September 14, 2026, 04:57:16 pm
Hoffman Amps Forum image Author Topic: More 6G15 questions  (Read 3962 times)
Offline prongster
More 6G15 questions
« on: September 27, 2021, 02:53:58 pm »
I came across a thread which discussed placing snubber caps in parallel with the diodes in the rectifier circuit, claiming this reduced the switching noise of the diodes and produced a quieter build, yet I haven’t seen any other reference to this - has this been made moot by the use of the bridge, or is there any other reason not to do this?
https://music-electronics-forum.com/forum/amplification/guitar-amps/theory-design/14066-ss-rectifier-hum-magic
Also, I’m thinking about using blue Sozo caps instead of the Xicons for the coupling caps…is it fairly straight forward to increase the spacing of the turrets in the board editor to accommodate longer caps?
Re: More 6G15 questions
« Reply #1 on: September 27, 2021, 03:21:10 pm »
... snubber caps in parallel with the diodes in the rectifier circuit, claiming this reduced the switching noise of the diodes ... has this been made moot by the use of the bridge ...
The same switching noise exists whether you have a half-wave, full-wave, or full-wave bridge rectifier.
If you want to use the snubber caps, add them across each section of the bridge (or bridge-package).
