September 08, 2026, 03:33:59 pm
Hoffman Amps Forum image Author Topic: Tweed BluezMeister  (Read 123098 times)
Offline Sertaro
Re: Tweed BluezMeister
« Reply #50 on: April 02, 2019, 10:15:04 am »
Hello,
This is my first time posting here and I just created the Account to ask you guys this.
I was wondering if I could include the reverb also on the "Standard" or Geezers Version of the Amp and does it matter if I put it in front or after the FX Loop?
« Reply #51 on: April 02, 2019, 12:44:36 pm »
Sure, you can put reverb on Geezer's standard. Are you planning to use a "one tube reverb"?
http://el34world.com/Forum/index.php?topic=7957.0
I am assuming you will use a passive FX loop correct?   IF that is the case, I would recommend having reverb after the FX loop.  Having said that, it's simply a personal preference which of those you want first.
with respect, Tubenit
« Last Edit: April 02, 2019, 12:49:49 pm by tubenit »
Offline Sertaro
« Reply #52 on: April 02, 2019, 05:22:14 pm »
Yeah,
I am looking for a one Tube Reverb and I want it to be a passive FX Loop.
I just love the Sound of this amp and I have got a Fender Reverb Tank in the dead Combo I am planing to use for this Build.
I thought it would be a shame not to use it.
Thanks a lot for the Schematic.
And do you have any recomendation for the Speakers i should use for that smooth Blues Sound in the Soundclips?
I was thinking about the Jensen C12K Ceramic Vintage or the Eminence Swamp Thang.
« Last Edit: April 02, 2019, 05:38:18 pm by Sertaro »
Online sluckey
« Reply #53 on: April 02, 2019, 07:07:42 pm »
Which dead combo? Not all tanks are the same.
Offline Sertaro
« Reply #54 on: April 03, 2019, 09:34:35 am »
It is an old fender Frontman 212R and I just read the post about the reverb and I will check it before I start building. I will check all of the parts and maybe reuse some of them.
Online sluckey
« Reply #55 on: April 03, 2019, 10:33:49 am »
That frontman tank won't work in the one tube reverb circuit, or any of the Fender tube type reverb circuits.
Offline Sertaro
« Reply #56 on: April 04, 2019, 10:59:59 am »
Have you guys ever done a build using a footswitch for the overdrive or anything else on this amp?
« Reply #57 on: April 05, 2019, 07:15:17 am »
My Tweed BluezMeister has 3 footswitched relays.   Clean to overdrive.   PAB (preamp boost) &  Midboost.
So, the answer is yes.   And there is tons of information in ARCHIVES on relay switching.
Tubenit
« Reply #58 on: June 18, 2019, 06:53:40 am »
.sch files can be opened by JSchem also
see the sticky link at the top of this board
