August 29, 2026, 04:56:32 pm
Hoffman Amps Forum image Author Topic: PR build wiring question  (Read 10291 times)
Offline Shack
« on: March 15, 2016, 02:44:57 pm »
Is the reverb input jack tip supposed to have continuity with ground after everything is wired up, from other end of transformer? After looking at layout diagram im thinking yes, but want to make sure .
Board is all wired up, time for components AFTER double checking every thing....man I wish I was a better solderer  :w2:
New build problems? Click here.
Offline Shack
Re: PR build wiring question
« Reply #1 on: March 15, 2016, 03:17:09 pm »
Its gonna take me awhile to figure out the pics thing, bear with me.....but here is the wired chassis. :icon_biggrin:
Offline p2pAmps
    • p2pAmps
Everything Affects Everything
« Reply #3 on: March 15, 2016, 03:37:16 pm »
When you say "continuity" do you mean very low ohms, 1-2-5 ohms or *any* amount of ohms not well into the megohms?
Sure, you should read some smallish amount of ohms across ONE SINGLE winding of a given transformer. A 120 VAC input to a power transformer can have a shockingly low DC resistance reading....1-2-3 ohms, easily. A high-current 6.3 volt winding can look pretty much like a short circuit as can a 5v rectifier filament winding.
This is provided you mean END of the transformer meaning END of the transformer WINDING versus SIDE of the transformer eg; input versus output, where there should be no continuity.
Is your soldering iron a WCC-100? I have one of those. Let's just say I use the stand/base and the iron is hanging off to the side unused. It's a piece of garbage, not as good as a Radio Shack $5.99 25 watt iron you plug into an AC outlet.
« Last Edit: March 15, 2016, 03:39:25 pm by eleventeen »
Offline Shack
« Reply #4 on: March 15, 2016, 03:51:46 pm »
I was using the audible continuity test
Offline Shack
« Reply #5 on: March 15, 2016, 04:01:42 pm »
heres mine ...I think im good
Offline Shack
« Reply #6 on: March 15, 2016, 04:03:24 pm »
crap, its upside down,lol
« Reply #7 on: March 15, 2016, 06:52:51 pm »
yes
Offline Shack
« Reply #8 on: March 15, 2016, 07:34:53 pm »
Thank you very much Sluckey...I seen the other end of the transformer primary on the layout as I was typing, so wanted to confirm
« Reply #9 on: March 15, 2016, 08:40:10 pm »
is that grid leak resistor on the return jack red-red-black-orange? can't tell if the 4th band is orange or yellow. it should be yellow for a 220K.
Offline Shack
« Reply #10 on: March 15, 2016, 10:36:52 pm »
hope its yellow,lol....hate the blue resistors
Offline Shack
« Reply #11 on: March 15, 2016, 10:41:18 pm »
its 220k
Offline p2pAmps
    • p2pAmps
« Reply #12 on: March 15, 2016, 10:44:28 pm »
So why is the white wire on pin 2 (grid) going to the reverb input instead of Reverb Pedal Input?  Have I been doing mine wrong?
« Reply #13 on: March 16, 2016, 02:30:37 am »
red-red-black-orange is 220K
« Reply #14 on: March 16, 2016, 02:34:47 am »
That's a mistake. White wire should connect to the two middle jacks.
Offline p2pAmps
    • p2pAmps
« Reply #15 on: March 16, 2016, 07:28:15 am »
Thanks Steve.  I thought so but I never assume I am right about anything with the company on this forum  :icon_biggrin:
« Reply #16 on: March 16, 2016, 08:14:34 am »
Hey, you're the go to guy for anything PR related!  :wink:
Offline p2pAmps
    • p2pAmps
« Reply #17 on: March 16, 2016, 08:18:32 am »
Don't start a fight with me this early in the morning and before my coffee LOL  :l2:
Offline Shack
« Reply #18 on: March 16, 2016, 08:29:39 am »
thanks, ill fix that, I also realized this morning that I forgot the bias tap wire too
I made that mistake because I mistook the jack on the layout as the end jack...DOH.......man im glad you guys are here
« Last Edit: March 16, 2016, 08:36:19 am by Shack »
« Reply #19 on: March 16, 2016, 06:15:05 pm »
... I also realized this morning that I forgot the bias tap wire too ...
Bias tap? A Princeton doesn't have a bias tap, but sources input to the bias circuit from the high voltage winding.
So did you mean a red/blue bias tap, or the wire from the rectifier tube (where the high voltage winding connects) over to the bias circuit?
Offline Shack
« Reply #20 on: March 16, 2016, 06:36:59 pm »
its from high voltage winding....Doug has it as bias tap on layout....its fixed
« Reply #21 on: March 16, 2016, 06:38:12 pm »
that's right - FOUR band. plz pass dunce hat.   :icon_biggrin:
« Reply #22 on: March 16, 2016, 07:22:13 pm »
good band name, but you mis-spelled dAnce :icon_biggrin:
Offline Shack
« Reply #23 on: March 16, 2016, 07:26:09 pm »
lmao
« Reply #24 on: March 16, 2016, 08:15:37 pm »
oh no! no misspellings...
http://dunce-hat-info.blogspot.com/    :icon_biggrin:
https://en.wikipedia.org/wiki/Dunce#Dunce_cap   :BangHead:
