July 25, 2026, 10:53:41 am
Hoffman Amps Forum image Author Topic: About scraping and painting a power transformer  (Read 10677 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: March 16, 2017, 08:13:42 pm »
I am transforming a solid state MarkBass guitar  amplifier into a small tube amp that I will try to sell. The power tranny I have in stock is kinda rusty and needs to be painted for a better look.
I know the bells can be painted, sanded even drilled with no prob. but what about  the laminations?
Thanks.
Colas
P.S.: call me Alvin.
Re: About scraping and painting a power transformer
« Reply #1 on: March 16, 2017, 10:11:30 pm »
Don't scrape so hard you deform the steel.
Wire brush and Rustoleum should last forever indoors, 5 years in a damp garage.
« Reply #2 on: March 16, 2017, 10:43:30 pm »
Checkout some hits on this page:  https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=rusty+transformer+laminations&*
Laminations are a problem.  They must be insulated from one another, so they are individually coated with varnish.  If the varnish is scraped away and the laminations make physical contact with one another, the performance of the tranny is degraded.  There seems to be more than one school of thought on what, if anything, to do about rusty transformers.
Offline frankenxtein
« Reply #3 on: March 16, 2017, 11:28:05 pm »
I've got a bit of rust on a real nice Thordarson , I don't have a steel brush , lucky me :wink: If it moves salute it , if it doesn't paint it. lol
Offline Beezerboy
« Reply #4 on: March 17, 2017, 02:46:48 am »
air is a poor conductor of flux lines, the laminations are there to focus and "guide" lines of flux.  the chemistry of the steel they use the plates is designed for high permeability and resistivity... it conducts flux lines well and electricity not so well, both characteristics reduce eddy currents. the steel has a natural oxide coat, sometimes they add other coatings.  even if there were no coatings at all.... the effect would still be there simply because the stacked plates are not homogeneous.... the only way to totally eliminate that effect is to weld it all into one monolithic block.
soooooooo........ surface rust on the outside... I seriously doubt there is any detectable difference even with lab equipment. rust on the contact surfaces of the plates down through the core maybe, but I don't see how thats even possible
as for rust making it better.... I doubt that too
« Reply #5 on: March 17, 2017, 03:16:51 am »
A piece of rough woolen fabric and paint diluent, strong rubbing on the laminations
when is dry you can paint it newly
« Reply #6 on: March 17, 2017, 09:10:21 am »
Guess I shouldn't put any cleaners , oils , solvents or "Red Lead" primer on , this Thordarson 26R46 , the only transformer I have with a bit of rust. A little flat black Krylon on the two sides effected would make it look nice again and , shouldn't make it weigh much more.  LOL
Some of the articles "High Temp Paint" lol , If your getting this stuff that hot , rust is the least of your worries eh?
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #7 on: March 17, 2017, 10:46:30 am »
What about some WD or the likes to kill that rust ?!
https://soundcloud.com/ukiuki
« Reply #8 on: March 17, 2017, 11:09:34 am »
I got a little frustrated with a Midshipman that ordered me to put together a crew and paint the deck at 2am, in a nasty squall, so when the ship pitched, he got painted, I got Captains mast, I won :icon_biggrin:
« Reply #9 on: March 17, 2017, 12:38:02 pm »
If you use WD or other oil based, a small part will fall inside the laminations and also if you use diluent after that
you are not sure all the oil comes out and if you paint on oil ..................
BTW, on the old times, lamination were abandoned to rust before to be used on transformers
rust was used as a form of isolation between laminations
« Last Edit: March 17, 2017, 12:40:59 pm by kagliostro »
« Reply #10 on: March 17, 2017, 01:03:08 pm »
Those Midshipman never came near us , V2 division (Cat Crew) CV42 & CV66, the MAA wouldn't even come around. I've always lived in a rough neighborhood , I still do.  :icon_biggrin:
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« Reply #11 on: March 17, 2017, 01:16:59 pm »
I was infantry, in the army, where we were, nobody wanted to be... and as soon as we made it livable, they kicked us out and took it over, and sent us to some other shithole :P
~Phil
Phil Davis
tUber Nerd =|D
Offline Beezerboy
« Reply #12 on: March 17, 2017, 02:57:21 pm »
wire brush or sand, don't worry if you don't get it all. hit it with naval jelly if you like... it has phosphoric acid that converts the remaining rust into a phosphate. then paint. there are other rust killers but mostly all the same.... acid conversion. there are also rust killer paints that have the conversion coating built in.... one I use is Marhide. another good line of products is POR (rumored to stand for Paint Over Rust) which they say you can do. kinda spendy but wow does that stuff stick. or... as mentioned, BBQ grill paint, it seems to be the toughest of the common rattle can paints
« Reply #13 on: March 17, 2017, 04:08:45 pm »
~Phil
+1  Phil
Probably didn't have to paint a lot .... eh?  :wink:
This same topic
http://el34world.com/Forum/index.php?topic=14251.0
 Another even gets to High Temp BBQ paint.
http://www.tdpri.com/threads/painting-transformers.144447/
Unless you gouge the lamination's cleaning one of these up a bit , I can't see how you could damage it , short of , dinging the winding. That varnish is in between the lamination's ?
I have two different spray cans here:
 One is the MalWart $1 gloss black enamel  (alphatic hydrocarbons Ketones, and tolulene) 4 hours between coats ..... Gloss paint dries slow and , this stuff would bond to the varnish ?
The other is Krylon Dual Superbond Paint and Primer  flat black (Acetone,propane,n-butyl acetate,butane,alphatic hydrocarbons,ethyl 3-ethoyxpropionate , xylene) 6 hours between coats 25min dry touch , handle in one hour $4 at MalWart :l3: Not sure what effect this would have.
Only one end on this Thordarson has varnish , the other three sides are bare metal.
The Essex transformer , I'm fixing to use has been painted the same color , you see in photo's , of some Stromberg Carson amps. Not heavy enough to , not see the separations between the lamination's.
I'd guess you could clean off what you can and put a single light coat of paint on it? Maybe transformers dissipate heat through the pretty much unpainted sides. The Japanese transformer I have is painted , not heavy , but you can see it's painted all the way around.
I only have one transformer with rust and the only reason the others aren't painted , I'm lazy  ...  Mature iron is all I have so , this is of interest to me , not cosmetic so much but , ........ rust being okay ........... , sounds like a used car dealer claim.
    • Daviszone
« Reply #14 on: March 17, 2017, 04:12:49 pm »
+1  Phil
Actually I did have to paint our battle signs on our Bradleys before we went in for the big drive across Iraq to Baghdad, and that wasn't fun in the Kuwait heat :P
~Phil
Phil Davis
tUber Nerd =|D
« Reply #15 on: March 17, 2017, 07:33:52 pm »
Having been in the Navy and the Army, painting Bradleys wasn't painting.  Not like the Navy guys mean it, anyway.
(All in good fun; though I did gut & refurbish nearly 300 spaces on a carrier undergoing half-life overhaul.  Navy is forever chipping paint or painting what they chipped.  But Kuwait in the summer is a ..... special experience. As I found out in the Army.)
« Reply #16 on: March 17, 2017, 08:33:35 pm »
For some reason every time the paint cans n needle guns came out my radar system went down :icon_biggrin:
« Reply #17 on: March 17, 2017, 10:31:21 pm »
Worn Out Needle Guns made more noise than chipping anything , Bug Juice ..... Coffee with an oil slick , JP5 showers ,  Palma Majorca  :thumbsup:
Offline Beezerboy
« Reply #18 on: March 18, 2017, 12:37:36 am »
"For some reason every time the paint cans n needle guns came out my radar system went down "
not all paint is radio transparent
« Reply #19 on: March 18, 2017, 08:49:38 am »
I think Shooter meant he would "find a problem" he had to work on instead of chipping and painting.
I would have, anyway.
« Reply #20 on: March 18, 2017, 10:03:23 am »
"find a problem"
Yup!
The cool thing was, Wayne and I were "tweaking" the receiver one "paint day", then did some testing on the tomcats and found we had increased the effective missile lock range of the Radar by almost 30miles over the OEM spec! We couldn't do anything about missile flight time but we could see 'em coming sooner :w2:
