September 08, 2026, 07:13:48 pm
Hoffman Amps Forum image Author Topic: Zip ties instead of stand offs  (Read 9562 times)
« on: February 23, 2016, 12:11:31 am »
I found these zip ties with a molded mounting hole. Took a little searching to find them with either a #6 or #4 mounting hole but they do make them.
I'm going to try them for mounting the loose end junction of preamp tube grid stoppers and shielded cable. I probably need to slide some shrink tube over the loose end of the R/solder joint to keep it from shorting out to the chassis?
And then I found these zip tie mounting brackets, they will hold 2 separate ties, only need 1 bolt/nut and only 1 hole drilled in the chassis. These have the benefit of lifting the R off the chassis depending how you mount them. Gonna try them too.  :icon_biggrin:
Both are cheaper then stand offs so I can save those for high(er) voltage stuff.
« Last Edit: February 23, 2016, 12:46:46 am by Willabe »
Re: Zip ties instead of stand offs
« Reply #2 on: February 23, 2016, 09:09:42 am »
Thanks DL, yeah guys here have been using those and posting gut shots with them.
But, I want to bolt them in, I just don't trust the adhesive/glue to stick long time.
« Last Edit: February 23, 2016, 09:14:06 am by Willabe »
« Reply #3 on: February 23, 2016, 10:51:45 am »
+1
« Reply #4 on: February 23, 2016, 01:20:46 pm »
Not sure about the *modern* glue, but the stuff we used in the 80's I had to chisel off in the 2000's so the scrap metal buyers were happy
« Reply #5 on: February 23, 2016, 03:35:28 pm »
That's the way it always is when you want to remove them!   :icon_biggrin:
I've used quite a few of those throughout my career. The ones used in a fully climate controlled space do very well. The ones in a weatherproof junction box in the parking lot usually turn loose pretty quick.
« Reply #6 on: March 08, 2016, 05:39:36 pm »
The mounting hole zip ties and bolt down zip tie mounting blocks arrived in the mail.   :mail1:
I really think these are going to work great!  :icon_biggrin:
Zip tie bolt hole is a #4 and the mounting bracket is a #6.
« Reply #7 on: March 08, 2016, 05:47:30 pm »
More pics;
Offline Fresh_Start
  • noob de Lux
« Reply #8 on: March 08, 2016, 11:28:23 pm »
Those look great. Thanks for sharing.
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #9 on: March 09, 2016, 06:43:50 am »
 :icon_biggrin:
