September 10, 2026, 02:21:43 pm
Hoffman Amps Forum image Author Topic: Show me your proudest builds  (Read 76796 times)
Offline escopunk
« on: August 29, 2010, 10:22:13 pm »
Hi,
New around here and I am a fellow builder and player. I would like to see the work people are the most proud of.
BrainTM :headbang: :headbang: :headbang: :headbang:
Offline bluesbear
Re: Show me your proudest builds
« Reply #1 on: August 29, 2010, 11:11:16 pm »
Okay, here's one. I built it for my son and I was just over at his house playing through it this afternoon. It's a Marshall plexi clone with a master volume, an Allen style raw control, and a Hoffman Hot Switch with pre and post controls.
I have others I like as well, particularly since I don't use anything over 20 watts, but I have a picture handy for this one.
Dave
Offline Iannone
  • If it's too loud, you're too old
« Reply #2 on: August 29, 2010, 11:18:50 pm »
10W, SE amp, through a KT77.
« Reply #3 on: August 30, 2010, 06:04:05 am »
Tweed Overdrive Special  with  clean & overdrive channels.  OD has triode into 5879. 5881's   Probably about 17watts
Carolina Overdrive Special with clean & overdrive channels.  OD has triode into 5879.  6L6's   Probably about 23 watts.     This is similar to the Tweed Overdrive but uses a Dumblish type tone stack.
Tweed OD Lite with reverb with clean and OD.  OD has only a 5879.  6V6's  Probably around 14 watts.
Tele's are hollow bodies with no "f" holes.
Offline phsyconoodler
« Reply #4 on: August 30, 2010, 10:19:21 am »
My Overdrive Rocket in suede is one of my best.
50 watts,two channel,footswitching channels and preamp boost.6L6 power tubes.NOS paper in oil coupling caps.
Offline JayB
« Reply #5 on: August 30, 2010, 10:41:15 am »
My two channel blues machine. Does a nice hard rock tone also.
You're going to hell faster than Britney Spears running to a Barber shop
Offline JayB
« Reply #6 on: August 30, 2010, 10:44:18 am »
And my two channel metal amp.
« Reply #7 on: August 30, 2010, 01:39:23 pm »
Here's my first build. i plan to do some further mods soon. Timbo
« Reply #8 on: August 30, 2010, 03:08:10 pm »
Maybe not the prettiest or the most controls I have on an amp but was one of the first designed entirely on my own. The Sheriff was my take on a single 12 combo lower powered JCM800 w/ 6V6s. It has an extra gain stage, switched presence, cathode or fixed bias, pentode/triode mode, send/return, variable line out @ 15 - 18 watts.
« Last Edit: August 30, 2010, 09:36:46 pm by jojokeo »
Offline Bierschinken
  • Crank it up!
« Reply #9 on: August 30, 2010, 03:23:27 pm »
At the Moment itīs this beast which is played a lot on stage so it is heard by lots of people and therefore my "proudest built"
3 Channels, Clean (boostable to crunchy tones), Crunch (boostable to 80ies Metal), Lead, serial Loop, 2x KT66.
- Swen
Offline bnwitt
  • Crankin' out the tone.
« Reply #10 on: August 30, 2010, 03:38:55 pm »
I was kind of proud of my Cherry front Komet 60 build.  But alas, it was too loud for me.
Offline ampgeek
  • Viva La Tube!!
« Reply #11 on: August 30, 2010, 07:16:05 pm »
My very first one (ca 2005) but...still....the one that I am the most proud of.
All octal (5691 pre and PI) 5F6A in a curley maple cab with Weber Alnico Blue Dog and Silver Bell.
GREAT sounding amp that takes pedals extremely well.  But..a total bear to tote around to gigs!
Dave O.
Offline escopunk
« Reply #12 on: August 30, 2010, 08:36:23 pm »
OK, im in the right place!
Offline TubeGeek
    • Glacier Amps
« Reply #13 on: August 30, 2010, 11:15:19 pm »
Here is my fav amp so far...I've had plenty of offers but I won't let it go.
5E3 Deluxe
« Last Edit: September 03, 2010, 08:27:44 pm by TubeGeek »
« Reply #14 on: August 30, 2010, 11:47:56 pm »
One more creative re-design of a Tweed Deluxe. Only 1 set of Hi/Lo inputs and the other two used for Treb & Bass w/ push/pull pots. V1 switched for series/parallel, tone stack can be bypassed w/ slight low end filtration to keep it from becoming muddy, Vol & PPI MV, w/ switchable Presence in old tone position.
Offline Fresh_Start
  • noob de Lux
« Reply #15 on: August 31, 2010, 09:48:14 am »
Super Reverb clone/derivative.  Hoffman-style bias vary tremolo.  Standard Vibrato channel.  Normal channel has Brown Vibroverb tone stack, reverb, tremolo, and numerous tweaks including guitar/harmonica switch instead of Bright switch.  Two Weber 10A125 and two 10F150-T speakers.  Mojo cab & chassis.
Visited the owner last week - he still loves it after playing it for a year.  Hadn't turned it up past "6" yet though... so I plugged it into a Weber MiniMass and cranked it to 8.5.  I love that power tube overdrive, but he's really happy with the clean tone.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #16 on: August 31, 2010, 10:17:45 am »
Chip,
That's one of the best looking Fender clones I've seen! Chassis layout is just beautiful. Well done.   I like your choice in speakers also.
Offline zendragon63
  • Vacuum Packed Tone
« Reply #17 on: August 31, 2010, 11:09:00 am »
I'll bite on this one because my proudest build was a struggle in both design and fine tuning. It started out dubbed as the 'Nirvana Project' last year that I built for a good friend/great guitar player and finished--if you can ever call a project finished--several months ago. Similar in topology to the *umble or TOS and runs either 2x6V6 or 5881s. Sporting a wormy maple cabinet. Too many knobs and weighs more than it should--but it does have a lot of tasty tonal options. And VVR. Ended up being a great amp to play but, oh the labor pains! :grin: Regards.
dennis
Knowledge is what you get when you read the fine print; experience is what get when you don't. I am, therefore, experienced.
« Reply #18 on: August 31, 2010, 12:50:29 pm »
 :tongue9:
Wow! Nice hardwood cabinets guys!
Offline navdave
  • 559
« Reply #19 on: August 31, 2010, 02:00:41 pm »
Wow everyone's amps look killer!
Here's  a couple of my builds a two channel dual eq beast and a 200 watt bass amp sportin Marshall Major clone iron from Heyboer.
Offline Danskman
« Reply #20 on: August 31, 2010, 02:15:09 pm »
Men, these amps are great!
Respects,
Danskman
Offline Boots Deville
« Reply #21 on: August 31, 2010, 03:11:07 pm »
Am I the only one building pink amps!?   :grin:
Offline archaos
« Reply #22 on: August 31, 2010, 03:26:56 pm »
AC30 TB w/o vib/trem channels
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
Offline Madison
  • What's up slobbies?
    • Funky Dolphins
« Reply #23 on: September 01, 2010, 08:40:08 pm »
Here's a couple.
A Princeton.....sort of. MV, Bright switch, Dwell, tweak mods.
Offline Madison
    • Funky Dolphins
« Reply #24 on: September 01, 2010, 08:41:26 pm »
A standard 5E3.
Offline Madison
    • Funky Dolphins
« Reply #25 on: September 01, 2010, 08:44:28 pm »
And a 6V6 stout with the hot-switch on the front.Boost and NFB switches on the rear.That head was way cool in the tone dept.
Offline bluesbear
« Reply #26 on: September 01, 2010, 10:47:45 pm »
I love the fact that with this many people, there is almost nothing in common between these amps. There are a hundred ways to thread this needle and they all work.
Great work, one and all!!
Dave
Offline Fresh_Start
  • noob de Lux
« Reply #27 on: September 02, 2010, 09:56:33 am »
These are all great to see.  Dave's got a good point - there's a lot of individuality in all of these builds and that's really cool.
Madison - your amps are beautiful inside & out.  I L-O-V-E that wood 5E3 cab  :glasses9:
Cheers,
Chip
Quote from: PRR
« Reply #28 on: September 02, 2010, 10:33:22 am »
How about a CRAZY build?
  Want tone out the wazzou?
« Reply #29 on: September 02, 2010, 11:12:43 am »
Ah,what the heck!
  Here's a set of twins that I'm proud of.
Offline tubesornothing
« Reply #30 on: September 02, 2010, 11:15:30 am »
Now your talking - sweet!  Phsyco, a couple of questions:
- how did you fasten the silver beading on the front baffle?
- how did you manufacture the chassis with the sloped face?
« Last Edit: September 02, 2010, 11:46:38 am by tubesornothing »
Offline rzenc
  • TUBES RULE
« Reply #31 on: September 02, 2010, 11:26:55 am »
Orange preamp + Black Face Super Reverb from rev to P.I. and bias vary trem.
No faceplate yet on this pic.
Offline Fresh_Start
  • noob de Lux
« Reply #32 on: September 02, 2010, 12:03:15 pm »
Hey noodler, is that two amps in one cab in the top photo???
I love the style of those "twins".  Very unique and cool.
Chip
Quote from: PRR
« Reply #33 on: September 02, 2010, 12:30:21 pm »
Yeah it's two amps in one.One side with EL34's and the other with 6L6's.Sounds pretty wicked.
Offline JayB
« Reply #34 on: September 02, 2010, 02:22:35 pm »
 :huh:
You definitely have the crazy build category wrapped up. Did you do a twin 2204 once?
« Reply #35 on: September 02, 2010, 03:31:46 pm »
Love the thread and the variety too! Very fun to see everybody's "hand" like in a poker game but much better since they're all hand-made pride & joy. I call these more than just great art, they're functional art. The best kind. You get to see, hear, feel, touch, play, and even smell and about the only sense you can't do is taste.  :smiley:
Offline bigdaddy
« Reply #36 on: September 02, 2010, 05:57:47 pm »
This is when I was in shape and working out, well before my back went out. I was training for the golden gloves....
« Reply #37 on: September 02, 2010, 06:58:36 pm »
Wasn't that a hundred years ago?  :laugh:
Manufacture chassis? How about a sheet of aluminum and a hand brake!And a drill.
  Yeah i did a dual 2204.It's still hurting people's eardrums to this day.The silver beading is an automotive trim and it's inserted into a CNC channel cut into the baffle.
« Reply #38 on: September 02, 2010, 08:17:02 pm »
Oh, I get it.  All amp'd up.  Give me the juice!   :grin:
Offline Madison
    • Funky Dolphins
« Reply #39 on: September 02, 2010, 10:34:55 pm »
Thanks Chip.
Same back at ya.
It wouldn't have been possible this without THIS forum.
Great folks here.
Amazing builds.
Give me lots of hope to see how many great craftsmen there still are.
Peace.
Offline Platefire
« Reply #40 on: September 03, 2010, 12:10:49 am »
I was happy the way the 5E3 variation head came out except I was still haveing problems with tweed glue bleed through.
« Last Edit: September 03, 2010, 12:16:20 am by Platefire »
On the right track now<><
Offline simonallaway
    • Hot Bottles - Tube Amp Blog
« Reply #41 on: September 03, 2010, 08:25:00 am »
Even though you've pointed it out, and the pictures are good, I can't see it myself.
If I ever get around to building my own 5E3 the cab will look much like yours. I think it's excellent.
Offline Platefire
« Reply #42 on: September 03, 2010, 12:07:41 pm »
Thanks! I appreciate that! Even though it is a head, I wanted to capture some the the original tweed and grillcloth combo look with still yet a little bit of modern toutch/layout to boot. Plate
Offline theundeadelvis
  • I love tube amps and bacon...
« Reply #43 on: September 03, 2010, 03:29:37 pm »
I have no business posting after some of these amazing amps, but here I go anyhow. Two 5E3's, one with a matching stand-alone verb.
« Last Edit: September 03, 2010, 03:32:39 pm by theundeadelvis »
« Reply #44 on: September 03, 2010, 05:49:17 pm »
Wow! Those look AMAZING! Very well done!!!!
« Reply #45 on: September 03, 2010, 10:48:19 pm »
Thanks man! That means a lot coming from someone with as impressive builds as yours!
Offline Tone Junkie
« Reply #46 on: September 04, 2010, 12:02:05 am »
This is why i like this place you guys do great work. Bill
Offline zendragon63
« Reply #47 on: September 04, 2010, 12:38:18 am »
Wowser, I am humbled. Great work all. I am glad someone didn't bait us with our least proud build.  :laugh: I have a few scary ones! Regards
dennis
Offline bluesbear
« Reply #48 on: September 04, 2010, 06:52:03 am »
Well, I figured out the electronic part long before I got the cabinet and faceplate part. Some of my proudest builds are pretty sad looking. I'll get some shots together later... I'll be brave!
Dave
Offline oldgitar335
« Reply #49 on: September 04, 2010, 08:56:29 am »
hello all. this is my best and favorite gig amp. thanks to tubenit  for the "blues amp" circuit.
            Weber cab, chassis and Texas 15. Big sound from two 6v6 tubes. This forum is the
             best tool on my bench. Thanks to all !       Oldgitar335
