August 03, 2026, 03:26:40 am
Hoffman Amps Forum image Author Topic: Vox Ac 15 vibrato problem  (Read 29141 times)
Offline rafaelctt
« on: June 04, 2022, 12:28:51 pm »
Hello!! I hope I don't bother you with my questions. Thanks in advance. I have built a Vox AC 15 from the year 1960 and I am facing the following problem. The clean channel works perfectly but the vibrato channel has a very low signal and also does not modulate. I have made different measurements and the result is that of the attached image. Could you help me understand it? Thank you
« Last Edit: June 04, 2022, 12:36:07 pm by rafaelctt »
Re: Vox Ac 15 vibrato problem
« Reply #1 on: June 04, 2022, 12:59:34 pm »
I drew that schematic. Did you also use my board layout?
The footswitch contacts must be closed to enable the oscillator. IE, the bottom of R68 and R65 must be connected to ground.
The normal channel is noticeably louder than the vibrato channel. That's just the way it is.
Offline rafaelctt
« Reply #2 on: June 04, 2022, 01:04:41 pm »
Thanks for answering. I am sure that the clean channel must sound much louder, but the vibrato with maximum volume, is heard very low and does not have a vibrato effect.
Offline trobbins
    • Tim's projects and info
« Reply #3 on: June 04, 2022, 06:27:58 pm »
Did the amp work properly before, and this problem just happened?
Offline rafaelctt
« Reply #4 on: June 05, 2022, 01:16:57 am »
No, I am finishing building this amplifier, and I am in the testing stage.
Offline rafaelctt
« Reply #5 on: June 05, 2022, 03:49:26 am »
The vibrato sounds already!! The problem is that I have to turn the volume to maximum and it sounds very low and with a lot of distortion. What has me concerned is the 32V voltage at pin 1 of V4 (Ecc82). According to the colleague who made this version, there should be the same voltage on pin 1 and pin 6 of V4. I attach an image. In blue my measurements and in red those of the previous one.
Thank you
« Last Edit: June 05, 2022, 03:52:15 am by rafaelctt »
« Reply #6 on: June 05, 2022, 04:27:53 am »
Something seems fishy, I suggest to verify the values of R35,36,37.
Offline rafaelctt
« Reply #7 on: June 05, 2022, 05:00:48 am »
I just measured the values ​​of the three resistors R35,R36 and R37 and they are correct.
With SW4 open, the voltage on pin 1 of V4 goes up about 8 V and it sounds louder.
« Last Edit: June 05, 2022, 05:15:21 am by rafaelctt »
Offline trobbins
« Reply #8 on: June 05, 2022, 05:33:42 am »
Have you swapped tubes?  Apart from the obvious anode voltage difference on V4, have you confirmed appropriate LFO AC voltage (measured from a scope, as a meter is unlikely to give an accurate rms voltage) on top of R45, and also top of R32 and R33?
« Reply #9 on: June 05, 2022, 05:57:42 am »
Let's see a hi-rez pic that shows V1 and V4 and the section of the board that contains the modulator components. Pic needs to clearly show components so we can read values. We also need to see all the components between V1 and V4.
Offline rafaelctt
« Reply #10 on: June 05, 2022, 06:13:28 am »
At this moment I don't have another Ecc82, only Ecc83 from other parts of the circuit.
The oscilloscope voltages that I obtain are: 2.90 rms in R32, 3.02 rms in R33 and 10.3 rms in R45. These measurements are with SPEED at halfway and DEPTH at maximum
Offline rafaelctt
« Reply #11 on: June 05, 2022, 06:17:18 am »
<a href='https://postimg.cc/tYHtPK91' target='_blank'><img src='https://i.postimg.cc/VLJGywTF/medidas-tensiones-vibrato-para-foro-2.jpg' border='0' alt='medidas-tensiones-vibrato-para-foro-2'/>[/url]
« Reply #12 on: June 05, 2022, 06:57:21 am »
This means post a PHOTOGRAPH of the inside of your chassis, not the schematic.
Offline rafaelctt
« Reply #13 on: June 05, 2022, 07:43:59 am »
« Reply #14 on: June 05, 2022, 01:19:22 pm »
If it is not the plates, and common cathode, then look at the grids.
Resistance from pins 2 and 7 to ground? Examine all solder joints closely.
Offline rafaelctt
« Reply #15 on: June 05, 2022, 01:39:16 pm »
Are you referring to V4?
I measure 1.3M resistance
« Last Edit: June 05, 2022, 02:15:48 pm by rafaelctt »
« Reply #16 on: June 05, 2022, 02:46:53 pm »
What dcv do you measure on pin 2 and pin 7 of V4?
Offline rafaelctt
« Reply #17 on: June 05, 2022, 02:53:02 pm »
3,45 V  1,78V
« Reply #18 on: June 05, 2022, 03:24:42 pm »
Pull V6 to kill the oscillator. Now what dcv do you measure on pin 2 and pin 7 of V4?
Offline rafaelctt
« Reply #19 on: June 06, 2022, 05:21:35 am »
Do you mean extract  v6 from the socket or just disable sw4(open sw)?
« Reply #20 on: June 06, 2022, 07:07:01 am »
extract
Offline Latole
« Reply #21 on: June 06, 2022, 08:51:03 am »
It is the picture or ?
Offline rafaelctt
« Reply #22 on: June 06, 2022, 09:22:47 am »
connected to power point D via jumper
Offline rafaelctt
« Reply #23 on: June 06, 2022, 09:24:06 am »
extract
Extracted the V6 and the problem of the voltage difference continues
Offline Latole
« Reply #24 on: June 06, 2022, 09:38:29 am »
Why I did not see a wire ?
« Reply #25 on: June 06, 2022, 09:42:34 am »
The jumper is under the board. Here's the complete docs, including a board layout...
     http://sluckeyamps.com/VAC15/Vox_AC15.pdf
Offline Latole
« Reply #26 on: June 06, 2022, 09:50:27 am »
Thank you sluckey, now I see.
« Reply #27 on: June 06, 2022, 09:52:34 am »
OK, so just to make sure you know where I'm headed... That 3.45V on pin 2 is causing the voltage on pin 1 to be low. I'm trying to find the source of that 3.45V. I'm gonna do this one step at a time so we can stay on the same page, so don't get ahead of me. Leave V6 tube out of the socket. Now unsolder and lift one end of C24. What is the voltage on pin 2 now?
Offline rafaelctt
« Reply #28 on: June 06, 2022, 10:45:45 am »
Sorry, I don't see that 3.45V on the schematic. Right now I'm not near the circuit, I'm working. I will do it as soon as possible and we keep in touch. Thank you
« Reply #29 on: June 06, 2022, 10:59:07 am »
The 3.45V ain't on the schematic! YOU measured that 3.45V on pin 2 yesterday. THAT'S A PROBLEM. Do as I say and we will soon find out why that 3.45V is on pin 2.
Offline rafaelctt
« Reply #30 on: June 06, 2022, 11:47:55 am »
ok, i will do it as soon as possible. Thank you
Offline rafaelctt
« Reply #31 on: June 07, 2022, 12:20:21 am »
pin2     4V
« Last Edit: June 07, 2022, 02:03:33 am by rafaelctt »
« Reply #32 on: June 07, 2022, 04:32:09 am »
pin2     4V
So, with V6 extracted and C24 disconnected you still have 4V on pin 2? Extract V4. If pin 2 now reads 0V replace V4 with a good 12AU7. If you don't have a 12AU7 then use a 12AX7 while you are waiting for a 12AU7 to arrive.
Offline rafaelctt
« Reply #33 on: June 07, 2022, 06:09:39 am »
Ok, so I will do it, in fact I have prepared an Ecc83 to be able to put it provisionally. What measurements should I do when I insert it?
« Reply #34 on: June 07, 2022, 06:47:12 am »
Answer this question. Does V4 pin 2 read zero volts when V4 is extracted?
Offline rafaelctt
« Reply #35 on: June 07, 2022, 06:53:08 am »
I'll measure it and tell you
Offline rafaelctt
« Reply #36 on: June 07, 2022, 10:06:50 am »
yes, 0 volts
« Last Edit: June 07, 2022, 10:10:22 am by rafaelctt »
« Reply #37 on: June 07, 2022, 10:30:41 am »
Offline rafaelctt
« Reply #38 on: June 07, 2022, 10:43:55 am »
In agreement.
What measures do you recommend me to measure once replaced?
« Reply #39 on: June 07, 2022, 11:33:12 am »
Measure V4 pins 1, 2, 3 and 6, 7, 8. Is the sound better?
Offline rafaelctt
« Reply #40 on: June 07, 2022, 11:44:07 am »
I'll do it when I get home and write down the result here.
Thank you very much
Offline rafaelctt
« Reply #41 on: June 07, 2022, 02:44:01 pm »
1   :60v
2   :2v
3   :3v
6   :60v
7   :2v
8   :3v
« Last Edit: June 08, 2022, 12:26:05 am by rafaelctt »
« Reply #42 on: June 07, 2022, 04:30:49 pm »
Looks like the voltage readings are good now. How does it sound?
Are you using a 12AU7 for V4?
Offline rafaelctt
« Reply #43 on: June 08, 2022, 10:07:20 am »
I am using 12AX7 and I have measured again and on pin1 there is 95v and on pin6 110v. It is NOT stable and varies constantly. The vibrato channel sound is still weak and distorted.
« Reply #44 on: June 08, 2022, 10:11:18 am »
That's quite different from what you posted yesterday.
Offline rafaelctt
« Reply #45 on: June 08, 2022, 11:03:02 am »
Yes, it is very different. The supply voltage was very low (about 280 V) so I secured the valves and now the voltage is 315 V (normal) and with that value the measurements are the ones I have set. In addition, they do not remain at a fixed value but vary a few volts up and down.
Offline rafaelctt
« Reply #46 on: June 08, 2022, 11:04:43 am »
The clean channel sounds great, although there are clicks
« Reply #47 on: June 08, 2022, 11:11:26 am »
I’m stuck getting my head around how 2V on the grids is ok? They look to be referenced to 0V common to me, with no other obvious DC source there to pull them above that.
Offline rafaelctt
« Reply #48 on: June 08, 2022, 12:09:02 pm »
I have simulated the entire amplifier and if I get voltages that oscillate around 2V
« Last Edit: June 08, 2022, 12:26:02 pm by rafaelctt »
« Reply #49 on: June 08, 2022, 01:12:30 pm »
Are you sure that’s a VDC (average) measurement, eg rather than instantaneous?
One grid looks to be -2V, the other +2V.
