September 19, 2026, 06:08:53 pm
Hoffman Amps Forum image Author Topic: WANTED: Amphenol 160-2N  (Read 11222 times)
Offline p2pAmps
    • p2pAmps
« on: February 08, 2016, 02:34:47 pm »
Hello Guys,
Anyone have a few of these they would like to sell me?
Everything Affects Everything
Re: WANTED: Amphenol 160-2N
« Reply #2 on: February 08, 2016, 03:21:17 pm »
I believe there are 2 sizes fender used.  Check with Steve at http://www.apexjr.com/
He used to have both.
I guess you know which size you need, but the part number is for the larger ones used in the 70's from what I read.  I have seen them in old radios, but not sure if it is 2N
« Last Edit: February 08, 2016, 03:25:06 pm by Ed_Chambley »
Offline Paul1453
« Reply #3 on: February 08, 2016, 03:28:59 pm »
$32 for a simple power connector?  Ouch!
Mouser doesn't have any of this round type, but for only $1 or so per connector I might consider squaring that hole to make one of these fit.   :dontknow:
http://www.mouser.com/Connectors/Power-Connectors/AC-Power-Plugs-Receptacles/_/N-axire?P=1yy18jl
Offline p2pAmps
    • p2pAmps
« Reply #4 on: February 08, 2016, 09:12:22 pm »
Yeah, 32 bucks seems a little on the steep side.
« Reply #5 on: February 08, 2016, 09:40:16 pm »
I have some two-pronged polarized outlets like that. Mine require a 1-5/32" diameter mounting hole 1-1/8" if mounting from the back). What size hole do you need?
Offline p2pAmps
    • p2pAmps
« Reply #6 on: February 09, 2016, 04:30:59 am »
Steve,
I don't have the hole yet as this is for a PR build.  I have a 2 prong like you now but my guy wants a 3 prong.  He might have to cough up that 32 bucks if it really is that important.  I like those IECs too but I do not have a square punch.
« Reply #7 on: February 09, 2016, 05:55:13 am »
I don't think a square hole would be a challenge for you. Drill, nibbler tool, files. Takes longer, but you feel so satisfied when it's done!   :icon_biggrin:
Offline p2pAmps
    • p2pAmps
« Reply #8 on: February 09, 2016, 06:19:38 am »
I could do it I just like things to be perfect, personality flaw.  If I do enough of these the 100 bucks for a Greenlee Radio Chassis Punch might be ok.
« Reply #9 on: February 09, 2016, 09:08:57 am »
I do square holes in chassis with 4 holes drilled in the corners then connect them using a dremel tool with their metal cutting disk, comes out darn near perfect to perfect.  :icon_biggrin:
« Reply #10 on: February 09, 2016, 11:17:27 am »
Take a look at this rectangle chassis hole dbishopbliss cut;
http://el34world.com/Forum/index.php?topic=19797.msg206776#msg206776
« Reply #11 on: February 09, 2016, 02:34:14 pm »
Hubbell makes some nice ones. They require a 1-1/2" hole. That may not fit a Fender repro chassis. Here's one on eBay...
http://www.ebay.com/itm/Lot-of-2-Hubbell-Receptacle-15-Amp-125-Volt-/151019124775?hash=item232970f827:g:hIMAAMXQlUNRVcTM
« Reply #12 on: February 09, 2016, 02:40:59 pm »
And here they are, just like Ed said...
http://www.apexjr.com/new.htm
Sixth item on the list.
Offline p2pAmps
    • p2pAmps
« Reply #13 on: February 09, 2016, 02:43:01 pm »
Yeah, I contacted apexjr and he is all sold out :(
« Reply #14 on: February 09, 2016, 02:52:22 pm »
Ha! I just realized the pic you posted is on the apexjr server!
Offline Paul1453
« Reply #15 on: February 09, 2016, 03:03:07 pm »
Mike, with your level of workmanship I am sure you could make a perfect square hole for the cheaper plug.
Willabe's four drill hole and dremel method is within your skill level.   :worthy1:
It might not look so nice if I did it, but practice makes perfect.   :l2:
Offline p2pAmps
    • p2pAmps
« Reply #16 on: February 09, 2016, 03:21:08 pm »
I don't thing a square hole is a big deal I just kinda wanted that Fender plug...  I guess I have to decide if I want it 32 bucks worth LOL
« Reply #17 on: February 09, 2016, 09:44:36 pm »
I know a socket in the back is traditional. My experience is that you plug a cord in a socket some feet off the floor, some fool (me) trips over the cord and knocks the amp down. (More fun if reverb is turned up.)
For a combo, I have put a 4-way plain two-duplex j-box in the bottom of the speaker space. Box, cover, and 10-pack of receptacles (do not get tamper-proof!!) is under $13 at the home store; may be $18 if you blow for two Commercial-grade (tougher) receptacles. Get dark outlets, paint the cover black, it isn't obvious, but very easy to use, and can support the whole band.
http://www.garvinindustries.com/electrical-covers-device-rings/4-square-covers-device-rings/industrial-surface-covers/g1939
Side note: that photo shows the receptacles mounted only by the center screw. That's how we did it for decades. But note the 4 empty holes. These covers now come with (should) 4 screws and nuts so you can hang the receptacles by their main ears 2-point. More solid, and better grounding. In either case you have to bust-off the Mickey-Mouse ears on standard receptacles to get them into that type cover.
« Last Edit: February 09, 2016, 09:46:55 pm by PRR »
Offline p2pAmps
    • p2pAmps
« Reply #18 on: February 10, 2016, 07:31:47 pm »
Ok, so I pulled the trigger on two from Marsh for 50.00 shipped.
Offline p2pAmps
    • p2pAmps
« Reply #19 on: February 14, 2016, 07:41:27 am »
Ok, now I'm satisfied...
« Reply #20 on: February 14, 2016, 09:50:42 am »
Ok, good.  :laugh:
I always plugged my Conn strobe tuner into that outlet.
Offline p2pAmps
    • p2pAmps
« Reply #21 on: February 14, 2016, 11:18:30 am »
Ok, good.  :laugh:
I guess we are both showing our age LOL
« Reply #22 on: February 14, 2016, 11:27:03 am »
Yeah, I still have mine too.  :icon_biggrin:
I still use it to adjust bridge saddles. I think I paid ~$250(?) for it back in the late '70's? Was a lot of $$ back then.
All the other guys I was playing with tuned up with it, nice to have everybody in tune.  :laugh:
« Reply #23 on: February 15, 2016, 05:58:03 pm »
If you got to play in tune thru the 70's & 80's, that was well worth the cost of the strobotuner©.  :laugh:
