September 15, 2026, 06:28:45 am
Hoffman Amps Forum image Author Topic: AB763 lite w/o trem/rev - european version  (Read 20267 times)
Offline Guitar-Tube-1969
« on: June 18, 2016, 08:22:02 am »
Hi all,
I'm from Germany and new to this great forum. I've built several pedals and one small 3W tube amp from kits by now.
My next project should be an AB763 Deluxe w/o trem/rev. I've found Sluckeys schematic (AB763_Deluxe_Lite.pdf) in this forum which will be perfect except:
- I need an european version with 240 V
- I want a version with more clean headroom => 6L6
Do you can help me out with an appropriate PT/OT (preferable 4, 8 and 16 ohm)?
In addition I've got the question what parts to change in your circuit in addition to different tubes, PT and OT?
Thanks - Axel
Offline drgonzonm
Re: AB763 lite w/o trem/rev - european version
« Reply #1 on: June 18, 2016, 11:29:16 am »
I believe the fender Pro, is similar in design to the deluxe, it has 6l6 tubes in place of the 6v6s.  The schematics also provide output bias info.
Regarding o/ts take the fender part numbers, and go to the Hammond website, it will provide the specs for the transformers for both the deluxe and the pro.  Hammond will also suggest upgrades.
While I haven't provided the specific details, I hope this information leads you in the direction you want to go.
« Reply #2 on: June 18, 2016, 12:30:39 pm »
Pick out the 6L6 AB763 amp you want then go to the Hammond website and find the replacement PT, OT, and choke. There will be choices for 240V (Euro) PTs as well. Write down the model numbers you want then go to your favorite dealer. You should be able to find several dealers in Europe.
Here's the Hammond link...
     https://www.hammfg.com/electronics/transformers/classic
« Reply #3 on: June 20, 2016, 02:30:40 pm »
Thanks for your input.
I've found a PT
http://www.tubeampdoctor.com/de/shop_Netztrafos_Netztrafos_fuer_Fender/Netztrafo_fuer_Fender_Deluxe_Reverb_Grand_Stack_DEL_MAXIMO_4840
with the following specs:
Primary:   #72500
0V   White
230V   Black
240V   Brown
Secondary:
350V/160mA   Red
56V   Blue
0V   Green/Yellow
350V   Red
3.15V/4,8A   Green
0V   Green/Yellow
3.15V   Green
5V/3A   Yellow
5V   Yellow
In addition I want to use the following OT:
http://www.tubeampdoctor.com/de/shop_Ausgangsuebertrager_Ausgangsue_fuer_Fender/Ausgangsuebertrager_2x_6L6GC_5881_fuer_2_4_und_8_Ohm_153
which seems to be a replacement for the 45W super reverb circuit.
Two question now:
1. Will this combination of PT/OT fit to Sluckeys AB763 Lite circuit?
2. Do I have to change other components in that circuit?
Greetings from Germany - Axel
Thanks in advance
« Reply #4 on: June 20, 2016, 02:40:10 pm »
Secondary:350V/160mA   Red  <---this seems oversized for a Deluxe. OK, you want to run 2 * 6L6. Still pretty large, this seems like a transformer for a Twin Reverb = 4 * 6L6. Check physical size if this is what you want.
« Reply #5 on: June 20, 2016, 02:57:44 pm »
That PT will give you more B+ voltage than you will probably want. Can't you find those Hammonds in Europe?
« Reply #6 on: June 20, 2016, 03:05:11 pm »
I found the following Hammonds on tubetown:
290 DEX (super reverb):
http://www.tube-town.net/ttstore/Transformatoren/Netztrafos/Fender/Hammond-290DEX-Fender-Power-125P5D-Super-Reverb::2151.html
290 CEX (vibrolux):
http://www.tube-town.net/ttstore/Transformatoren/Netztrafos/Fender/Hammond-290CEX-Fender-Power-125P26A-Vibrolux::2150.html
Will be these ones a better choice and which one will fit better for a AB763 with much clean headroom?
« Reply #7 on: June 20, 2016, 05:52:05 pm »
I would use the 290 DEX.
« Reply #8 on: June 23, 2016, 12:25:31 pm »
Is there anyone having a partslist für Sluckeys AB763 lite?
« Reply #9 on: June 23, 2016, 12:44:54 pm »
I bet you can make a parts list in less than 15 minutes.
« Reply #10 on: June 26, 2016, 12:09:46 pm »
Ok, will it  fit in a 5e3 or Princeton chassis?
« Reply #11 on: June 26, 2016, 12:34:37 pm »
Depends on dimensions of the transformers. I could build the Deluxe Lite in a blank 12" x 6-1/2" x 2-1/2" chassis.
« Reply #12 on: July 04, 2016, 02:11:54 pm »
Ok, I decided to build your original version with the 6V6 first to learn more about the circuit. After understanding more from it, I will alter it to a version with more output. For that reason I will use the following transformers/choke:
PT: Hammond-290BEX
OT: Hammond-1760H
Choke: Hammond-194A
When preparing my parts list I detect some difference between your schematic and the layout diagram where I'm not quite sure:
- The filter caps C12-C16 are not marked with a "+" in the schematic, but I think these of course have to be electrolytic capacitors, right?
- C17, C18 are 50uF in the schematic and 47uF in the layout diagram, I would youse 47uF/100V right?
- C1, C7 are not marked with a "+" in the schematic, but I think this have to be electrolytic capacitors too, right?
Do you have any suggestions regarding the capacitors (manufacturer, oil cap, sprague Orange Drop, mustard, ...)?
Thanks in advance - Axel
« Last Edit: July 04, 2016, 02:21:49 pm by Guitar-Tube-1969 »
« Reply #13 on: July 04, 2016, 03:03:53 pm »
Right to all electrolytic questions.
Those yellow caps on my layout are Mallory 150s. They are scaled properly. I know that Xicon chicklet caps will fit nicely. I know that Sprague ODs will not fit nicely. I don't know about any other type caps.
« Reply #14 on: July 04, 2016, 03:05:31 pm »
great, thanks!!
« Reply #15 on: July 06, 2016, 12:49:11 pm »
Do you have any suggestions about the cables?
I would prefer to use a shielded cable as shown in the layout diagram.
For all other connection I will use 18 gauge material which I think is 1mm diameter.
Is that OK or is it better to use different gauges for e.g. the filaments...?
« Reply #16 on: July 06, 2016, 01:23:03 pm »
I like RG-316 for shielded cable. RG-174 is OK also but it's not as durable as 316. I use 20AWG for filaments ang 22AWg for everything else.
Offline labb
« Reply #17 on: July 06, 2016, 02:03:38 pm »
Sluckey, are values for C10 and C11 0.1 or 0.047
« Reply #18 on: July 06, 2016, 02:14:25 pm »
Ha ha! They are .1µFs on the schematic (like Fender) but .047µFs on the layout (my preference).
« Reply #19 on: July 10, 2016, 09:07:10 am »
So, I've got my list, added the resistor and capacitor numbers in sluckeys layout diagram and got four new questions:
Question 1:
R27 and R28 are not shown on the layout diagram, I suppose
- R27 goes from V4/8 to ground 2
- R28 goes from V3/8 to ground 2
I added this in the attached layout diagram, is that right?
Question 2:
V3/4 and V4/4 both goes to B
Question 3:
I would use 5W resistors for R29, R30, R32, R33, R34 and 2W for all other resistors.
Is that OK or do you have different recommendations?
Question 4:
The position of the standby-switch in sluckeys version is different from that from the hoffman single channel version (see attached diagram). Why is this so and what effect does this have?
« Reply #20 on: July 10, 2016, 10:39:47 am »
OK, a little background on my drawings... None of the 'layout' drawings in any of my documents are a complete layout drawing. They are meant to be used to build the boards and show how the boards interconnect with the other components. You can print (full size) any of my board layouts, tape it to a blank board and use it as a drill guide to make an exact copy of the drawing. If you only had one of my board layout drawings to work with, you probably could not build a successful amp. YOU MUST REFER TO THE SCHEMATIC FOR THE COMPLETE AMP WIRING.
About this particular drawing... It is old and today I would have provided clearer instructions for grounding. Here's how I'd do the grounding on that amp. Screw a ground lug to the chassis very near the input jacks. This is the preamp ground. Put a ground lug on one of the PT bolts. This is the power ground. Screw a ground lug to the chassis near the entry point of the mains cord (or IEC). This is the safety ground. Connect the green wire from the power cord (or IEC) to the safety ground. DON'T CONNECT ANYTHING ELSE TO THE SAFETY GROUND. Now referring to page 2 and 3 of my pdf, connect gnd 1 and gnd 3 to the preamp ground lug. Connect gnd 2, A gnd, B gnd, and the output tube cathode resistors to the power ground.
And your specific questions...
1. Connect R27 and R28 to power ground.
2. That's wrong. Connect both pins 6 together and run a single wire to B cap.
3. 1 watt is fine for R29, R30, R32, R33, and R34, but I would use 3 watt metal oxide. 1/2 watt metal film is fine for everything else. Use Mallory 150s or Xicon coupling caps. Other types may not fit the board very well.
4. My STBY switch is wired just like the original. Either way will work.
Sounds like you're about ready to roll. Keep us posted. We're interested in your project. BTW, I have never actually built this Lite version, but several members have. It will easily fit a 12 x 6-1/2 x 2-1/2 chassis.
« Reply #21 on: July 10, 2016, 01:09:40 pm »
Great, thanks! You see, I'm a beginner.
just 2 questions more:
1. I can't get 3 watt metal oxyd resistors for R29, R30, R32, R33, and R34. Only 2 Watt or 5 Watt. What would you recommend?
2. I did not found metal film resistors (0.5 watt) for R27, R28 (1 Ohm) and R15 (100 Ohm). Can I use metal oxyd 1watt instead?
Offline labb
« Reply #22 on: July 10, 2016, 01:14:28 pm »
Sluckey, why the two 20 uf 500volt caps in parallel for node A. I know that Fender shows about the same but doesn't that give you 10 uf for the initial cap. for the rectifier. I think either is rated for 60uf input.
« Reply #23 on: July 10, 2016, 01:34:29 pm »
For Guitar-Tube-1969...  (Your questions don't seem to be beginner questions.)
1. I would use 2 watt.
2. The 1Ω resistors need to be 1% tolerance. Wattage doesn't really matter. These resistors are only used to help you set the bias. They are not required for the amp to operate correctly. R15 is only 1/2 watt. Use whatever you can find. Note... R15 should be 47Ω if you plan to connect NFB loop to an 8Ω speaker tap (like the Deluxe Reverb). It should be 100Ω if connected to a 2Ω or 4Ω speaker tap. Ain't no big deal if you get it wrong.
For labb...
Two 20µF caps in parallel will give you 40µF total capacitance, not 10µF.
Offline labb
« Reply #24 on: July 10, 2016, 01:51:30 pm »
Whoops, got it backwards don't I.
« Reply #25 on: July 31, 2016, 01:11:43 pm »
Hey Sluckey,
I've got a question for soldering the PT to the rectifier tube.
My PT is the Hammond 290 BEX which has
2 green cables (6,3 V) => filaments V1-V4
2 yellow cables (5V) => filament for rectifier (pin 2 and 8)
till here it is clear, but...
2 red cables (330V/660V) => for rectifier pin 6 and 4 ??
1 red/yellow cable => to power ground?
thanks in advance - Axel
« Reply #26 on: July 31, 2016, 01:17:20 pm »
2 red cables (330V/660V) => for rectifier pin 6 and 4 ??   yes
1 red/yellow cable => to power ground?    yes
« Reply #27 on: August 01, 2016, 02:07:41 pm »
So, I finished the amp except an impedance switch for the speaker out (hopefully I will get the package soon). I will shorten the cables from the OT after assembling the switch. I'd added some pictures from the result.
Now I will double check all of my soldering against the circuit and then I will put in the tubes and power on.
Do you have some hints for starting / measuring at first?
« Reply #28 on: August 01, 2016, 02:39:55 pm »
Build 1 of these light bulb limiters and use it on 1st power up to test for shorts;
http://sluckeyamps.com/misc/Amp_Scrapbook.pdf
« Reply #29 on: August 02, 2016, 04:39:20 am »
Hey Sluckey, that was a good tip!
Unfortunately i've got a short as it seems.
Power on => OK, bulb shines very low
stdby on after a while => NOK! bulb shines very bright
stdby on shortly after power on => OK at first, NOK! (same result as before) after a short while.
I've double checked everything but I can't find the defect.
Do you have an advice, where to look for?
I've attached the final fotos.
« Reply #30 on: August 02, 2016, 06:31:22 am »
Keep the amp plugged into the lamp limiter for now. Pull the output tubes. Measure voltage on pins 3, 4, and 5. What have you?
« Reply #31 on: August 02, 2016, 07:05:13 am »
V3-3 / ground: 399 VDC
V3-4 / ground: 397 VDC
V3-5 / ground: -29,7 VDC
« Reply #32 on: August 02, 2016, 07:12:54 am »
How did the lamp limiter look?
Those voltages look good. For now just set the bias pot for max negative voltage on pin 5. Put the 6V6s back in and try again.
« Reply #33 on: August 02, 2016, 07:24:45 am »
Now after switch on the standby the lamps is a little bit lighter than before. I can plugin and hear the guitar but also a lot of hum. This is with and without the guitar plug in.
Max neg. voltage on pin 5 is -51.1
« Reply #34 on: August 02, 2016, 07:32:42 am »
Is the lamp anywhere close to being full brightness? By that I mean as bright as it would be if it were plugged into a standard lamp.
« Reply #35 on: August 02, 2016, 07:35:46 am »
No, not at all.
It seems that there is a problem with the high input jack. I only hear a guitar signal from the low input. This signal is week an a little bit distorted
« Reply #36 on: August 02, 2016, 07:43:35 am »
You should be done with the lamp limiter. Plug the amp straight into the wall and turn it on. Watch for smoke, listen for odd sounds. And smell for odd odors. Be ready to turn it off if any alarms.
If all is well, set the bias a little hotter. Adjust the pot for about 25mV on pin 8 of each 6V6. Then measure the voltage on pin 3 of each 6V6. What have you?
« Reply #37 on: August 02, 2016, 08:58:02 am »
Ok, nothing smokes, but....
Increasing the bias leads to much hum from the speaker. I can only turn it up to around 10.1mV on V3/8 and 8.6mV on V4/8. Why are these different?
V3/3 = V4/4 = 432 VDC
« Reply #38 on: August 02, 2016, 09:50:13 am »
The voltages are different because the tubes are not perfectly matched. Nothing to worry about. But the hum is an issue. Hum can be caused by many issues, bad tubes, filter caps, NFB, poor connections/solder joints, etc. For now, disconnect the NFB wire that runs from the speaker jack to the board and leave it disconnected. Does the hum go away?
Pull the preamp tube. If the amp still hums, the problem is in the power amp and/or power supply. If the hum goes away, the problem is in the preamp stages.
« Reply #39 on: August 02, 2016, 10:04:07 am »
Ok, the hum goes by pulling V1. Nothing changes when disconnecting the cable from the speaker out tip. So it is a problem in the preamp stage?
« Reply #40 on: August 02, 2016, 10:06:33 am »
Could it be a grounding problem of the pots and the input jack? I change the soldering from two input jacks to one to test if it comes from a wrong soldering there. But I get no input signal now.
« Reply #41 on: August 02, 2016, 10:08:19 am »
Yes, sounds like it's a preamp problem. For now just leave V1 out. Reconnect the NFB wire and try to set the bias for about 25mV on pin 8 of the output tubes. Then measure voltage on pin 3 of the output tubes. What do you have?
« Reply #42 on: August 02, 2016, 10:15:47 am »
It feeps again when biasing up. I can reach 12.0 mV on V3 and 10.0mV on V4. Pin 3 then have again 431 VDC
« Reply #43 on: August 02, 2016, 10:25:34 am »
What does 'feeps' mean? Does it quit feeping if you disconnect the green NFB wire at the board?
« Reply #44 on: August 02, 2016, 10:30:20 am »
If I disconnect the nub wire, there is no feeping and I can adjust the bias at 25mV
« Reply #45 on: August 02, 2016, 12:07:12 pm »
Hey all,
I have started to rewire the filaments in a better way and when I finished it I will recheck the preamp section.
Now I will be on a vacation till August 14th. After my return I will go on and post my results.
Thanks for your advice!!
Axel
« Reply #46 on: August 02, 2016, 12:08:07 pm »
OK. The permanent cure for that is to swap the OT primary wires on pins 3 of the 6V6s. Then reconnect the NFB wire. Now readjust the bias pot for 25mV on pins 8. Measure the voltage on pins 3. What are the voltages.
Now plug in the preamp tube and tackle the hum problem if it still exists.
« Reply #47 on: August 14, 2016, 01:39:15 pm »
Hey Sluckey and all others,
I'm back from vacation and continue building...
It seems that I have solve the power amp/supply:
After changing the OT primary wires as Sluckey stated I could bias to nearly 25mV and receive the following values:
V3/8: 25,5mV
V3/3: 410 VDC
V3/4: 413 VDC
V3/5: -40,1 VDC
V3/8: 25,0mV
V3/3: 410 VDC
V3/4: 412 VDC
V3/5: -40,1 VDC
There is nearly no hum, even at high volumes, but... there is no audio signal. If I plug in a guitar cable and touch the tip, there is no signal at all.
I have checked the circuit against my soldering twice, but I cannot find the problem.
Do you have any idea how I can proceed?
Thanks - Axel
« Reply #48 on: August 14, 2016, 01:54:23 pm »
Check it again and again until you find the error. There is very likely a wiring error or wrong component value. Click the link in my signature line below for some good info on verifying your schematic agrees with your layout and agrees with your actual amp.
« Reply #49 on: August 14, 2016, 03:37:47 pm »
Hey Sluckey,
finally I got it.
The shielded cable that goes from the input jack to V1 was broken inside. After replacing it, it seems to work fine. Tomorrow I will check the rest, bias and will add a bright switch ...
I will upload the final result and hopefully a sound sample.
Thank you so much Sluckey for your advice.
Axel
