August 01, 2026, 10:12:33 am
Hoffman Amps Forum image Author Topic: Dual 50 Plexi/JCM 800  (Read 83046 times)
Offline purpletele
    • Vallis Enterprises, Inc.
Re: Dual 50 Plexi/JCM 800
« Reply #50 on: March 09, 2019, 09:05:36 pm »
Put all tubes back in, disconnect the NFB wire, and recheck voltage on pin 3 of each power tube.
With NFB disconnected I get 409 V and 407 V
I put it on standby to calculate the bias, set up the meter and now I get an indication of a short from the light limiter.
« Last Edit: March 09, 2019, 09:10:32 pm by purpletele »
« Reply #51 on: March 09, 2019, 09:11:09 pm »
How does the amp sound with NFB disconnected?
Offline purpletele
« Reply #52 on: March 09, 2019, 09:15:58 pm »
I didn't get there, I wanted to set the bias and then play it.  I switched to Standby and clipped my lead onto my 1 ohm resistor and the light limiter started glowing a lot brighter than it had been.
I switched everything off to contemplate
« Reply #53 on: March 09, 2019, 09:22:13 pm »
Which OT do you have? Be specific. Post a link.
Offline purpletele
« Reply #54 on: March 09, 2019, 09:35:17 pm »
I flipped the switch and let the light limiter absorb the rush, it settled down to a normal low glow but it startled me, Shocked would be the wrong word.
As the amp was warming up it jumped in and out of a solid signal and settled to a strong quiet idle.
The amp sounds and plays like it is within the right range of power and touch.
The JCM side sounds real Ice Pickey, the JMP side sounds good, I will try with a single coil and I can tell if the tone is right or thin
I posted the Classictone 40-18025 below.  I don't think i'm shorting out, but I spooked for a second.
« Reply #55 on: March 09, 2019, 09:42:11 pm »
You must have the black wire on the secondary connected to chassis ground. I suggest using the power ground point. Reconnect the NFB wire. If the amp screams then reverse the OT red and blue plate leads.
Offline purpletele
« Reply #56 on: March 09, 2019, 09:47:53 pm »
The black wire is connected to a speaker ground only, I will extend the ground from the jack to the power ground.
I dropped some voltage where everything is at 395 V now.  I described the sequence in the note above.
I'll reconnect the NFB and see what happens.
« Reply #57 on: March 09, 2019, 09:53:30 pm »
Huh? What? Where?
Offline purpletele
« Reply #58 on: March 09, 2019, 09:59:33 pm »
The grounding on the power ground helped with the surge.
The amp is back at 1 volt or less at the plates
**Correction, plate voltage is jumping in and out.
397 V at the fuse OT connection 397 V at the plates.
« Last Edit: March 09, 2019, 10:07:53 pm by purpletele »
« Reply #59 on: March 09, 2019, 10:19:19 pm »
Plug the amp straight into the wall. You don't need the lamp limiter now. Did you swap the OT plate leads? And?
Offline purpletele
« Reply #60 on: March 09, 2019, 10:40:38 pm »
Oh man did it yell at me!!
« Reply #61 on: March 09, 2019, 10:51:22 pm »
Swap the plate leads again.
Offline purpletele
« Reply #62 on: March 09, 2019, 10:59:54 pm »
I must have a bad connection that I cannot find.
After I reset the Plate Leads I was getting 427 V.  I played it for a while and then it dropped out while I was on the JCM side.  It went to 390 V.  The JMP side stayed strong and deep but the JCM side was weak and thin.
After all of that I was checking voltages and my Klein meter kept jumping to AC after I would get a low reading on the Plate.
Funny stuff going on.  I get 1.5 volts on V6 and it goes right to AC mode when I hit pin 3 V4
This amp is winning tonight!  I am beginning to think the OT is failing.  I didn't have any event that would make me think I fried it, but it sure seems suspicious.
« Last Edit: March 09, 2019, 11:15:31 pm by purpletele »
« Reply #63 on: March 10, 2019, 07:21:15 am »
I'm kinda beginning to suspect that meter. I've never had a meter to jump from dc mode to ac mode. every meter I've ever used required you to turn a knob to go from ac to dc. Maybe your Klein wants a fresh battery.
Tell me more about this Klein. Exact model number so I can look up the specs and manual.
EDIT... Never mind. I think your meter has a SEL button to toggle between AC and DC mode. This just sets some logic state in the meter brain. This logic state is being upset when you try to measure the plate voltage on this amp for some reason. If fresh batteries don't fix it, there is likely nothing you can do about that. Try another meter if you have one.
« Last Edit: March 10, 2019, 10:14:21 am by sluckey »
Offline Slimtim
« Reply #64 on: March 10, 2019, 09:29:16 am »
yep never had a meter go to ac from dc either.do you have a spare or borrow one from someone for a few quick tests?
Offline purpletele
« Reply #65 on: March 10, 2019, 09:53:51 pm »
I changed the batteries in my Klein meter.
Fired the amp up, here is the sequence:
1. Once it is warmed up I get 465 v on the plate.
2. Pull off and measure V5 Plate and the voltage is on a sequence voltage drop, but it goes from 465 to 1.25 Volts and then drops at a decimal at a time until it is less than a volt.
Then I get disgusted and turn it off.
I think I fried the transformer with the bias trim pot being backward.
« Reply #66 on: March 10, 2019, 10:12:17 pm »
You gotta ask why that Klein only misbehaves when you have the NFB wire connected? Seriously, try another meter before you order an OT.
If I had that amp and also had a super duper 50W Plexi (probably with the same OT), I'd temporarily swap OTs.
Offline purpletele
« Reply #67 on: March 10, 2019, 11:21:46 pm »
I'll try another meter tomorrow.
Said What??  My super duper Plexi is working great, don't want to disturb the mojo.
Thanks for the help
Offline purpletele
« Reply #68 on: March 14, 2019, 03:13:08 am »
Back In The Game
I had tested the plate voltage with another meter, but it was a cheapy.  It had just kind of redlined and didn't know how to react.
I had to let it go for a few days, but I did order a spare.
I performed a test bench retrofit of a new OT, (I didn't mount it).  The amp warmed up and was in quiet idle at 400 V on V6 and 315 on V5.  That didn't look promising.
I disconnected the NFB and I have a steady 410 V at each plate and the bias is steady at 44 mV.
Summary:  I am not sure that the OT is fried, but the new one that is hooked up temporarily is at least holding a voltage while the NFB is connected.
NFB: My first thought is do I have the bias system hooked up correctly.
Bias: At 410 V I set the bias at 43 mV but I am bottoming out on the low end adjustability on the bias system.
Tone: The amp plays well on both channels.  The tone for each channel is reflective of its design.  I didn't have a chance to turn up the MV, but at lower levels the amp sounded distinctly like a JCM 800 and a 1987x and it sounded nice.
The amp feels like it is operating at 92%.  The NFB is obviously an issue.  I have posted a new photobelow.
« Reply #69 on: March 14, 2019, 03:42:04 am »
short? see area circled in red in attachment.
Offline MFowler
« Reply #70 on: March 14, 2019, 08:45:18 am »
I don't like the looks of many of the solder joints on the turrets looks bare of solder to me.
Mark
« Reply #71 on: March 14, 2019, 09:08:26 am »
Your 1Ω bias resistors mounted on the sockets don't appear wired correctly. The correct way to wire them is to jumper pins 1 and 8 together. Then connect the 1Ω resistor between pin 8 and chassis ground (preferably use the power ground point). Do this for each tube socket.
Offline purpletele
« Reply #72 on: March 14, 2019, 11:18:46 am »
Thanks Pete,
Those turrets are close, but I can slide a straight edge between the gap, so nothing is touching.
Offline purpletele
« Reply #73 on: March 14, 2019, 11:20:57 am »
Thanks, I'll try that this afternoon.
The amp is sounding nice, it's almost there.
BV
BV
Offline purpletele
« Reply #74 on: March 14, 2019, 02:32:11 pm »
Thanks, I'll make that change now.
BV
BV
Offline purpletele
« Reply #75 on: March 14, 2019, 07:20:43 pm »
Afternoon Tests
I changed the 1 Ohm resistor for V5 and V6, I used a solder post to tie the ground and the 1 ohm resistors together.
Things are still wonky:
1. With the NFB disconnected the voltage starts at high 300's and bleeds voltage like a metronome.
2. If you play it when it first heats up is sounds good, after a few minutes it is real tinny and you can tell the voltage has dropped.
3. When I measure the voltage after playing it is really low and continues to drop decimals of voltage while powered up.
4. If I start up with the NFB connected, then the voltage is low to start, mid 300's and it drips away like a faucet.
Photos of the grounding on the power tubes.
Thanks for any ideas.  It took me a while to dream up this issue. :happy2:
« Reply #76 on: March 14, 2019, 07:47:38 pm »
with the NFB
the dripping, and metronome are with your ears, or meter?
without any tubes in, monitoring your "last" tap VDC, what happens in 15min With NFB, and 15min Without NFB
Offline purpletele
« Reply #77 on: March 14, 2019, 07:54:13 pm »
with the NFB
I have a meter on it and visually watching the voltage drop.
I'll test it.
Offline purpletele
« Reply #78 on: March 14, 2019, 08:16:36 pm »
with the NFB
Shooter I get the following:
514 V on the plates with the NFB connected
517 V on the plates with the NFB dis-connected
« Reply #79 on: March 15, 2019, 07:04:24 am »
so put all the pre tubes in and repeat
if it's steady, add the PA tubes, repeat, somebody, or some thing is sucking current and it should be getting mighty warm.  did you fix/replace your sketchy meter?
Offline purpletele
« Reply #80 on: March 15, 2019, 06:29:07 pm »
Busy day at the Jungle today.
I'll do the steps as suggested.  I changed the batteries in the Klein.
I was looking at the following as a second meter:
https://www.amazon.com/SSEYL-FLUKE-Digital-Multimeter-F17B/dp/B00SF3SQ50/ref=sr_1_fkmrnull_1?crid=3LFK3V3IKEV6E&keywords=fluke+17b%2B&qid=1552692307&s=gateway&sprefix=fluke+17b%2Caps%2C205&sr=8-1-fkmrnull
These meters look like they are built in Asia somewhere and built for the Amazon market.  Any other recommendations?
Offline purpletele
« Reply #81 on: March 16, 2019, 12:38:20 am »
493 V NFB Connected Pre-Amp Tubes installed   Voltage is steady and not dropping
495 V NFB Dis-Connected Pre-Amp Tubes Installed. Voltage is steady and not dropping.
475 V NFB Connected Power Tubes installed.  Voltage drops like a Zeppelin
475 V NFB Connected Power Tubes Installed. Voltage drops like a Zeppelin.
BV
« Reply #82 on: March 16, 2019, 10:04:22 am »
It's time to beg, borrow or buy another meter to be sure, same check.
If it still drops without NFB, I'd be inclined to swap out the tubes, then the filter cap feeding the PA tap.
« Reply #83 on: March 16, 2019, 10:12:59 am »
I'm suspecting some HF oscillation when NFB is connected is confusing his meter. There's just no way for voltage to really drop that much without seeing some smoke somewhere. Probably need a scope to prove/disprove my suspicion.
« Reply #84 on: March 16, 2019, 02:02:19 pm »
that's why I put in the 15min disclaimer  :icon_biggrin:
I suspect you're correct since he didn't mention any smoke
Offline purpletele
« Reply #85 on: March 16, 2019, 03:05:23 pm »
No smoke, and I let it run for at least 15 minutes.
How did I get a case of High Frequency Oscillation and what should I do to correct that?
« Reply #86 on: March 16, 2019, 05:30:23 pm »
you know the gremlin with the spiked hair smoking a cig, that's the guy you're after  :icon_biggrin:
typical, positive feedback, induced signals, bad DC filtering, harmonic tubes.  I've chased him a few times, he's a B :cussing: ch to kill  :icon_biggrin:
« Reply #87 on: March 16, 2019, 07:04:08 pm »
a shot in the dark: try removing the plate to plate (47pF SM) cap from the LTPI - it's the cap connected from pin 1 to pin 6 on the LTPI tube.
you may have a high(er) level preamp signal in proximity to a lower level preamp signal and they are relatively in phase.
an oscilloscope really helps to troubleshoot these kinds of issues.
pull the the LTPI tube and power up - is B+ stable? if yes, then LTPI or something before the LTPI is the issue. if B+ is not stable, then the issue is with the output stage.
Offline purpletele
« Reply #88 on: March 16, 2019, 10:03:14 pm »
Pete,
I get the 475 V and then it drops immediately as before.
BV
« Reply #89 on: March 16, 2019, 10:21:37 pm »
what does it drop to - e.g. bottoms out at?
Offline purpletele
« Reply #90 on: March 17, 2019, 01:05:14 pm »
The voltage dropped quickly to 335 V.
It has stayed at 335 V for about 4-5 balls in the water at 17.  (15 -20 minutes)
BV
Offline purpletele
« Reply #91 on: March 19, 2019, 11:10:14 am »
How do you resolve such a matter and what would create a HFO?
« Reply #92 on: March 19, 2019, 11:32:26 am »
I don't know that it's even an issue. It may only occur when you put your meter probe on the plate socket pin. I've had amps that would emit a screeching/arcing sound when my meter was connected to the plate of one tube but would behave quite well when connecting to the other tube plate. Never resolved that. Just said to self, don't do that.
So, other than this plate voltage issue, how does the amp behave otherwise? Sound good, bad, or ugly? Any red plates?
« Reply #93 on: March 19, 2019, 12:09:16 pm »
yup, same!  My 100X probe ALWAYED messed up plate readings.  I just made my I readings via Rk and accepted the math, and audio measurements at speaker.
Offline purpletele
« Reply #94 on: March 19, 2019, 01:31:19 pm »
The amp sounds decent for maybe a minute, then it drops voltage and gets real thin and tinny.
« Reply #95 on: March 19, 2019, 02:46:06 pm »
are you wired like the layout on page 1, reply 8?  specifically the "A" cap?
If so can you clip your meter + on cap, - on chassis (Not a stud, or ground point, just gator-clipped to chassis metal), set for VAC and watch it from power on, for ~~~~5min or so
« Reply #96 on: March 19, 2019, 06:32:53 pm »
Is this happening with your meter hooked up?
Or is it getting thin sounding and your thinking it's because the voltage has dropped?
Offline purpletele
« Reply #97 on: March 19, 2019, 06:51:10 pm »
Is this happening with your meter hooked up? Or is it getting thin sounding and your thinking it's because the voltage has dropped?
It does happen when the meter is hooked up.
I can also not be on the meter and just play it after it warms up, it sounds full then it shifts gears and feels real thin and tinny, that timing is consistent with the meter readings of the voltage.
Thanks for thinking about it.
Offline purpletele
« Reply #98 on: March 19, 2019, 06:53:37 pm »
I thought that would be the next suspect.  I'll run the test and get back.
Thanks for the input.
« Reply #99 on: March 19, 2019, 06:58:54 pm »
IS this what doesn't happen;
in other words; it works fine without meter?????
