July 09, 2026, 02:14:01 am
Hoffman Amps Forum image Author Topic: Standel 25L15-Do you like it as is or would you like to change something  (Read 19839 times)
Offline wsscott
I've always been a great fan of Chet Atkins, and loved the sound of his Gretsch's and his Standel 25L15 studio amp.  When I was a teenager, they were a rarity, but considered as the Holy Grail where I lived.  So I've recently been thinking of building a replica.  I've found what I think to be is a pretty accurate schematic, and the circuit looks pretty simple.  The amp just has 1 channel, 25 watts, 15" JBL P130 speaker, and Volume, Bass and Treble pots.  I don't play gigs, but I have a couple friends that do, and so I would be building this for the fun of doing it, but also making it available to buddies to use.
So I'm hoping I can get some input from those who own or have used this amp, and can give me some thoughts on things they like, or would like to change or have added to the amp.  It's designed for 807 power tubes, and I've never seen those in an amp.  I've read that 6L6's could be used instead.  But would that affect the sound that I really like.
If it was going to be used by someone who has a studio for an amp that players could use when recording, would it be an attractive addition to the studio, and is there something more that the amp needs or should have that would make it even more attractive for a studio.
Thanks for your comments.
just guessing, but..
pretty sure 90% of that sound you like, came from the mans fingers n soul...
HotBluePlates is the man to talk to.
To build one, you need the right information; the result will be a truly, truly clean amplifier, t'hat was the purpose of that amp
As far as I'm concerned, building one and then modifying the design wouldn't be worth the effort.
Offline Banjan73
Power transformers and output transformers? Can you get some similiar ones as the original?
I believe those two components has a LOT to do to a spesific sound of an amp.
Offline wsscott
Yes, I'm pretty sure I can get the transformers with the proper specs.  Agreed on their impact on sound.
I've talked to a couple of buddies who gig, and they said one thing they would like is a switch to adjust the wattage of the power output because they play in different venues where a 25 watt amp might be too much.  So a switch that could change the wattage to 5W, 15W, and 25W for example.
I think this is something different than an attenuator.  I think maybe Marshalls have something like this.  I know I've seen it on some amps, but I don't know what's going on.  I'll do some research.
To maintain the original tone I don't think a VVR will be appropriate expecially with the 25L15
To me the right way will be an attenuatore, but a very good one
can you post the schematic, i've looked at about 1/2 Doug's n their all sand.
Offline wsscott
Shooter-sorry but I had to sign a NDA and can’t share it.
 :laugh:
it is tube though?
self biased or fixed?
Offline wsscott
Yes, its all tubes, cathode/self-biased, running 807 output tubes as the original.
I've always been a great fan of Chet Atkins, and loved the sound of his Gretsch's and his Standel 25L15 ... It's designed for 807 power tubes, and I've never seen those in an amp.  I've read that 6L6's could be used instead.  But would that affect the sound that I really like. ...
If you use the original 807s, you have the hassle of top caps but you can buy NOS 807s all day long for half the price of some Chinese 6L6s.
That said, you can ditch the top caps and use 6L6G/GB/GC/5881 as you please without any significant effect on the amp's sound.
Chet Atkins, not Eddie Van Halen, right?  Who cares if "25w" is too loud, because you simply turn down the Volume control.
You will also find the amp's Tone Controls use negative feedback, and the amp is extremely-clean sounding unless you turn Treble & Bass full-up.  That being the case, there is zero benefit to "reducing power output."
Further, the design of the entire amp is geared to "Clean, Clean, Clean."  Each stage of the preamp and power amp handles a larger signal than the stage before, so that no stage is over-driven.
Standel 25L15 Inspired Amp
It's been a minute...
The most important change was that I added Bias Adjust and Bias Balance lifted essentially verbatim from the Williamson Amplifier (R14 through R22).  Adding some meter pin jacks, I can install any two 807s and have them exactly biased up rapidly.
If you use a JBL D130 (and not a paper-dome version), you may find the upper treble a little steely.  I added a Vox-like Cut control at the phase inverter output to reduce extreme high-treble as desired.
There is a T-filter that imposes a fixed midrange-scoop.  What if you want more/less midrange?  I added a control that reduces the amount of scoop by adding a 1MΩ pot between Ground and the resistor-to-ground in the T-filter.
What if you don't like the center-frequency of the mid-scoop?  That was a little more complicated:  I added a dual-pot and a pair of build-out resistors that allowed the resistance of the pair of resistors forming the "Top of the T" to be changed; this changes the center-frequency of the scoop.
... I've found what I think to be is a pretty accurate schematic, and the circuit looks pretty simple.  The amp just has 1 channel ...
There are really 2 channels, 2 Volume controls.  But one is hidden on the underside of the preamp chassis, and they share the T-filter and Tone control section.
I didn't need 2 channels, so I ditched the input 12AX7 and used a 7-pin 6AV6 (or 6AT6 if desired).  Once again, you can buy NOS all day long for cheap, cheap cheap.
If you want to go on the cheap there are G-807 and if you want to go cheaper than that, 1625
Main design points we know;
1. Real class A 25w power amp with 807 tubes (6L6GB with different pinout/bottle).
2. There's 2 chokes in the power supply.
3. Each stage can take more input power then it's given, so it doesn't distort.
4. 15" JBL D130
5. T filter mid range scoop.
6. NFB around the tone controls.
Questions about design still not clear;
1. Do we know how many and what type/# of preamp and PI tubes?
2. And which type of PI?
3. NF around the power amp?
4. Grid bias for power tubes?
Offline wsscott
HotBluePlates-If you use 6L6GC's instead of the 807's, what changes to its wiring would be needed?  Obviously you would no longer have the anode cap to deal with, and it would free up some space, so might make the build more efficient.
12AX7 (1 stage per channel) ---> 12AT7 ---> 12AU7
Split Load / Concertina / Cathodyne. (pick your favorite name)
No.
It's a cathode-biased amp.
Octal socket instead of 5-pin socket.
No other changes necessary.  You're not trying to get higher power output from the 6L6GCs, even if the tubes themselves can dissipate more heat.
Offline wsscott
HotBluePlates-would you still add the Bias Adjust and Bias Balance pots if you use the 6L6GC's instead of the 807's?
Offline wsscott
Maybe it’s just a single pot to balance the tubes so that the bias point for both tubes is the same.
So, I think HBP made his adjustable grid bias and balance to match up nos 807 tubes he bought?
Offline wsscott
BHP-If you wanted to use an OT with 3 taps and selectable for 4, 8 and 16 ohms, what would you recommend on how to wire the circuit?  Would this affect the NFB circuit?
Also is the T-filter that you refer to a Prescence control, or something else?
Objection:  Asked and Answered, because
An amp does not need to be fixed-biased to have bias-adjustment, and an amp does not need to be fixed-biased to have bias-balance.  Click the links guys, and look at the schematic.
... Would this affect the NFB circuit?
No.
No Negative Feedback around the power section.
Guys... you're killing me with the repeated questions about stuff that was already answered.  Maybe that "pretty accurate schematic" ain't so accurate?
When I built my example of the 25L15, I received information on the circuit from someone who was provided access to an original by a collector, and documented every detail of that particular amp (there is a possibility that other individual examples were tweaked for their original buyer).  Now the 25L15 is not "magic" and you can cop the sound close-enough using a blackface Fender amp set for a clean sound.  But the only negative feedback in the amp is inside the preamp to make the Treble/Bass controls function.  Apparently Bob Crooks didn't feel power section negative feedback was necessary to damp the speaker.
Offline wsscott
I've noticed on a lot of older amps, ie. from the late 50's to mid-60's, like the Standel, and the Valco/Gretsch/Supro, and probably some others, that the chassis' were made with their ends being made with blocks of wood instead of the aluminum/steel of the chassis being bent up to form the end pieces like the rest of the chassis.
Any thoughts on why they did it that way.  Was it to provide for a solid mounting surface that wasn't of a conductive material, and maybe helped avoid ground loops?
Offline passaloutre
I think it’s just easier to manufacture. I’ve made chassis this way, with old safe deposit boxes, cut to length and plugged at each end with blocks of wood. Inspired by my Supro Thunderbolt.
Also, why is everyone always so cagey about this schematic? These amps are 60 years old.
« Last Edit: March 18, 2026, 03:54:43 pm by passaloutre »
... Also, why is everyone always so cagey about this schematic? ...
In my case because:
... I received information on the circuit from someone who was provided access to an original by a collector, and documented every detail of that particular amp ...
Right or wrong, the gentleman who provided me the information on this amp asked that I not make it public.  He was concerned he might get sued by the modern Standel company (as unlikely as that is/was).
I gave him my word, so that's that.
Offline wsscott
I've thought of adding a Presence pot to the circuit.  Any thoughts on that?  Any suggested circuit layout to use?
Thanks.
Offline passaloutre
If there’s no negative feedback, then you can’t use a traditional presence control.
It sounds to me like this amp (assuming you can get your hands on an accurate schematic) doesn’t require any changes. I’d try it as is before trying to shoehorn mods in there.
« Last Edit: March 20, 2026, 01:12:27 pm by passaloutre »
found this in the "public" domain
might not be the mystery amp but is is a pic n you can color on it:)
Offline wsscott
No that’s got a bridge rectifier and it’s running EL84’s not the 807’s and the 5U4.
The schematic for the preamp is in the wild, seems to be accurate. The power supply is  built on hollow state recto 5u4g. Build that and you're at 90% of the original. Use Hammond hi-fi OT with NOS 6L6GB tubes to circumvent the 807 and plate cap cautions.
--Pete
« Last Edit: March 21, 2026, 03:47:21 am by kagliostro »
You would have to add negative feedback around the power section to implement a Presence control (that simply reduces negative feedback at high frequencies).
When used with a JBL D130 with an aluminum dome, the amp/speaker combo has plenty of top-end presence.  I did the exact opposite of what you're considering, by adding a way to reduce treble at the phase inverter to offset the D130's brightness.
wsscott has an accurate schematic already.  I forgot, but he obtained it from the same source as I did.
Offline wsscott
What type of non-electrolytic, 600V caps would you use in a build of this Standel, ie. polypropylene, polyester, 715P or 716P, Orange Drop, Mallory, etc.?
You mean for coupling caps?
I used no-name polyester coupling caps.  They do the job well enough, are not overly-large, and the amp sounds good!
Offline wsscott
Thanks.
Offline wsscott
Since I'm considering using 6L6's instead of 807's for the output tubes, I want to resolve my concerns over the issue of arcing between the Plate and Grid of the 6L6's, which I understand was one of the reasons that the 807's were used in this amp.
Is that really a concern anymore?  I haven't seen any numbers for the Plate voltages on this amp, so I don't know if it runs that much hotter than other 6L6's do in an amp like this.
The specs for the Output Transformer show 60W, 6600 ohm, CT, 200ma.
Any thoughts?
There is no issue of arcing between output tube elements in the 25L15.
I don't know why Bob Crooks chose to build his amps with 807s instead of 6L6s.  There is nothing about the amp's behavior that makes use of the 807's higher plate voltage rating.
Offline wsscott
OK, let me ask a dumb question-certainly not my first.
In Reply #13 above, its commented that this is a Class A amp.
Would someone please tell me what makes this a Class A amp and not a Class AB?  Is it just the wattage?
Offline Banjan73
If you look at "sound" as a sinuscurve (one frequency), class A amplifies 360 degrees of that, while AB cuts it in half (180 degrees). This means that the output tubes rests half of the cycle (class AB). In class A there is "full power" all the way..
Offline Banjan73
Nope.
I will habe to correct myself.
That was single ended vs push pull..
Class a a/b c d are all "operating conditions"
the amp is just that, it amplifies, IF the drive signal "pushes" the amp into "clipping" you've entered the "next class"
the operating conditions are typically set with "bias" or G1-Cathode VDC
you won't pass any EE classes with said explanation thu:)
Offline wsscott
So why would this amp, that has 2 6L6’s, is cathode biased, has a cathodyne phase inverter, B+ of 400VDC or higher, and 25 watts output be considered Class A?  If the design of the circuit doesn’t create the distinction, is it just the way it “plays” or “sounds”, and if so, how can one identify the Class without ever hearing it?
Offline wsscott
I read both of those articles, and understood about 10% of the technical analysis--but they were helpful.
Rightly or wrongly, what I get from the technical explanation is that the bias setting is the main factor that affects whether the amp is Class A or AB.  If that's correct, then by just looking at the schematic you can't tell which class it is because either Class can have the physical design attributes of the other.
If this conclusion is wrong, or much too simplistic, I would appreciate your comment.
Thanks for your time and guidance on this question.
Correct. You can't tell just by looking at the schematic. You need to look at the signal on the plate.
"The Amp" is simply an amplifier, it has no Class.
now you have to determine "how it operates" as an amplifier ….Class
so yes, bias is a major contributor, so is the input, or drive signal
Offline wsscott
I've started building this amp, and have a question about placement of the fuse holder in relation to distance from the AC mains power line.
This amp has a Power Supply chassis mounted on the floor of the cabinet, and the Pre-Amp chassis mounted to the top of the cabinet.  The PS chassis is 8" deep front to back, is 2.5" tall, with the PT mounted at the left-rear side of the chassis.  The rectifier tube is mounted at the front edge of the chassis in line with the PT.
The most accessible location for the fuse holder is on the front left side of the chassis about midway between the PT and the Rectifier tube.
So where is the best location to bring in the main AC power line to connect it into the fuse, etc.  Or does it really matter?  I could put it on the rear left side behind the PT but on the 2.5" rear face of the chassis, not on the top, or I could bring it to the 2.5" face of the left side of the chassis, closer to the fuse holder.
I think I would prefer the AC power line on the rear, but I'm seeking input from you guys who have done this many more times than me!  Thanks.
Offline wsscott
Here's a photo with the cover of the fuse holder placed on the left in front of the PT, where I would prefer it.
Offline acheld
Most of us normally put the fuse holder right next to where the power enters the chassis.  That allows the "un-fused" hot lead to be the shortest possible.   For a production amp, that would be imperative.
For a personal, one off amp, you can put it anywhere, but definitely consider keeping that AC away from your signal path as best you can.
Offline wsscott
Thanks.  If I put the fuse holder at the rear of the chassis it's awkward to get to, so that's why I wanted it up front.
I have thought of bringing the AC in at that point on the left side of the chassis where I would put the fuse holder, so I'll have to see if it will work with the layout in the cabinet.
