September 08, 2026, 04:40:10 pm
Hoffman Amps Forum image Author Topic: Confused!!  (Read 6312 times)
Offline Snake5150
Confused!!
« on: October 20, 2024, 08:39:30 pm »
So I understand that there will be continuity between the heater wires and ground due to the ct of the pt.
I also believe that the same thing across the speaker ours occurs. But I’m confused with the jack switching of the output.
With a cable plugged in will there still be continuity across tip/sleeve? Or should the cable be opening that connection so that they are now isolated from each other.
Single output jtm 45.
8 ohm to tip
Center tap, ground, and nfb to sleeve.
Am I correct?
Offline Latole
Re: Confused!!
« Reply #1 on: October 21, 2024, 04:13:31 am »
Re: Confused!!
« Reply #2 on: October 21, 2024, 10:14:39 am »
His question was not answered.
He wanted to know if there is 'continuity between tip to ring.'
Why he want's to know that?  :dontknow:
« Last Edit: October 21, 2024, 10:20:06 am by Willabe »
Offline Latole
Re: Confused!!
« Reply #3 on: October 21, 2024, 10:20:02 am »
Why he want's to kn ow that?  :dontknow:
Question is ; " With a cable plugged in will there still be continuity across tip/sleeve "
Answer is on his second post for same subject
Re: Confused!!
« Reply #4 on: October 21, 2024, 02:05:00 pm »
8 ohm to tip
Am I correct?
No.
There is no CT on an OT's secondary. And the nfb is tapped from the tip, + signal, not the sleeve, ground connection.
Re: Confused!!
« Reply #5 on: October 21, 2024, 02:12:06 pm »
It is not answered, what you and pdf64 posted was ohms, not continuity.
I get it, but because of what he asked and the way he worded it, I don't think he will understand.
He asked about continuity, not resistance/ohms. Yes, where there's resistance there will be continuity, but I don't think he'll get that.
Offline Snake5150
Re: Confused!!
« Reply #6 on: October 21, 2024, 03:48:48 pm »
No, I believe I understand. Thank you all for the help. My statement about negative feedback to sleeve was a typo and from my post I’ve gathered that continuity Between tip and sleeve is normal
 I have also gathered that at no time Should any output secondary tap Be grounded.
.8 ohms between tip at ring So all is well thanks again
