August 29, 2026, 02:06:01 pm
Hoffman Amps Forum image Author Topic: 1 channel Vibrolux no Trem  (Read 4524 times)
Offline dunner84
« on: October 22, 2015, 11:05:51 pm »
Hello,
So I finally have everything I need to build this amp, and I have begun planning it out. I am using the layout posted on the Hoffman site for the 1 channel ab763 circuit. http://el34world.com/Hoffman/files/Hoffman_AB763_1.pdf
However I am removing the tremolo... boo hiss... It is just a feature that I can live without.
I have started a rough draft of the layout without the tremolo circuit included. I was hoping someone could take a look over the layout where I removed the trem, and make sure I didn't miss anything. I did this up on my lunch break today, so hopefully a fresh set of eyes can proof it for me. It's a bit sloppy, but it's a rough draft. At this point, I am just concerned about the trem section being removed properly. I drew a dotted red line in-between v3 and v5 where the trem section was.
Also, I am using a PT without a 50v bias tap. I am hoping to implement the suggested circuit on this page: https://robrobinette.com/5e3_Modific...djustable_Bias
Any suggestions on how to modify the bias portion to use the HV tap and not a 50v one?
I will most likely be modifying the Mid to be a RAW control, and I will also be adding more control for the verb, but I think I can manage all that on my own.
I will post pics when I am all done. The cabinet is made, the chassis is bent up and mostly drilled, and the components are all here. I will be working out of town for the next 6 weeks, so I have a lot of time to plan and populate the board. The rest will be finished when I get back which is hopefully in time for christmas.
Thanks for the help.
Re: 1 channel Vibrolux no Trem
« Reply #1 on: October 22, 2015, 11:19:42 pm »
Looking at Hoffman's layout... The box that says "Bias Tap"... Change to say "HV Tap". Replace the 470Ω/3W bias range resistor with a 100K/3W resistor.
That's all.
Offline dunner84
« Reply #2 on: October 23, 2015, 12:06:44 am »
Fantastic, thank you! Much easier than I thought it would be.
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #3 on: October 30, 2015, 10:03:02 pm »
Sorry for hijacking the thread, I've been trying to find the list of files like the one above, no go  :dontknow:, could someone point me the way please and thanks.
https://soundcloud.com/ukiuki
« Reply #4 on: October 30, 2015, 10:13:39 pm »
Their in our host Doug's 'Tube Library of information.' Link can be found at the very bottom of any page in the forum.
http://el34world.com/schematics.htm
« Last Edit: October 30, 2015, 10:16:36 pm by Willabe »
Offline uki
    • Uki's Guitar Trip
« Reply #5 on: October 31, 2015, 10:21:28 am »
THANKS !!! Those are really helpfull, and good learning platform.
