September 16, 2026, 07:29:36 pm
Hoffman Amps Forum image Author Topic: Twisting OPT primary wires  (Read 6301 times)
Offline punkykatt
« on: May 23, 2010, 10:03:28 am »
Hello all, Im working on a build where Im having to run the OPT primary wires and the CT wire about six inches outside the chassis before entering inside. For neatness can I twist/braid all three wires together or do I need to keep the CT wire separated? Thanks in advance.  Punky
Re: Twisting OPT primary wires
« Reply #1 on: May 23, 2010, 10:13:41 am »
You can twist or not. It should not make any real difference.
Offline punkykatt
« Reply #2 on: May 23, 2010, 05:27:19 pm »
Thanks, HBP. I had concern about the B+ in the CT wire being run parallel to the pulsing B+ in the plate wires.
« Reply #3 on: May 24, 2010, 02:33:11 am »
Just remember that those wires are right next to each other as they exit the transformer end-bell. So we can be pretty confident there will be no safety problems.
Offline punkykatt
« Reply #4 on: May 24, 2010, 07:04:16 am »
I was thinking the B+ in the CT might have an effect on the signal in the two plate wires being run together for that six inch length. Sometimes I just over think things.  Thanks for your input.  Punky
« Reply #5 on: May 24, 2010, 09:32:41 am »
Well, gosh... I've never been guilty of over-thinking things.... :laugh:
