September 08, 2026, 03:39:45 pm
Hoffman Amps Forum image Author Topic: lego's spin on Sluckey's AC15  (Read 341013 times)
Offline lego4040
Re: lego's spin on Sluckey's AC15
« Reply #200 on: April 14, 2014, 03:07:10 pm »
 :cry: My parts are still in Fla, I will be off project till end of next week when I get back from Buffalo. I might take a trip to Hammond themselves which is not far from my inlaws. Backordered are the 3mra pot and carling switches  :cussing: Maybe Ill score some projects when Im up there
Offline terminalgs
« Reply #201 on: April 14, 2014, 03:29:10 pm »
Ed, what speaker(s) are you planning to use?
In your research, what have you found to be the wood used in the original cabinet construction?
« Reply #202 on: April 14, 2014, 05:00:33 pm »
What did VOX use, or is it all of the above since they seemed to change manufacturers
I seem to remember Ken Fisher saying that Vox used 5 or was it 6 different manufactures in the old AC30/15's. He had his favorite of course but that will surly be different for different peoples ears.
(I think it's in the Gerald Webber books where Webber added Kens column's from Vintage Guitar Mag.)
             Brad      :icon_biggrin:
« Reply #203 on: April 14, 2014, 06:09:47 pm »
Rain is back! Got the filaments and power supply wired and checked out.
EDIT... big pic removed.
« Last Edit: April 16, 2014, 07:30:32 pm by sluckey »
« Reply #204 on: April 14, 2014, 06:40:05 pm »
Man your a fast bugger.   :laugh:
Looks great.
It's snowing here. Roof's and grass are covered already and it's still coming down.     :BangHead:
Grass just got nice and green the last 2 days after some rain and sun.
             Brad     :cussing:
Offline lego4040
« Reply #205 on: April 14, 2014, 09:39:07 pm »
It's the new season called springter I heard, I'm head out northwest to Buffalo on wensday, where it's going to be snowing tomorrow and a low of 19*. Sluckey that looks great man, I'm way behind now, it took them a week to send my stuff out and I won't be home to receive it, and the switches and 3mra pot is on back order. I'm gonna order those from somewhere else and just have the extras on hand. Collecting amp parts is Waaayyyyy more expensive then pedal parts. Next build I have everything ordered in one shot.
Offline Tone Junkie
« Reply #206 on: April 15, 2014, 02:31:06 am »
Man Im away for a few days and you guys kick butt and leave me 2 pages to catch up on. The builds look good, I love the faceplates.
Bill
« Reply #207 on: April 15, 2014, 04:40:58 am »
Single 12 Celestion Blue.
All vox cabs were birch until recently became MDF.  The Vox Showroon goes through a few different cabinet forms.  The size of the cabinet changes the tone as much if not more than the wood.  The AC15 was a small combo cab to have a 12 as the bluesbreaker cab was small for 2, 12.  I have never seen a 2, 12 AC15, but I read they are the same as the AC30 2, 12.
I have heard people say pine is warmer and birch is brighter, but I have never noticed this.  I build my cabs larger and a little deeper as this will make available a deeper response.  I can make it brighter by opening it up.
Here is some info for a replica cab.  http://www.voxshowroom.com/northcoast/vox/cabinets/ac15_TE_blk.html
You can see the materials and size.
I am doing a head with a birch 1, 12 cab.  It is 3/4 with a box joint and the back is made of 3 panels so I can tune it as close as possible.
« Last Edit: April 15, 2014, 08:02:45 am by Ed_Chambley »
« Reply #208 on: April 15, 2014, 05:02:44 am »
Sluckey,
Curious as to how you made your ground buss bar?  It looks like rivets with cable.  What is securing the rivets, pressure from expanding them or is this something else?
Also, what is the size of the machine screws on the tube sockets?  I like the idea of tapping and plan to follow.  They appear to be shorter than 1/4.  If so, where did you get them?  Did you use any blue thread locker?
I did get my board made, underboard wires (checked 4 times) and top jumpers.  Getting close to begin making my chassis and there are a lot of good ideas in yours I plan to rip off just as soon as I find out what you used.  That ground bar makes for a very clean look and also easy to make change if needed.
Offline lego4040
« Reply #209 on: April 15, 2014, 05:27:40 am »
Ed, reply 219 for the tap and screw sizes. Not sure on the buss rivet
« Reply #210 on: April 15, 2014, 05:53:37 am »
That 2" buss bar is simply a piece of solid 14 AWG house wire soldered between two standoff turrets. The turrets accept a 4-40 screw through the chassis. I've attached a pic from a different angle that clearly shows the bar/turrets. I used that same buss bar in my TDR, 5E3, November, and Lightning builds. In fact that buss bar actually was donated by the Lightning.
1/4" long #4-40 SS phillips head machine screws. Got'em cheap on eBay.
« Last Edit: April 16, 2014, 07:31:26 pm by sluckey »
Offline lego4040
« Reply #211 on: April 15, 2014, 06:11:24 am »
So you put a screw and nut locked into chassis then put turret on that. Did you tap the turret because of soft metal it self tapped?
« Reply #212 on: April 15, 2014, 06:42:14 am »
Much simpler than that. The manufacturer does all the hard stuff. I just drill a hole in the chassis. Look at the pic of my filament string. You'll see a couple turrets installed next to the sockets. Since I'm not using Hi/Lo/ input jacks, I moved the 68K grid stopper resistors to the socket and will mount them between those turrets and the socket.
« Last Edit: April 16, 2014, 07:32:03 pm by sluckey »
« Reply #213 on: April 15, 2014, 08:01:52 am »
Where do you purchase those single turrets and what are they called?  Is there any reason for the different colors?
Did you use any thread locker on the tube socket screws as I do not see any locknuts?  Overkill?
« Reply #214 on: April 15, 2014, 08:36:03 am »
I've never bought any. The ones I have were scrounged from leftovers on various equipment mods I've done to USAF and FAA systems throughout my career. My white ones are ceramic, brown is bakelite, green is some kind of hardened plastic. Color is not significant. They're not cheap and that's why you rarely if ever see them in consumer grade electronics. All the big industrial suppliers will have them. Here's a link to one...
http://www.newark.com/wearnes-cambion/572-4814-01-05-16/terminal-turret-4-40-thread-blue/dp/40F6225?MER=PPSO_N_P_Terminals_None
http://www.ebay.com/itm/10-terminal-studs-Helicopter-HH-53J-M-F16-military-electrical-MIL-T-55155-10A-/380686825818?pt=LH_DefaultDomain_0&hash=item58a2b3f95a
There's no need for a nut since the chassis is tapped. And I didn't use thread lock or lock washers since this amp will not be traveling. Lock washers is not a bad idea though.
Offline lego4040
« Reply #215 on: April 15, 2014, 09:06:33 am »
 :huh:  6 bucks a pop on that site, 10 for 20 bucks on ebay is more feasable. heres one of those receptacle noise suppressors, this came out of a 430watt power pack for a pc. Its kinda big and looks like Id have to desolder jack to install then resolder
« Last Edit: April 16, 2014, 03:51:17 pm by EL34 »
Offline terminalgs
« Reply #216 on: April 15, 2014, 09:30:34 am »
I'm going to try and answer my question  :l2:  does this look right? Or do I loose that 1M or am I way off
what is the switch for?
« Reply #217 on: April 15, 2014, 09:31:23 am »
How did you get it out with out unsoldering it? Bust up or cut up the chassis housing?
             Brad     :think1:
Offline lego4040
« Reply #218 on: April 15, 2014, 09:39:40 am »
I used tin snips to cut around power pack. FYI folks, this cpu power pack carry a wallup just as bad as an amp. The main cap was 450volts on this one, SO BE CAREFULL
« Reply #219 on: April 15, 2014, 10:25:02 am »
This is the main reason I choose RG-316 over RG-174. The black wire is soldered directly to the RG-316 shield.
« Last Edit: April 16, 2014, 07:33:35 pm by sluckey »
« Reply #220 on: April 15, 2014, 10:52:31 am »
That's nice, you don't have to strip a long length to run the shield to it's ground. Much neater and less waste.
                   Brad     :icon_biggrin:
« Reply #221 on: April 15, 2014, 11:26:47 am »
Just got some of these turrets from the link you provided.  Offered a total of $30 for 20 and the offer was accepted.  I can use these a lot, I wish the new ones were less expensive.
« Reply #222 on: April 15, 2014, 05:45:34 pm »
Got a little more done today...
« Last Edit: April 16, 2014, 07:34:28 pm by sluckey »
Offline lego4040
« Reply #223 on: April 15, 2014, 06:24:02 pm »
 :happy1: :happy1:  my parts came today. Only missing 12 4/40 hex nuts. Boo, I'm away till end of next week
« Last Edit: April 16, 2014, 03:51:45 pm by EL34 »
« Reply #224 on: April 15, 2014, 06:33:03 pm »
... heres one of those receptacle noise suppressors, this came out of a 430watt power pack for a pc.
That thing is an IEC inlet only, without the line filter. It might have an internal fuse holder.
But as Sluckey said, the filter is not absolutely necessary.
« Reply #225 on: April 15, 2014, 07:31:37 pm »
 :huh:
 :worthy1:
« Reply #226 on: April 15, 2014, 07:49:12 pm »
All right!       :blob8:
            Brad     :laugh:
« Last Edit: April 15, 2014, 07:54:49 pm by Willabe »
« Reply #227 on: April 15, 2014, 07:53:49 pm »
:huh:
Yeah, he's good, isn't he?
I know it's personal preference but I have to say it's the best work I've seen and I say that using a different layout style!    :laugh:
          Brad     :icon_biggrin:
« Reply #228 on: April 15, 2014, 08:27:29 pm »
It's art to me...
Picasso - Smickasso  :l2:   (and I love Picasso)
That should be on display at the Smithsonian!
The good news is that it's raining here too :wink:
Inspirational!.....seriously  :thumbsup:
« Reply #229 on: April 15, 2014, 09:49:46 pm »
I just hope it works!   :icon_biggrin:
« Reply #230 on: April 15, 2014, 10:13:26 pm »
James Taylor, "Sweet dreams and flying machines in pieces on the ground."
I'm bettin she'll fly and then some! Come on baby let's hear that vibrato!!!!!!
                Brad       :m2
Offline lego4040
« Reply #231 on: April 15, 2014, 11:25:06 pm »
Snowing here in Manhattan, SOB. Art work there Silvergun. I wasn't sure if I wanted to put leads on or not myself. I'll dream about parts while I'm away
« Reply #232 on: April 16, 2014, 04:56:10 am »
I do too as I have a replica of your copy of sort of Vox looking thing.  I have looked it over and over and do not see any reason why not.  Could you post a close up of your input jacks?  Also, I cant quite tell what the triangular part of the switch to the right of the inputs.  Is that part of the switch?  What is it for?
Is your choke wired yet?  Is so, how?
Is that a 1/4 watt 100 ohm resistor on your speed pot?  Did you solder to the back of the pot or is it just where you soldered the resistor.  I cant see it well, but it looks like you have it on the wiper or lug 1 as it is parallel.  Is it really connecting the wiper to lug 3 and then you have a ground from lug 3 to the buss bar?  Just checking. :icon_biggrin:
I a a good bit behind, but I want to attempt to get as nice of a look as you are doing.  We will see as I have gotten better.  It has to do if I have enough patience.  I love those single turrets.  Can't wait to get mine.
You have an incredible  sense of space.  I cant wait till you wire to the tube sockets.  That is my favorite part of your work.
« Last Edit: April 16, 2014, 05:11:00 am by Ed_Chambley »
« Reply #233 on: April 16, 2014, 05:12:00 am »
Sluckey,
You truly do remarkable work!  That looks phenomenol.
with respect, Tubenit
Offline lego4040
« Reply #234 on: April 16, 2014, 06:58:01 am »
Ed that switch is the bright switch and that's the capacitor across the lugs. That pot is the speed pot with a 100 ohm in series to buss, instead of using three way selector one option is the 3mra pot. It's drawn up and posted in a earlier post but it's the same as the Hoffmans AB763 project
« Reply #235 on: April 16, 2014, 07:17:53 am »
You might have to change the name of the thread to "Sluckey's take on lego's spin of sluckey's AC15"  :l2:
Just kidding lego....keep up the good work...don't bother trying to keep up with sluckey
If I built that board it would take about 3 months and it still wouldn't look that nice!
« Reply #236 on: April 16, 2014, 07:31:28 am »
The attached pic should clear up any questions about the jacks, switch, and speed pot wiring. The choke was wired a couple days ago. You can see it in reply #231. Look for the two black wires poking thru a grommet.
« Last Edit: April 16, 2014, 07:35:47 pm by sluckey »
« Reply #237 on: April 16, 2014, 10:24:50 am »
I see it now.  I could not see where the choke wires passed the PT wires.  That is a very cool buss wire.  Man, I am learning some great techniques.
Thanks!
Offline lego4040
« Reply #238 on: April 16, 2014, 11:14:53 am »
Sluckey your right, that heavy gauge aluminum is thick stuff
Offline dbishopbliss
    • Bliss Amplifiers
« Reply #239 on: April 16, 2014, 01:00:51 pm »
I'm not understanding the difference... doesn't RG-174 have a shield as well?
Check out my blog for more details. Bliss Amplifiers
Offline lego4040
« Reply #240 on: April 16, 2014, 01:12:27 pm »
I think the difference was that you can solder lead directly on and the Teflon covering core won't melt
    • Bliss Amplifiers
« Reply #241 on: April 16, 2014, 01:14:31 pm »
Ah... I have some 89259 which has a stranded core but teflon dialectric and copper shield (not tinned).  Any reason not to use it?
Offline lego4040
« Reply #242 on: April 16, 2014, 01:22:04 pm »
Other then it being stranded, I can't see why not use it unless core to thin.
    • Bliss Amplifiers
« Reply #243 on: April 16, 2014, 01:44:34 pm »
I think these standoff terminals are similar to the one's slukey is using.
Is there an issue with using stranded wire?
    • Bliss Amplifiers
« Reply #244 on: April 16, 2014, 03:13:46 pm »
Hey... I just read that the Hammond 1650F can be used for a Dynaco ST-35 stereo amp.  I have a set of output transformers for a Dynaco ST-35 (mine are actually magnequest).  Looking more and more like I was meant to build this amp.
« Reply #245 on: April 16, 2014, 04:08:01 pm »
Thanks for posing that, I just bought a bunch of them.
           Brad      :icon_biggrin:
Offline lego4040
« Reply #246 on: April 16, 2014, 05:18:58 pm »
I prefer stranded sometimes, you can move around more and not worry about breakage.
Offline drew
« Reply #247 on: April 17, 2014, 12:49:58 am »
           Brad      :icon_biggrin:
"Diallyl Phthalate," seriously?  That's not an amp part, it's a Foster Brooks punchline.
« Reply #248 on: April 17, 2014, 04:34:39 am »
           Brad      :icon_biggrin:
I looked and the ones I really wanted were sold out, imagine that.  I did get a few different kinds.  Did you notice the ceramic ones.  They are around $2.50 each which I am sure is a good price.  I have seen these things before in equipment but never really noticed them if you know what I mean.  I will be, from now on salvaging all that i see.  50 to 75¢ are not too bad considering how useful they can be doing modifications.
I am still looking for the meter jack tips that have metal threads and nuts.  I am waiting for my cap order and I know I will have one last order to get the things I either forgot or ordered wrong.  I usually will make a mistake like 2k7 instead of 27k and it will be on a wattage above what I keep on-hand.
I am going shopping for something to use for buss wire.  I want something more rigid than the copper I usually use.  I am not sure what Sluckey is using or if it is very rigid, but I do really like the style in which it is implemented.  Looks very clean.
« Reply #249 on: April 17, 2014, 04:48:33 am »
                Brad       :m2
The vibrato is way cool, but keep in mind the normal channel has a unique tone all of its own and a different touch than any other amp.  There I go reminiscing again.  I have begun to worry some that my memory may be playing tricks, but a lot of people go through great extremes to attempt to recreate these amps.  Some people I have emailed have made exact replicas.  There are not near as many people building them as it is harder to clone one.  The reproduction cabinets North Coast has are really beginning to help the Vox to be cloned.
