September 08, 2026, 04:40:53 pm
Hoffman Amps Forum image Author Topic: LND 150 FX loop pcb  (Read 6565 times)
Offline joesatch
  • save me from myself.
LND 150 FX loop pcb
« on: May 02, 2025, 08:06:52 am »
Getting tired of ordering these things from Australia. Takes too long and expensive. Anyone have a source for a zero loss FX loop pcb? Not fully populated for $80 but just the pcb
Offline Rontone
  • Ixnay on the Ampscray
Re: LND 150 FX loop pcb
« Reply #1 on: May 02, 2025, 09:38:02 am »
Tubetown have this
https://www.tubetown.net/ttstore/en/kit-seriel-fx-loop-lnd150.html
I cant see if that is including parts
« Last Edit: May 02, 2025, 09:41:22 am by Rontone »
Offline joesatch
« Reply #2 on: May 02, 2025, 01:46:52 pm »
they're in the UK. i need USA. takes too long and shipping costs too much plus tariff nonsense.
« Reply #3 on: May 02, 2025, 02:05:14 pm »
Your time has come joesatch! This is your startup moment. Set yourself up in one of the old Peavy plants.
« Reply #4 on: May 02, 2025, 02:23:59 pm »
i might be able to put you in touch with folks that have one of the 'ol Gibson plants in Kalamazoo  :icon_biggrin:
Offline joesatch
« Reply #5 on: May 02, 2025, 02:26:32 pm »
i know this forum is mostly clean amps but for high gain stuff you need an LND fx loop where y'all get yours? you dont make your own you drop the $90 for a metro one? it's like $10 in parts
« Reply #6 on: May 02, 2025, 02:52:03 pm »
$10 parts plus your ingenuity, and sell it for $29.95!
(Whoopsie - Is the $10 parts subject to tariffs? Sell it for $49.95)
Offline Rontone
« Reply #7 on: May 02, 2025, 03:07:28 pm »
I did another search but looking at images and different shops came up, there's Granger in the US selling populated ones, and says limited stock, but perhaps they may be able to sell bare PCB's, might be worth contacting them
Otherwise its cheapy chinese ones from KLD on Reverb site, but yeah, there's not much out there
Tried looking for "layout" in the search but only this LND150 Overdrive FX Pedal came up
https://forum.pedalpcb.com/threads/2x-lnd150-od.16532/
I'm sure you could work on a small tagboard / holeboard layout for this, there more parts than the overdrive pedal in the link above but its a lot less than some of your guitar layouts you have worked out and built
Offline pullshocks
« Reply #8 on: May 02, 2025, 03:19:53 pm »
I got an FX loop that was really excellent from a guy on SLOCLONEFORUMS.COM.  Not sure if he still offers them.
Offline joesatch
« Reply #9 on: May 02, 2025, 03:40:41 pm »
i gotta start making my own pcb's i did have the necessary files to order from JLCPCB  but that was a IIC+ board. Also relay boards, folks charging way too much for those . stuff that cost a few bucks.
Offline scstill
  • https://stillampd.com
    • Still Amp'd
« Reply #10 on: May 02, 2025, 04:31:49 pm »
Never built one of these
I have a lot of pedals but don't usually use them as I prefer just the guitar and amp.
But as I researched this fx loop has become appealing.
What do you think about my first time trying this China kit?
https://reverb.com/item/42638093-fx-loop-of-tube-guitar-amp-by-lnd150
could I breadboard into an existing amp for experimenting?
Is the schematic here correct? or is there a better one?
« Last Edit: May 02, 2025, 04:38:30 pm by scstill »
Offline Rontone
« Reply #11 on: May 02, 2025, 05:34:11 pm »
Some other schematics and a lot of good info on LND150, starting about Reply #32:-
https://el34world.com/Forum/index.php?topic=10208.0
« Reply #12 on: May 03, 2025, 09:44:14 am »
Our host Doug sells relay PCB's in his store, their $2.50 for 1 to 9 boards, their $2.00 for 10 and up. His relay power supply boards are $6.00 for 1 to 9 boards, $5.50 for 10 and up. And there's a 16 pin relay socket he sells for $0.60. You use those with the relay board, you pull 8 of the pins to use it.
It's a good deal.
I think Mojo musical was selling them too, Doug supplied them.
Here's the link to the page in Doug's store with them;
https://hoffmanamps.com/MyStore/catalog/parts20.htm
« Reply #13 on: May 03, 2025, 09:54:55 am »
Here's the link for his socket and relay install tips. He goes though how to build them/solder them up. Has great close up pics of them.
Read all the way to the bottom of the page.
http://www.el34world.com/projects/relay_switch.htm
With the relay power supply boards, he has them set up so you can use either, an axial lead or a radial lead electrolytic filter cap.
« Reply #14 on: May 04, 2025, 08:00:26 am »
And the kit Doug sells, with both boards and all the parts, including mounting hardware is $22.33.
https://hoffmanamps.com/MyStore/catalog/Relay_Single_Relay_Board%20and%20Power%20supply%20parts.htm
Offline acheld
« Reply #15 on: May 04, 2025, 10:36:32 am »
I use Doug's relay boards all the time  --  they are cheap and work great.
His power supply boards are also inexpensive and are versatile.   You can wire them up as a straight up 5VDC power supply, or as a voltage doubler.   Or 12VDC supply -- just depends on your parts.
You can't go wrong.   Well, maybe . . . :icon_biggrin:
« Reply #16 on: May 08, 2025, 04:59:08 pm »
Nien! Deutschland!
-Pete
Offline tristanc
« Reply #17 on: May 10, 2025, 05:00:57 pm »
I made my own LND150 FX loop PCB. The KICAD source and gerbers are here: https://github.com/tristancollins/Guitar-SolidStateFX/
This has board mounted jacks and a pot, intended to be supported by those when in the chassis. I’ve used this design on two builds - seems to work well. As it should - it’s Merlin’s series loop, but made with sand.
Feel free to get some made (the $10 PCBway deal or similar) and share if others are interested.
