Hoffman amps Boardmaker instructionsPage - Board Page 0 - Board Page 1 - Board Page 2 - Board Page 3 - Board Page 4 - Board Page 5 - Board Page 6To follow along with these pages you should go here to the library page and print out the layout diagram for the 5F6A Bassman board. |
At this point we have built our complete circuit board and our pot harness. The last thing I did before I shipped a board kit was to assemble the bag of goodies
that are needed to install the board kit in an amp. The exact items that came with each kit would vary, for example you don't get 4-12A jacks with a 6G15 reverb kit, the jacks are
on the pot harness assembly. The actual parts listings on this page are a better guide as to what each kit needed or did not need. You can also see
pictures of the bag of goodies on the old board kit page. This is the general list of parts not specific to any one board. 1 - Set of instructions. |
| 5E3, 5F6A, Plexi and AC30 bag of goodies |
1 - Set of instructions. 1 - Layout diagram. 1 - Circuit board with all mounting hardware (standoffs, screws, nuts) 1 - Pot harness assembly. 4 - #12A 1/4" input jacks. 4 - 68k input jack resistors. 2 - 1meg input jack resistors. 2 - 1.5k Fender or 2 - 5.6k Marshall or 4 - 1.5k Vox grid stopper resistors. 4 - Round terminal lugs for chassis ground connections. 5 ft each of assorted green, red, black and white wire. 20 gauge solid and 18 gauge stranded. 2 ft Shielded cable for input jacks. 2 inch Heat shrink tubing for shielded cable. |
| AB763 bag of goodies |
1 - Set of instructions. 1 - Layout diagram. 1 - Circuit board with all mounting hardware (standoffs, screws, nuts) 1 - Pot harness assembly. 4 - #12A 1/4" input jacks. 4 - 68k input jack resistors. 2 - 1meg input jack resistors. 2 - 1.5k Fender grid stopper resistors. 4 - Round terminal lugs for chassis ground connections. 5 ft each of assorted green, red, black and white wire. 20 gauge solid and 18 gauge stranded. 2 ft Shielded cable for input jacks. 2 inch Heat shrink tubing for shielded cable. 2 - 6.8k mid control resistors. 1 – 220k reverb jack resistor. |
| 6G15 bag of goodies |
1 - Set of instructions. 1 - Layout diagram. 1 - Circuit board with all mounting hardware (standoffs, screws, nuts) 1 - Pot harness assembly. 4 - Round terminal lugs for chassis ground connections. 5 ft each of assorted green, red, black and white wire. 20 gauge solid and 18 gauge stranded. 2 ft Shielded cable for input jacks. 2 inch Heat shrink tubing for shielded cable. 1 – 220k reverb jack resistor. |
