July 27, 2026, 04:20:31 pm
Hoffman Amps Forum image Author Topic: 6N6P (6Н6П) is really an (electrically) equivalent tube of the ECC99 ?  (Read 20394 times)
« Last Edit: January 16, 2016, 09:26:45 am by kagliostro »
Offline drgonzonm
Re: 6N6P (6Н6П) is really an (electrically) equivalent tube of the ECC99 ?
« Reply #1 on: January 18, 2016, 05:04:19 pm »
Franco,
I love your strange finds, they put smiles on my face, as look over your posts  :headbang:
« Reply #2 on: January 18, 2016, 06:56:03 pm »
Is the 6N6P (6Н6П), as some vendor says, really an (electrically) equivalent tube of the ECC99 ...
The Russian data sheet for the 6N6P claims a little more Gm, a little less rp for the same operating point as the JJ ECC99.
The 6N6P heater uses only pins 4 & 5; pin 9 is an internal shield. The data sheet says 6.3v heater only.
The JJ ECC99 uses pin 9 as a center-tap for the heater, and can accept 6.3v (2 heater sections in parallel) or 12.6v (2 heater sections in series).
So similar, but different. I haven't personally tried either tube.
« Reply #3 on: January 19, 2016, 02:09:53 am »
Thanks HotBluePlates
So, if the filament voltage is the major difference, in a small amp with filament circuit properly adapted I think the 6N6P can be used as power tube in place of ECC99
(a friend told me that there may be a chance to have some it at a good price, I'll try to take it)
Thanks again
Offline jazbo8
« Reply #4 on: January 19, 2016, 02:17:26 am »
for a mini-amp perhaps... :icon_biggrin:
« Reply #5 on: January 19, 2016, 05:10:43 pm »
There is a recent post about a small amp that uses ECC99
http://el34world.com/Forum/index.php?topic=19680.0
 :angel
Offline Bluemeany
« Reply #6 on: January 25, 2016, 01:42:08 pm »
 :angel
Hi again Kagliostro, when I designed that amp the 6N6P was in my mind and should work fine - the reason I spec the ECC99 is the heater arrangement mentioned above and simplicity in set up that it allows (I use 12v6 heaters in most of my builds).
« Reply #7 on: January 25, 2016, 03:54:12 pm »
Thanks for the info
