September 08, 2026, 04:41:13 pm
Hoffman Amps Forum image Author Topic: Fender Twin Reverb AB763 Stock Bias Range Insufficient  (Read 39244 times)
Offline omalikular
« on: September 17, 2025, 11:28:25 pm »
I purchased a '65 Fender Twin Reverb/AB763 recently as it has long been a dream amp of mine. Previously I opened up and saw it had been recapped at some point and important resistors converted to metal film and was satisfied. After a few months I decided time to roll new tubes and discovered that they previous owner had 6V6 tubes in the power section. I swapped them back to 6L6 and found that I was unable to bias them above 19ma plate current. My bias with the pot was from about -64V to -44V.
At first I figured perhaps it had been modified to better accommodate the 6V6 tubes, however I have been unable to determine why the current is so low. Resistors all measured within spec. No unexpected continuity errors. All values within the circuit appear to be matching to the schematic, including the bias feedback and range resistors. Transformers are correct model numbers. Diodes in rectifier and bias circuit look good.  I asked the previous owner and he only ever biased for the -52V bias voltage.
Voltage from wall outlet was 121V AC, Two 8 ohm JBL 120 speakers connected as load
340v tap 349.5V AC
48v tap 50.27V AC
Setting Bias voltage for -52 before bias range resistor change
Bias Voltage -52.04V
B+1 471.5V
B+2 469.5V
Plate voltage 469.5V
Grid -51.0V
Plate current= 8ma
After changing bias range resistor on bias pot from 22k to 10k resistor aiming for 37ma
Bias negative= -36.02V
B+1 455.5V
B+2 455.3V
Plate Voltage 452.2V
Grid -35.2V
Plate current=37ma
All measurements are with 6L6 tubes in circuit. I used a Variac to drop to 117V at one point but it did not impact current enough to account for differences. Bias was measured using a bias one probe from Eurotubes. 6L6 tubes are a matched set.
I was able to get the plate current where I wanted with no red plating by changing the bias range resistor, but I'm wondering if this is an indicator of some other issue that I have failed to determine, and have only bandaged. I'm still new to tube amps and perhaps the voltage values above indicate something that I fail to understand?
Appreciate any help on this!
Offline Merlin
Re: Fender Twin Reverb AB763 Stock Bias Range Insufficient
« Reply #1 on: September 18, 2025, 02:58:08 am »
Have you ruled out the 6L6s themselves? New or used? What brand? If they are are very worn out it would account for it.
« Reply #2 on: September 18, 2025, 03:23:19 am »
If they had 6V6s in there, they would’ve goosed around with the bias range I’d say. So good on you for changing it back.
I’m assuming all 6L6 tubes in the quad are now within the same tube-current ballpark?
Offline omalikular
« Reply #3 on: September 18, 2025, 07:10:58 am »
All tubes are new production Tung-Sols and are brand new. They are a matched set and are pulling the same current.
Exactly what I figured; that it was made to accommodate 6V6. However, it wasn't unusual for folks to just run 6V6 in these amps without modifying the circuit from what I've seen, and I have been unable to spot any changes. The part that confuddles me is that I had to move the bias out of spec to get current to not be so cold. -35V on the grid is far outside the -52V approximation these would typically have.
Offline omalikular
« Reply #4 on: September 18, 2025, 07:15:59 am »
I did wonder potentially about maybe the OT being adjusted in some way. I measure the windings for about 38 ohms while doing the voltage drop method. The transformer is fender stamped 125A29A, but these have different load configurations. Is it possible that they swapped this for another to get a load mismatch to account for the 6V6? Would a mismatched load be enough to account for the differences?
« Reply #5 on: September 18, 2025, 10:08:12 am »
Cooling off bias is one way of bringing a load line back under the Pmax curve but it’s better to go for optimum load impedance. If  it hasn’t got a standard fender twin OT in there, you should do an impedance test - simply measuring DC resistance with an Rmeter won’t tell you anything. You need to determine the Pr:Sec VAC ratio by supplying one of the windings with a known VAC and measuring the other one. (edit: VAC^2 = impedance)
« Last Edit: September 18, 2025, 10:20:34 am by tubeswell »
Offline stratomaster
  • Don't guess, measure.
« Reply #6 on: September 18, 2025, 10:49:30 am »
What is your screen voltage measured at the socket, not B+2?
Offline omalikular
« Reply #7 on: September 18, 2025, 11:57:59 am »
Latest voltage measurements:
B+1 457V
B+2 454.1V
Screen 452.3V
Plate 453.5V
Grid -35.2V
Offline SEL49
« Reply #8 on: September 18, 2025, 12:28:26 pm »
That's a very good bias voltage range for healthy 6L6s in a TR amp.
Offline omalikular
« Reply #9 on: September 18, 2025, 01:09:34 pm »
Correct,however this range would not supply the 6L6 with enough current. I had to increase bias voltage to -34 to get to 70percent dissipation.
« Reply #10 on: September 18, 2025, 02:17:04 pm »
I think your math is off. You said you measured 38 ohms from CT to primary
I=V/R = 3.5V/38Ω = 92mA
P = IV = 0.092A*453.5V ≈ 42W
That's about 140% dissipation.
Offline omalikular
« Reply #11 on: September 18, 2025, 02:39:23 pm »
I'll double check after work, I know my last check before above measurements was bias probe current at 37. I did OT CT to standby, my measurement could be wrong.
Offline omalikular
« Reply #12 on: September 18, 2025, 06:04:05 pm »
No idea where the original number came from... I'm getting 97 ohms.
3.5V / 97ohms= 36ma
.036A * 453.5V ≈ 16.8W
« Reply #13 on: September 19, 2025, 02:30:28 am »
3.5V / 97ohms= 36ma
38 ohms seems high, 97 ohms seems nonsense.
Just to be clear, it's the resistance of the OT primary wires, red to blue, and red to brown, that are needed to derive anode current.
38 ohms seems more like the brown to blue resistance, but even then it's a bit higher than expected.
The relevant readings should be about half that, eg 19 ohms.
https://www.hammfg.com/files/parts/pdf/1750W.pdf?v=1697661946
Fitting 1R cathode current sensing resistors would avoid all this confusion.
The transformer is fender stamped 125A29A, but these have different load configurations. ...
What do you mean by 'different load configurations'?
Offline omalikular
« Reply #14 on: September 19, 2025, 10:57:29 am »
This is on me for my lack of experience, I've been using Rob Robinettes bias guide to determine the windings and not properly understanding the electronics. I had previously gotten 97 ohm measure red to standby. With the transformer still in circuit, I'm getting Red-Blue Red-Brown of 38 ohm.
The bias probe accomplishes this doesn't it? This is what I'm using to get the 37ma current. I'm just trying to determine why to get this reading I have to increase my negative bias voltage to -34V, out of the typical ~-52V.
As far as I understand, this transformer is available for 4, 8, 16 ohm loads in mind, looking at after market replacements at least. The only reason I considered that it may be configured for a different load is the fact it has been running 6V6 tubes for who knows how long.
« Reply #15 on: September 19, 2025, 02:39:14 pm »
This is on me for my lack of experience... With the transformer still in circuit, I'm getting Red-Blue Red-Brown of 38 ohm.
This means the math in my post is valid and you're over dissipating the tubes by biasing them way too hot.
Offline omalikular
« Reply #16 on: September 19, 2025, 03:01:01 pm »
I did consider that previously when I'd done the math, as I had gotten the results similar to you of being hot. But I relegated that to some failure on my part, since the cathode resistor insertion with a bias probe gives .037V, and this is how I've biased other amps. Also the tubes don't look like they are running too hot...
« Reply #17 on: September 20, 2025, 12:08:31 am »
Based on the measurements you've provided, the simplest explanation is that you're unintentionally idling your tubes too hot.
If your voltage measurements are correct and complete, then I can only conclude the resistor in your bias probe is significantly off from 1Ω.  Try measuring the resistance of the probe with nothing in it.
Failing that, I'd be tempted to do the output transformer shunt method to determine the plate current, but that has fallen out of favor in recent years. So proceed with that at your own risk.
« Reply #18 on: September 20, 2025, 12:36:18 am »
For the few cents-worth of 1R1% cathode bias measuring resistors, you can avoid a lot of incorrect measurements
Offline omalikular
« Reply #19 on: September 20, 2025, 01:15:29 am »
This is the current plan, will update once I get these put in.
Offline omalikular
« Reply #20 on: September 26, 2025, 10:24:56 pm »
Just finished installing the 1R1 resistors, getting .04V reading  :w2:
« Reply #21 on: September 27, 2025, 12:10:06 am »
0.04V = 40mV
I suggest you put your V-meter on the 'mV' setting. Then you will get an even more accurate reading
What Plate voltage have you got?
« Last Edit: September 27, 2025, 12:13:56 am by tubeswell »
Offline omalikular
« Reply #22 on: September 27, 2025, 12:13:23 am »
Yeah... Just seems to disagree with bias being too hot. Not sure why I need -34V bias voltage to get this current, but good is good I guess?
« Reply #23 on: September 27, 2025, 10:00:56 am »
And what is your screen dcv?
Offline omalikular
« Reply #24 on: September 27, 2025, 03:05:23 pm »
Screen is 450.5V
Plate is 452.2V
« Reply #25 on: September 27, 2025, 04:06:22 pm »
I stand by my earlier statement that there is a math/measurement error, and these tubes are being punished.
There should be agreement between the output transformer voltage drop method and the cathode current sense resistor with the cathode resistor giving a slightly higher current number.  The difference here is almost 2x.  Something else is happening.
« Reply #26 on: September 27, 2025, 04:14:49 pm »
Assuming you are running 6L6GC rated at 30W Pmax (as you didn't say whether you were running 6L6GC or 5881s)
You measured cathode voltage at 0.04V (If you take the cathode voltage measurement with your V-meter set to 'mV', we possibly could get  slightly more accurate cathode current estimation.)
To get a plate current estimate for a 6L6GC from measuring the cathode current, you can assume 5mA screen current, and since cathode current = plate current + screen current, this leaves 35mA plate current.
452.2V x 0.035A = 15.8W
15.8W/30W = 53%
If your measurements are correct and if you are running 6L6GC, you could easily warm them up a bit
« Last Edit: September 27, 2025, 04:19:38 pm by tubeswell »
« Reply #27 on: September 27, 2025, 05:42:14 pm »
Yes there should, assuming the OT voltage drop measurement and the OT primary resistance measurements have been made accurately - and that 2-plates'-worth-of-voltage-drop has been measured across each OT primary half
(However, given the OP has reported a voltage of 0.04V at one of the cathodes - albeit with a 1R 1% resistor - there is still some ambiguity about what the cathode current is. It could be 0.045V or 0.036V, with the '10s-of-volts' setting not able to provide enough decimal places for a decent readout).
« Last Edit: September 27, 2025, 05:44:24 pm by tubeswell »
Offline omalikular
« Reply #28 on: September 27, 2025, 06:01:19 pm »
High precision mode on multimeter says .039V
« Reply #29 on: September 27, 2025, 06:09:55 pm »
Well then, that’s 39mA cathode current on that tube you measured. Is that the same on each tube? Or ?
The sum of cathode current for each pair on each side of the primary should correspond to the total current measured across each half of the OT primary plus the screen current for each pair, I.e., for each half of the OT primary;
2.Ik = 2(Ip + Ig2)
« Reply #30 on: September 27, 2025, 06:32:12 pm »
2.Ik = 2(Ip + Ig2)
Then the math error is mine. I forgot this was a 4 x 6L6. That accounts for the 2x discrepancy.
I have no idea what is causing the bias voltage to be so far from the expected range then. Screen voltage lines up.
Offline omalikular
« Reply #31 on: September 27, 2025, 06:35:30 pm »
All the tubes are matched, I am getting .037V-.039V range across each one of the resistors individually
« Reply #32 on: September 27, 2025, 07:29:29 pm »
So assume a screen current of 5mA for each 6L6, and subtract that from the cathode current for each tube, and the plate current (for each tube) will be what’s left over.
Then do the plate voltage x plate current equation* for each tube to get each tube’s plate dissipation. A good number for a twin reverb is 60 to 70 percent of 30W. When you get that, button it up and call it done.
*Remember that the units in the equation are Volts and** Amps (so 39mA needs to change to 0.039A in the equation)
**But the equation is Volts x Amps = Watts  ;-)
It doesn’t really matter what actual control grid voltage is required to get there - different batches of tubes may naturally run hotter or colder depending on production stats etc, and so the amount of bias voltage required to get to a happy place will vary somewhat between batches.
« Last Edit: September 27, 2025, 07:48:06 pm by tubeswell »
Offline omalikular
« Reply #33 on: September 27, 2025, 09:50:17 pm »
Appreciate all the well written responses. I do feel like I've got what I need for the bias, and yeah bias is adjustable because it the variance of tubes. Ultimately what had me end up here is I would expect the stock bias range to be sufficient for that variance, without needing to change the resistor on the leg of the bias pot. I had figured that this could be an indicator of something wrong, either by my calculations or my amp itself.
The 6V6 tubes also had me wondering for that reason. But if the voltages and currents are getting me dissipation I guess I just role with it  :laugh:
Offline omalikular
« Reply #34 on: September 28, 2025, 02:56:21 pm »
Well the plot thickens... After deciding to roll with it, I noticed my V7 and V8 tubes are red plating... Measuring .037V and 453V plate on them.
Offline omalikular
« Reply #35 on: September 28, 2025, 03:06:13 pm »
Swapping tubes the red plating followed, but I do see very slight red plating in the dark on the others that weren't full on red plating noticibly
« Reply #36 on: September 28, 2025, 03:28:13 pm »
You say above 6V6.  ^ ^ ^ ^
Which do you have in the amp, 6V6 or 6L6?  :dontknow:
Big difference in those 2 types of tubes.
Offline omalikular
« Reply #37 on: September 28, 2025, 03:30:08 pm »
The original post started with me rolling tubes and discovering it had 6V6 tubes. I swapped to 6L6 tubes, that is what I'm currently working with.
« Reply #38 on: September 28, 2025, 08:23:14 pm »
This could be because these two tubes either aren’t bonafide 6L6s, or they could be 6L6s that have already been run badly previously (or are old worn out ‘NOS’ tubes) and have deformed grids etc that mean that they should be thrown away.
If your measurements are correct, these tubes are running at 16.7W, which is cold for 6L6s, but too hot for 6V6s
Can I ask, what makes you think these are redplating? You don’t necessarily need to be in the dark to see red plating (but you might not see normal red heater filament glow in broad daylight).
« Last Edit: September 28, 2025, 08:28:29 pm by tubeswell »
Offline omalikular
« Reply #39 on: September 28, 2025, 08:44:48 pm »
Attached an image. Potato phone camera quality! These are new Tung Sol 6L6 STR. Bias probe is in but it red plates without it.
« Reply #40 on: September 28, 2025, 08:49:16 pm »
Okay that is red-plating.
If your voltage and current measurements are correct, these must be very poor quality tubes.
Have you got the same negative DC voltage on every 6L6 grid pin*? (pin 5)
*never mind what the RI schematic test point says, you need to measure the actual tube socket pin voltage (in case there is a fault somewhere on the PCB)
« Last Edit: September 28, 2025, 09:01:28 pm by tubeswell »
Offline omalikular
« Reply #41 on: September 28, 2025, 09:45:29 pm »
-34.89V - red plating
-34.89V - slight red plating
-34.92V - slight red plating
-34.91V - red plating
« Reply #42 on: September 28, 2025, 10:58:01 pm »
Okay, next thing to check is how fresh is the battery in your meter?
And confirm you have 1R 1%tolerance resistors installed between each 6L6 socket cathode pin and the ground return. (And not 1.1R or ‘1R1’ as that would make a 10% error in the calculation)
« Last Edit: September 28, 2025, 11:25:27 pm by tubeswell »
« Reply #43 on: September 28, 2025, 11:48:40 pm »
Hold your horses!
Are you making these measurements through your bias probe? Because that could be giving you a false indication if that has a 1R resistor installed between the cathode return wire and the ground if you have also installed 1R resistors at each tube socket!  (Depending on how the probe is wired, you might be getting 1R||1R , which would be half an ohm - over which you are measuring 0.037V , which would be 74mA!
Offline omalikular
« Reply #44 on: September 29, 2025, 12:17:14 am »
I do see what you are saying but no that is not the case :D I had removed the 1R resistor for this tube exactly for that reason. This probe does have the 1R resistor setup, I had realized that earlier. I did it as more of a sanity test, to confirm all my readings with the bias are accurate. I'm soldering the 1R back in on this tube. All four have the 1R.
« Reply #45 on: September 29, 2025, 02:54:05 am »
When you use your R-meter to ohm-out the 1R on the tube socket, do you get 1 ohm (after the DC-resistance of your probes is deducted)?
Offline Merlin
« Reply #46 on: September 29, 2025, 10:59:15 am »
I am wondering if this amp is oscillating ultrasonically and that is why the grid bias voltage is bizarrely low when the cathode current appears to read normal?
Offline SEL49
« Reply #47 on: September 29, 2025, 11:31:57 am »
Checking the bias with no tubes should answer that.
« Reply #48 on: September 29, 2025, 11:40:33 am »
Pull the PI and check the bias, unless the oscillation is in the power amp.
Offline omalikular
« Reply #49 on: September 29, 2025, 12:48:54 pm »
.99-1.01 when subtracting the .15 internal resistance of the probe.
