August 29, 2026, 02:04:19 pm
Hoffman Amps Forum image Author Topic: Doug's 5F6A Bassman Build  (Read 9584 times)
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« on: April 17, 2016, 12:27:56 pm »
Got a question.  I've got the 5F6A started, but I'm currently just trying to attach the transformers etc.  I'm not having luck finding information on this, but it seems the OT I have doesn't match any holes on the chassis.  Is it bigger than what would have originally gone on this build normally?  (I just ordered the entire thing from the site here).  It seems I'll have to drill something.  Which would be better to drill, the feet of the transformer or the chassis?  (If I do the chassis it may be really hard as it's already almost at the edges and there'd be partial drill hole overlap).
~Phil
Phil Davis
tUber Nerd =|D
Re: Doug's 5F6A Bassman Build
« Reply #1 on: April 17, 2016, 03:36:37 pm »
I've got the 5F6A started, but I'm currently just trying to attach the transformers etc. ......  (I just ordered the entire thing from the site here).
Which chassis and which iron set?
Can you post a pic showing the iron set sitting on the chassis?
    • Daviszone
« Reply #2 on: April 17, 2016, 03:58:59 pm »
I'll get a pic when I get home, it's the default ot for the default chassis when you select Doug's complete parts list.
Phil
Phil Davis
tUber Nerd =|D
    • Daviszone
« Reply #3 on: April 17, 2016, 07:24:46 pm »
Here are the pics, one showing the one side lined up, the other showing it not, and then a side shot
https://goo.gl/photos/Lxmf9Jcu6ycJkitn7
Phil Davis
tUber Nerd =|D
« Reply #4 on: April 17, 2016, 07:43:54 pm »
you need this part: 022855
the part you bought is a "universal" 40W with 2/4/8ohm secondaries. doug sells the 022855 part.
if you want 2/4/8 ohm secondaries with the original fender footprint buy the hammond 1760K or classictone 40-18000 - the clssictone is 1/16" narrower on the width centers, but should still fit without any hacking.
« Last Edit: April 18, 2016, 01:21:16 am by DummyLoad »
    • Daviszone
« Reply #5 on: April 17, 2016, 08:22:21 pm »
I guess I'll need to talk to Doug, I'm pretty sure I just accepted the default transformer, but maybe I didn't.
Phil
Phil Davis
tUber Nerd =|D
    • Daviszone
« Reply #6 on: April 17, 2016, 10:58:48 pm »
Yeah I just confirmed by looking at the parts list, it has the transformer I ordered instead of the other, maybe Doug's thinking people will prefer the optional output impedances?  I can likely just adjust the location of the holes for the transformer to make it fit.  I'll double check with him.
~Phil
« Last Edit: April 17, 2016, 11:03:49 pm by pompeiisneaks »
Phil Davis
tUber Nerd =|D
« Reply #7 on: April 18, 2016, 01:24:59 am »
rotate it 90deg and it'll fit. of course new holes will need to be machined. check clearances first.
    • Daviszone
« Reply #8 on: April 18, 2016, 08:55:57 am »
I thin think it will fit, I'll just have to drill new hooks in the feet of the OT,   but if not, I'll do that.
Phil
Phil Davis
tUber Nerd =|D
« Reply #9 on: April 18, 2016, 10:29:35 am »
It's not the stock 2 ohm only tranny
It's multi tap and larger
You will have to drill mounting holes
« Reply #10 on: April 18, 2016, 12:04:32 pm »
I would just use a round file to elongate the holes in the chassis.
    • Daviszone
« Reply #11 on: April 18, 2016, 12:54:12 pm »
Oh excellent idea... lots less painful than trying to get a drill into the side of an existing hole ;)
I was thinking of my dremel as well, but don't know if I have a small bit that size that's a mill type.
Sorry I know this isn't specifically an 'amp' question, but I'd hoped people had some experience with the 'fab' side of the chassis and had ideas here.  Thanks so much!
~Phil
Phil Davis
tUber Nerd =|D
« Reply #12 on: April 18, 2016, 01:46:55 pm »
If you don't have such a file, look in the chain saw section at Lowes.
    • Daviszone
« Reply #13 on: April 18, 2016, 02:07:19 pm »
I have one, but it's also pretty small diameter, so I may have to get one that's more appropriate.
~Phil
Phil Davis
tUber Nerd =|D
« Reply #14 on: April 18, 2016, 02:15:18 pm »
ROFLOL
« Reply #15 on: April 18, 2016, 03:19:15 pm »
perhaps you can drill new holes in the footplate of the OT rather than hack the chassis up?
    • Daviszone
« Reply #16 on: April 18, 2016, 05:02:53 pm »
ROFLOL
It's true.  The chainsaw, when you sharpen them, need a round file ;)
~Phil
Phil Davis
tUber Nerd =|D
    • Daviszone
« Reply #17 on: April 18, 2016, 05:04:43 pm »
Phil
Quote from: DummyLoad
phone corrected 'feet' to 'hooks' or something similar, but yeah that's what I was saying there
~Phil
Phil Davis
tUber Nerd =|D
« Reply #18 on: April 18, 2016, 05:12:56 pm »
I get that, got lots of them, and chainsaws, I just had a *visual* image pop in of you using a chainsaw to elongate the holes :icon_biggrin:
    • Daviszone
« Reply #19 on: April 18, 2016, 05:31:33 pm »
ahh excellent ;) :l2:
Phil Davis
tUber Nerd =|D
Offline Paul1453
« Reply #20 on: April 18, 2016, 07:30:37 pm »
PRR recommended I get a hand held saber saw as a flexible all purpose tool.
Great recommendation, by the way.   :worthy1:
If the little metal blade will fit in the current holes,
you could also use that to elongate the holes.   :icon_biggrin:
« Reply #21 on: April 18, 2016, 07:34:10 pm »
Phil
~Phil
sorry, missed that!  :BangHead:
dictation monkey still on loan to wilabe.  :icon_biggrin:
« Reply #22 on: April 18, 2016, 08:49:21 pm »
Yeah and he's not very good at teaching me how to read.  :BangHead:    :cussing:
All he does is eat more bananas and throw the peals at my cats.    :laugh:
« Reply #23 on: April 18, 2016, 09:46:29 pm »
he's a taunting soul...  :icon_biggrin:
« Reply #24 on: April 18, 2016, 10:43:16 pm »
 :laugh:
    • Daviszone
« Reply #25 on: April 18, 2016, 10:47:31 pm »
Nice lol!  Here she is all mounted up, so you all can rest assured your round file advice was put to work and to heart :D
https://goo.gl/photos/No3id9PCzDnq2E196
 :occasion14: :l4:
Thanks again!
~Phil
Phil Davis
tUber Nerd =|D
