September 08, 2026, 03:38:14 pm
Hoffman Amps Forum image Author Topic: HiFish II PSE 6V6  (Read 12866 times)
HiFish II PSE 6V6
« on: March 28, 2016, 03:35:16 pm »
Just one more :icon_biggrin:
Parts are coming, the paperwork's done.  I'll call it my take on a guitar karaoke amp.  Or just a basic mono block for music, or practice amp for the bedroom.  The owner of my last version is hunting down a small - 8" cab, then wants me to tune it.   I started by trying to get a 25W edcor to fit on a stout chassis, it did, but there wasn't room for tubes!  So I hunted up K's SE Ot wiring diagrams and we'll see how a couple 22905's cross-wired will sound.  Shooting for 300 plate, 12 - 13 bias and around 30mA on the 6V6s.
One *thing*, on the layout, I have the grid leak and grid stop R's for the 6V6s on the preamp ground, should I by-pass that turret and just run it to the PA ground section?
The TS will be built off the pots, probably with a terminal strip.
« Last Edit: May 09, 2016, 06:59:37 pm by shooter »
Re: HiFish II PSE 6V6
« Reply #1 on: March 29, 2016, 12:08:33 am »
Why so many gain stages?
A Champ plays with two gain stages.
As drawn, input sensitivity is near 0.1mV. Classic Fender is 20mV. 0.1mV is extreme thrash turf, and probably can't be made stable.
Offline Fresh_Start
  • noob de Lux
« Reply #2 on: March 29, 2016, 01:26:50 am »
Yes, grid leak (grid return) resistors should be grounded where the tube they precede is grounded. But grid stoppers shouldn't be grounded.
I can't do the math but it sure looks like you need several voltage dropping dividers between preamp stages.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #3 on: March 29, 2016, 01:53:32 am »
I do not get along with math, but those preamp tubes are 12AU7, not the usual 12AX7, didn't this changes things ?
« Last Edit: March 29, 2016, 01:59:27 am by kagliostro »
« Reply #4 on: March 29, 2016, 02:10:12 am »
yes 12AU7. but still going to need to pull a bypass or two in that string... if he wants somewhat clean, even with 2nd stage as input.
« Last Edit: March 29, 2016, 02:15:13 am by DummyLoad »
« Reply #5 on: March 29, 2016, 08:53:54 am »
That's one of the things still to learn, what to look at to guestimate sensitivity
The original pre, I stole from RCA, see attached.   A few ideas and re-works with wise inputs from here and me became what's drawn.  I fully expect to be modifying stage gains, might even  use V2b as a CF.
« Reply #6 on: March 29, 2016, 09:05:24 am »
They should be grounded with the same tubes cathode R.
From Merlin below;
« Reply #7 on: March 29, 2016, 10:13:58 am »
The big difference I see in your schematic, respect the "source" schematic is that in the source V1a and V2b are is CF whose gain is max 1
in your version V1a and V2b are Anode Followers and there the gain is much more
BTW I've never seen a CF at the input of an amp, that is curious, may be that solution is due to an attention to have an impedance adaptation
What about to go V1a input > V1b CF > James Tone Control > V2a gain stage > V2b switchable OD ?
« Last Edit: July 25, 2016, 12:35:14 am by kagliostro »
« Reply #8 on: March 29, 2016, 11:32:01 am »
Thanks K, the original *design* was to drive a KT88, here's the link and *progression* to this *design*
http://el34world.com/Forum/index.php?topic=19097.0
I didn't bother re-calc'in gains from 88 to pse 6v6, figured I could scrap one stage, or convert to CF if needed.  If it works fine but I can only turn up the volume to 5, that's not a big deal to me.  Being able to have a clean reasonable range is.  It's main *job* will be playing digital music, but, when I hear *that* song, I know I'm gonna want to plug in the 6 strings, loop the song, and see just how bad I can butcher it.
Offline Paul1453
« Reply #9 on: March 29, 2016, 03:03:35 pm »
OK, so now I get your concept.
The Karaoke term had me thinking you would Mic the AUX jack.
So you want a Hi-Fi tube amp that can mix in your guitar when you hear "that" song.  :icon_biggrin:
Cool!  That seems a better solution then plugging in another amp to play along.
« Reply #10 on: March 30, 2016, 12:14:28 am »
> I stole from RCA
I like plagiarism.
Some of RCA's sketches were throw-aways. Or worse.
And here you've totally repurposed half the stages.
So I am blind.
Say gain of 15.
15 * 0.5 * 15 * 0.1 * 15 * 15 = 2,500
Say 25V needed at 6V6. 25/2500 is 0.010V, 10mV, hot but not excessive.
Three stages of Gv=36 would be the same gain, less work.
RCA sold tubes. Plans with extra tubes may have seemed like good business.
« Reply #11 on: March 30, 2016, 01:54:42 am »
 :laugh: :laugh:
Some time ago I've read something that sounded like more tube more harmonics
There is some truth on that ?
« Reply #12 on: March 30, 2016, 10:29:42 am »
K, you are reading my mind!
I've been wondering IF tubes add harmonics, or simply amplifies them :dontknow:
So this is input sensitivity for the amp, 10mV?
I understand sensitivity as smallest input signal  that can be, measured, amplified, cleanly,
like if I get much below 10mV on my scope I'm viewing more grass than signal.
« Reply #13 on: March 30, 2016, 06:01:10 pm »
No, this is smallest signal to get FULL OUTPUT. 10mV in will give 25V at the power tube grid, which is +/- what most power tubes need to reach Full Power Out. (EL84 typically less, hi-Volt 6L6 a bit more, but not a big difference.)
The "smallest signal which can be recovered cleanly" is the noise level. Tubes have about 2 micro-Volts self-hiss, and 1uV-20uV of hum induced from heaters or poor B+ filtering.
Your 'scope is wide-band. A tube will be about 2uV hiss in a 20KHz band, but about 20uV hiss in a 2MHz band. Still you should be able to resolve <1mV at the 'scope terminals. (10X probe pads or test stages in front will degrade this.)
« Reply #14 on: March 30, 2016, 08:41:17 pm »
Thank you PRR
got parts today, just as an artic blast shows up!, drillin and cutting in the house!
« Reply #15 on: April 03, 2016, 05:06:48 pm »
Got the board put together and as I was ringing out everything I noticed a + sign on the .022uf cap.
Is this something to indicate foil side, or is this a .022uf E-cap, stray + on the silkscreen :dontknow:
« Reply #16 on: April 03, 2016, 05:26:58 pm »
Definitely not a polarity indicator.
« Reply #17 on: April 03, 2016, 05:48:41 pm »
figured it wasn't, that's why I left it *backward* :icon_biggrin:
« Reply #18 on: April 03, 2016, 07:07:49 pm »
... I noticed a + sign on the .022uf cap. Is this something to indicate foil side, or is this a .022uf E-cap, stray + on the silkscreen :dontknow:
The Dijon is a film & foil cap, so possibly a mark for the outer foil. A 0.022µF electrolytic would be exceedingly tiny.
« Reply #19 on: April 03, 2016, 07:19:40 pm »
so it'll just make a tiny puff since it's backward :icon_biggrin:
I was guessing Ecap  a stretch, stray silkscreen was my 1st *guess* since it's the only Dijon I have
with a +
« Reply #20 on: April 04, 2016, 10:17:39 am »
got some in-door work done while we freeze :cussing:
formed up the copper overlay, but need some 70f before I do any glue-sniffing.
need to hunt-down some graphic wiz to help-print my logo after the glue dries!
« Reply #21 on: April 04, 2016, 10:39:44 am »
That looks real nice.  :icon_biggrin:
Just 1 possible suggestion, using different colored fly lead wires would make it easier to wire up.
I go with a separate color for the preamp tubes plate/grid/cathode/B+/ground/etc.
« Reply #22 on: April 04, 2016, 11:50:25 am »
Those, like the copper *overlay* is sorta "my signature" design.  This is my 3rd coppertop, red-lead build.
And, ya, you DO have to pay attention, and Ya, I do feel sorta bad for the poor tech in the future :icon_biggrin:
« Reply #23 on: April 08, 2016, 08:13:33 pm »
I gave up on waiting for the weather so I spent the evening sniffing glue, solder, and resin.
Still gotta clean the initial solder and re-flow.  Time for a green beer to clear my head :icon_biggrin:
« Reply #24 on: April 11, 2016, 04:43:46 pm »
More paint sniffing
Offline Paul1453
« Reply #25 on: April 11, 2016, 07:33:40 pm »
Your copper coating is interesting.   :worthy1:
I'm wondering if I could just screw down a thin sheet of copper to cover the holes on my swiss cheese chassis'?  :l2:
« Reply #26 on: April 11, 2016, 08:01:47 pm »
You probably could, sorta part of why I do it.  the copper sheet is about 4X stiffer than a sheet of paper with a thick paper backing.  glue it though!   I paint instead of play, so my songs or Riffs are done with oils, acrylics, rattle-cans instead of F bodies or acoustics, otherwise the *process* is the same. :icon_biggrin:
« Last Edit: April 11, 2016, 08:22:50 pm by shooter »
« Reply #27 on: April 20, 2016, 12:45:27 pm »
some progress, I now have a somewhat better view of mechanical engineers.  I set the board back from the tubes so there would be less PA tube *interaction*, thinking the OT's were not an issue, till I got the wires basically laid out.  So i'll be re-drilling board holes and moving it about 1/2 - 5/8 inch fwd.  Should be testing power by the weekend.
« Reply #28 on: May 01, 2016, 04:03:07 pm »
PS up and running, still need to scope ripple, but meter is showing <20mV on the grid-preamp tap.
:BangHead: errors, the 1st was easy, just a miss-wire, the 2nd, just dumb!, I used a 5k R as load to verify PS, good.  Put in the 6V6's, bad, plate current 85mA, B+ like 220!, then I realized G1 was just floating :cussing:
put in a temp 820k, now * normal* is 268plate, 15.5 bias, Ip 33ish mA. using node B.  moved to node A, 324plate, 19 bias, Ip 40mA.   Probably stay with node B, but I was shooting on paper for 315 plate, 13 bias, 35mA Ip
hopefully have the TS built later tonight then solder in the board and see.
« Reply #29 on: May 07, 2016, 08:55:28 pm »
 :happy1:
She's up and playing, dead quite!, The TS needs a *range* tweak, still gotta do the paperwork.
Thanks to PRR for the 1st *tweak*, the 2 inputs work well, the *guitar* side sounds 5F1-ish, the *aux* side plays albums as well as you can play albums.
Need to scope it, the output sounds thin, but overall it's close enough to *tweak* to taste.
« Reply #30 on: May 08, 2016, 08:33:19 pm »
Need some wiser than me help;
ran initial voltage checks, all the DC appears happy, The AC, mostly;
outta the pre I have clean 55Vac-rms, way more than I need. (used 50mV AC-rms in)
going into the PA grids, I have to *dial* the MV to 13Vac-rms in order to *keep it clean*.  Is that an effect of tube loading, impedance mismatch?
Out of the 6V6's I get 142Vac-rms, but by the time it gets to the speaker it's 6.7Vac-rms into a 10ohm DL, which yields only ~ 4.6W.  Is the *un-common* configuration of the OT to blame? (was expecting 7ish W)
Is there a *normal* OT coupling value?  Like with 100vac in you *should* get 10 out?
(each tube is running about 7.8W plate dissipation)
« Reply #31 on: November 02, 2016, 03:43:44 pm »
I've just discovered this schem ... an HiFish (Hifi & Guitar Amp)
may be your next effort ?  :wink:
http://www.r-type.org/exhib/aaa0711.htm
The VA-12 was designed for both HI-FI and Guitar use.
Ciao
