September 08, 2026, 04:42:07 pm
Hoffman Amps Forum image Author Topic: 1 watt plate resistors.  (Read 6304 times)
Offline joesatch
  • save me from myself.
« on: March 18, 2025, 02:45:37 pm »
i was told from various sources that 1 watt plate resistors are fine. Well these 1 watt metal film i have are tiny!  are you folks sure 1 watt metal film is enough? these things are the size of a grain of rice
Offline pullshocks
Re: 1 watt plate resistors.
« Reply #1 on: March 18, 2025, 02:57:33 pm »
I just installed some of those, so I sure hope so….,
« Reply #2 on: March 18, 2025, 03:27:20 pm »
bust out a breadboard, a 'lil math, test for smoke  :icon_biggrin:
Offline joesatch
« Reply #3 on: March 18, 2025, 04:34:16 pm »
i have doubts
« Reply #4 on: March 18, 2025, 04:44:01 pm »
Some years back, over at Kevin O'Connor's tube amp forum, guys were having trouble with the small body resistors in the B+ power supply. They couldn't take it and were dying.
They went back to the larger body R's and then no more problems.
I don't trust them, the small sized body R's.
« Reply #5 on: March 18, 2025, 07:41:37 pm »
Also check the voltage rating of resistors that you are wanting to use where there are big voltage swings
Offline AlNewman
« Reply #6 on: March 18, 2025, 07:46:32 pm »
For plate resistors, I think they're fine.  As power or dropping resistors, I'm not so sure.  I use them quite a bit and haven't had a failure yet.
Offline joesatch
« Reply #7 on: March 18, 2025, 08:07:29 pm »
gonna use them in V1 and V2 plates. hopefully no issues. if i have trouble sleeping i'll pull em
« Reply #8 on: March 18, 2025, 10:50:49 pm »
Offline joesatch
« Reply #9 on: March 18, 2025, 11:56:58 pm »
« Reply #10 on: March 19, 2025, 01:26:11 am »
350V  probably not enough fml
350v is okay for a preamp plate or cathode load resistor given the likely range of voltage swing. Wouldn’t use them as single bleeder resistors in the power supply tho.
Offline pullshocks
« Reply #11 on: March 19, 2025, 02:22:30 pm »
Well, they look smaller than what I'm used to, but not *THAT*   bad
Time will tell on the longevity.....
« Reply #12 on: March 21, 2025, 09:27:54 pm »
i was told from various sources that 1 watt plate resistors are fine. Well these 1 watt metal film i have are tiny!  are you folks sure 1 watt metal film is enough? ...
The resistor's power-rating is about temperature-rise.
"When this resistor dissipates 1 watt, the body-temperature will not rise more than ____ degrees."  And we de-rate the resistor to dissipate less than its rating to keep it cool.
The implication is something about this resistor's construction enables it to throw off heat-to-the-air faster/better than older designs, such that it does not need a big surface-area to lose heat to the air via convection (or as-much surface-area as older designs).
If you want to use a 5w resistor because you like the size & look, you can use a 5w resistor.  Or get used to some newer ones being a lot smaller than what you used in the past (and assume you're gonna need a meter to verify their value, because reading the color codes is impossible).
Offline Guy77
« Reply #13 on: March 23, 2025, 07:02:20 pm »
Just as a reference. I have been inside several two rock 100 watt amps and they use the tiny 3mm x 8mm KOA CF resistors on the plates of several preamp tubes.
They hold up fine and they are only 1/2 watt.
Here is the data sheet on them
https://www.mouser.ca/ProductDetail/660-CF1-2C683J
I was surprised when I saw them too!
Cheers
Guy
« Last Edit: March 23, 2025, 07:05:48 pm by Guy77 »
