September 17, 2026, 10:52:21 am
Hoffman Amps Forum image Author Topic: Power Supply Mod  (Read 6628 times)
Power Supply Mod
« on: September 12, 2016, 05:21:57 am »
Hi guys, I have a local made amp that I want to mod the power supply.
It's basically a 50w JCM 800, using JJEL34s.
The power supply below is stock and I'm having trouble with the ELs running on 800+ volts.
At the time of the measurements the electricity is at it's peak of 250vac.
A question.........
Why would they need to run the ELs at such high voltage to get an assumed 50w (amp is called a "GUNN 50")
Our local supply usually is between 245 and 250v, so I would think that the PT secondary's would be around 310v.
So I'm thinking to rewire the PT as a full wave rect with an output of approx. 420v with loading.
I need to replace the Ecaps and was wanting to run the ELs at a lower voltage.
Re: Power Supply Mod
« Reply #1 on: September 12, 2016, 06:32:02 am »
800V on old construction EL34 is acceptable, new ones will have problems (big ones)
But .... are you sure the amp is only 50W ?? a pair of EL34 @ 800V will be able to give 100W
Offline Tone Junkie
« Reply #2 on: September 14, 2016, 06:43:13 pm »
Timbo  Geezer had a way of hooking 5 zener diodes to the HV center tap and was dropping about 45 to volts off the supply . Maybe Tubnit will see this and put up a link. Im at work or I would put up the chart I have saved. I don't know why you couldn't use 10 and get 95volts  or so.
Just a thought .
Bill
« Reply #3 on: September 14, 2016, 07:09:04 pm »
Get rid of the bridge recto! Someone mismatched the PT and recto. Wire in a conventional FW rectifier. Probably have to change the bias circuit as well.
« Reply #4 on: September 14, 2016, 08:29:17 pm »
> * GUNN 50.sch
Can someone remind me of the simple free Java(?) program we use to open these things?
I had it before but my PC lost its mind.
« Reply #5 on: September 14, 2016, 08:41:37 pm »
ExpressSCH
« Reply #6 on: September 14, 2016, 09:01:10 pm »
Here's the link for the download from Schematics and Diagrams section;
http://el34world.com/Forum/index.php?topic=590.0
« Reply #7 on: September 15, 2016, 12:34:51 am »
Here the jpg of the file
« Reply #8 on: September 15, 2016, 01:28:26 am »
Thanks guys, PT's got a separate bias tap and at the moment it's set at -38.
Offline trobbins
    • Tim's projects and info
« Reply #9 on: September 15, 2016, 02:01:23 am »
You could run everything at 415VDC - don't use half the HT secondary, and just move the diodes to make a full bridge on just half the secondary.  Simplest initial modification to make me thinks.
« Reply #10 on: September 15, 2016, 06:13:04 am »
So I'm thinking to rewire the PT as a full wave rect with an output of approx. 420v with loading. I need to replace the Ecaps and was wanting to run the ELs at a lower voltage.
Yes, kinda like this...
« Reply #11 on: September 15, 2016, 12:07:37 pm »
That only makes sense if you have a 13K OT.
More likely you have 3,400r OT and should be running 425V on plates and screens.
While you could hack half the winding as TR says, when I try to draw it I get confused.
Especially accounting for the bias-tap (not shown!).
This IS a PT for the standard two-diode rectifier. Lose the bridge.
The caps could be re-organized for the now non-insane voltage.
« Reply #12 on: September 15, 2016, 01:46:32 pm »
Sluckey has nailed it. I have not checked the OT primary impedance yet, i'll do that before hacking the rectifier.
I have quite a few of amps with this psu arrangement and are in the 100w+ output, so I'm looking for a way to reduce the voltage on the valves and the output.
« Reply #13 on: September 18, 2016, 05:14:20 am »
Hi guys, The amp is a clone of a "PLEXI" with a few component changes.
I used the Hoffman Plexi 50 as a guide to the rewiring.
Amp fired up well with a few noise issues, now sorted.
