thinner, there might be enough room?
             Brad     :think1:
« Reply #88 on: March 03, 2015, 11:30:46 am »
.5mm is pretty thin
That may work
Check them out and let me know what you come up with
« Reply #89 on: March 03, 2015, 11:31:38 am »
I thought about stocking those pots, but like you said, the values are limited
« Reply #90 on: March 03, 2015, 12:14:42 pm »
Maybe next time you talk with you could bring up the bushing length for more values of pots for guys building with aluminum chassis and thicker face plates?
             Brad    :dontknow:
« Reply #91 on: March 03, 2015, 12:23:51 pm »
I could mention it and see
Don't hold your breath :)
I didn't really have any problems with the Alpha pots I stock
A .09 inch chassis and a .0625 inch faceplate works out just right
The Stout Chassis + Alpha pots is a good combo
Years ago, my Hoffman chassis were .125 inch thick aluminum with the same faceplate material
That was right on the edge of being too thick
« Reply #92 on: March 03, 2015, 03:24:57 pm »
yes, they are .4" long - specifically for vintage fender amps. 16ga (.058") chassis + faceplate + brass backing plate + internal tooth washer necessitates that: the values mojo stocks are used in the most common vintage fender amps.
