September 08, 2026, 06:33:49 pm
Hoffman Amps Forum image Author Topic: Fender Twin Reverb AB763 Stock Bias Range Insufficient  (Read 39302 times)
Offline omalikular
Re: Fender Twin Reverb AB763 Stock Bias Range Insufficient
« Reply #50 on: September 29, 2025, 12:58:51 pm »
Pull the PI and check the bias, unless the oscillation is in the power amp.
To confirm: leave in the power tubes, pull V6 phase inverter tube, and check bias voltage or current passing through the cathode?
« Last Edit: September 29, 2025, 01:03:24 pm by omalikular »
Offline omalikular
« Reply #51 on: September 29, 2025, 02:17:28 pm »
I have
.038V across 1R
-35.30V Screen
-36.20V Negative bias at the 220k junction
With PI pulled
Offline omalikular
« Reply #52 on: September 29, 2025, 02:18:54 pm »
I will say now that I'm in high precision mode I see a .03 fluctuation on these negative bias voltage measurement...is that normal or an indicator of an oscillation?
« Last Edit: September 29, 2025, 02:36:53 pm by omalikular »
Offline SEL49
« Reply #53 on: September 29, 2025, 04:00:52 pm »
It's time to bite the bullet and put a fresh set of 6L6s in the amp.
« Reply #54 on: September 29, 2025, 04:27:05 pm »
I'd be concerned about repeating the experience with yet another new set of tubes. It seems something fishy is going on with the bias. I'm wondering whether it could be something dodgy to do with the PCB traces - given it's one of those modern reissue jobs, and the amp has obviously been tinkered and meddled with before (with parts being pulled and substituted). I've seen several re-issue fenders with cracked/bad PCB traces that have needing jumpering to get the things to work. Hairline cracks in traces can cause oscillation. Given the seeming insolvability of this, I'm thinking if it were my amp, whether it might be more satisfactory to completely gut the innards and install traditional eyelet board setup etc complete with new pots and jacks and so on. $1,000 bucks worth of parts and work but at least you could exert complete control over the quality.
Offline omalikular
« Reply #55 on: September 29, 2025, 05:00:08 pm »
Oh this is not a reissue, this is from '65
Offline Calboy
« Reply #56 on: September 29, 2025, 06:07:27 pm »
Were the bias capacitor(s) and bias diode updated?
What about setting the bias at 30ma per tube.
Offline omalikular
« Reply #57 on: September 29, 2025, 06:29:29 pm »
All the original capacitors in the amp were replaced with orange drops  and modern electrolytics, though an unknown time ago. At 30ma at each tube it still red plates. I get in to the low 20s before it really stops red plating. Unsure of the diode, I did a test with the multimeter and it drops the expected voltage and drops .58V
« Last Edit: September 29, 2025, 06:44:07 pm by omalikular »
« Reply #58 on: September 29, 2025, 07:30:53 pm »
Sorry I misread the '65 Fender Twin Reverb in your first post - my bad.
Is there anything else we don't know about your amp? (Like - has anyone added g-k caps to the output put tube sockets? or other possible modifications that could explain the bias conundrum?) Can you upload some hi-res gut shots?
« Last Edit: September 29, 2025, 07:36:11 pm by tubeswell »
Offline omalikular
« Reply #59 on: September 29, 2025, 09:03:08 pm »
Traveling for work for a couple days. I grabbed some old pics from the listing, the only thing different is the caps on the normal channel were replaced and the 1 ohm resistors added.
Offline omalikular
« Reply #60 on: September 29, 2025, 09:07:58 pm »
More closeups
« Reply #61 on: September 30, 2025, 01:05:52 am »
Have to tested the 2  x 0.1uF couplings caps going to the 6L6 grids for DC-leakage?
Offline Merlin
« Reply #62 on: September 30, 2025, 04:33:42 am »
His grid voltage is the same as his bias supply voltage, so the coupling caps are fine. Anyway that wouldn't explain why his tubes are red plating with only ~30mA plate current.
« Reply #63 on: September 30, 2025, 05:31:21 am »
Maybe something is wired incorrectly? How else can there be red plating with only 37mA cathode current? How can current get to the plate other than through one of the other electrodes (cathode, screen, suppressor or grid)?
« Reply #64 on: September 30, 2025, 06:41:11 am »
haven't followed close so;
does this amp have flyback diodes on the plate?
has the tubes been verified good in another amp?
The bias was verified at the grid, was it verified at the the tube side of sockets?
guessing this is all being troubleshot at DC level...No AC signal, has the OT primary been ohmed for partial shorts?
Offline stratomaster
  • Don't guess, measure.
« Reply #65 on: September 30, 2025, 09:17:27 am »
Appears to be missing the artificial center tap as there is no filament center tap to ground. Confirm this with measuring the resistance of one leg to ground when powered off though. Some of these early 60s PTs have internally grounded filament CTs. Haven't seen it on a Twin Reverb though--but most of my experience with TRs is post '68...aka What my clients can afford.
The bias filter cap looks like it's several decades old.  Its worth investigating. Put your meter in Vac and check if you have significant ripple riding on the bias voltage. You may have a 60Hz AC spike to low voltage that the DC measurements aren't picking up. (Grasping at straws with that one.)
The OT is definitely aftermarket, so that carries the risk of it being improper spec and installed incorrectly.  You can try disconnecting the NFB at the speaker jack and rechecking bias to see if it was oscillating above audible frequencies which is causing the red plating. If this causes the bias to behave and the tubes to stop red plating, then reverse the secondaries and reconnect the NFB.
Finally, I always replace tubes that have a history of red plating.  I would want a fresh set in there after you've fixed the problems, regardless. So perhaps have a set on order.  This isn't as thoughtless a suggestion as it was even 10 years ago with the pricing being what it is now vs then.  But in my experience, once they pop the fun don't stop--so a clean slate is warranted after the servicing is complete.
« Reply #66 on: September 30, 2025, 02:31:52 pm »
That would answer my earlier question thanks. UHF oscillation from an incorrectly wired NFB loop can cause thermal runaway in the output tubes
Offline omalikular
« Reply #67 on: October 01, 2025, 02:48:30 pm »
So to confirm, disconnect this red highlighted wire?
« Reply #68 on: October 01, 2025, 03:23:20 pm »
Yes
Offline omalikular
« Reply #69 on: October 01, 2025, 03:55:02 pm »
-35.8V at junction of 220k
-35.0V at grid,
38.4ma plate current
I do hear 60Hz hum noticeably...
« Last Edit: October 02, 2025, 12:15:59 pm by omalikular »
Offline omalikular
« Reply #70 on: October 01, 2025, 04:04:47 pm »
When you say leg, do you mean like one of the green transformer wires to filament to ground?
Vac at the negative bias resistor junction I get 118.8mV
Measurements above, and still red plating.
Waiting on new tubes as well.
« Reply #71 on: October 01, 2025, 05:52:33 pm »
You'll probably notice less hum if you replace that old bias supply cap.
Offline omalikular
« Reply #72 on: October 01, 2025, 09:22:52 pm »
My heart of hearts told me I should just recap all the filter caps at the beginning of this... just to eliminate the possibilities. I'll start with the bias supply cap but might as well order them all with the incoming shipping  :laugh:
« Reply #73 on: October 02, 2025, 09:22:17 am »
120mV ripple is actually not that bad for a bias supply. It'll be audible, but only noticable if you're looking for it. I'm still a big fan of a smaller cap on the wiper to create a 2nd stage on these bias arrangements. Fender does 100μF and 22μF on the reissues. I've settled on 47μF or 50μF and 8μF on the pot.
Glad your red plating isn't ripple related, but we're starting to run out of easy solutions.
« Reply #74 on: October 02, 2025, 11:04:51 am »
-35.0V at screen,
Measure at the tube socket for the -bias dcv.
And why do you have negative dcv/-35.0 on the screens?
And when you post voltage numbers, say if it's AC or DC.
Offline omalikular
« Reply #75 on: October 02, 2025, 12:14:57 pm »
-35.0V at screen,
Sorry at Grid not Screen! Been troubleshooting between travel, been hectic. Yes all voltages are DC above.
Offline Merlin
« Reply #76 on: October 02, 2025, 12:54:19 pm »
Running out of ideas. Pin 1 of some power tube models is connected internally, is pin 1 wired up to anything it shouldn't be?
« Reply #77 on: October 02, 2025, 03:34:35 pm »
-35.0V at screen,  ...
And why do you have negative dcv/-35.0 on the screens? ...
Must be a typo. Maybe he meant '-35.0 on the grids'?
« Reply #78 on: October 02, 2025, 03:36:54 pm »
Wait til you get the new output tubes in. If they still redplate under these conditions, then it's something you've missed telling us. We can only work with the information you give us on-line.
Offline omalikular
« Reply #79 on: October 14, 2025, 10:53:39 pm »
New tubes and we are good to to go. New dog house and bias caps won't hurt.
